Thread: Problem while copying handycam to cd or pc.. |
New member Username: Devendra
Mumbai,
Maharashtra
India
Post Number: 1 Registered: Mar-07
| Posted on Friday, March 09, 2007 - 04:52 am: |
i to all i m devendra from india....I have sony DCR-HC36E camcorder, i have connect the it to pc via usb. i try to creat cd by using picture package software, i using picture package vcd maker option , but when i click on start button it show message " pls insert blank cd in destenation device " any one have any idia about this....pls help.... U can mail me on : devya9@rediffmail.com |
Relevant Product Info
Platinum Member Username: Project6
Post Number: 13408 Registered: Dec-03
| Posted on Monday, March 12, 2007 - 04:06 pm: |
Do not use USB. Get a better video capture card or firewire. |
New member Username: Pravin_shashi
Howrah,
WB
India
Post Number: 1 Registered: May-07
| Posted on Thursday, May 17, 2007 - 05:56 am: |
I have sony DCR-HC36E camcorder,While i am trying to burn VCD from camera to Computer, them I am getting a message that :: you have to install macromedia flash player first" But my PC has ADobe flash player 9.0 installed in it. I am unable to burn cd for the tapes I recorded. Can any one help me. Regards Pravin |
New member Username: Lorna1313
Post Number: 1 Registered: Jun-07
| Posted on Friday, June 29, 2007 - 06:24 am: |
I have a DCR-DVD92E PAL sony camcorder and im wondering if i can transfer my videos onto my computer via any i link or USB cable of some sort. Any suggestions would be grateful. Lorna |
New member Username: Heilasatru
Windhoek Namibia
Post Number: 1 Registered: Apr-08
| Posted on Wednesday, April 09, 2008 - 06:40 am: |
Greetings to all I have surfed the Web and found nothing...this is my problem: I have a Sony Video Recorder (DCR-TRV265E). I had it for 4 years and had no problems ripping the video from my camera ontu my PC and then burning it on a CD (it burns only VCD). Since yesterday all went well, but here it goes. It normaly splits the video in sections of each 9 minutes and then has 5-7 sections of those. But yesterday it only took 3 minutes of video and burned it. The rest he just forgot!! Can anybody of this board help me - silly and desperate video Mom with NO answers Should you have a direct answer or a link to a site that can help - I will be SO GRATEFULL!! Send an email to : heil_asatru@yahoo.de Thanks to all |
New member Username: Nits
| Posted on Wednesday, April 09, 2008 - 10:25 am: |
Hello i have sony DCR trv 355e. My pc has dual core , 160GB HD , 1GB RAM with XP-SP2 OS. I am trying to capture video using firewire and windows movie maker When i connect my cam to pc , the system recognises it after a long delay. when i start WMM it gets extremely slow, and WMM almost stops responding. after patiently going through all steps of "capture video with best quality" then " capture automatically etc." it finally shows me a message that there is no cassste in the handycam. I have just not been able to figure out the reason.i have tried reloading the OS even reformatting the whole system but nothing is helping. Can somebody please guide me?I will be highly obliged |
Post Number: 15684 Registered: Dec-03
| Posted on Thursday, April 10, 2008 - 09:24 pm: |
Increase your RAM to 2 GB minimum, if you are planning on doing any heavy editing. |
Windhoek Namibia
Post Number: 2 Registered: Apr-08
| Posted on Friday, April 11, 2008 - 01:28 pm: |
any answer to my question? Please help! Could it be that my PC has only 769MB left from the original 40gig? I have 2.4ghz & 704 mb of ram? |
Bronze Member Username: Ieee488
Post Number: 75 Registered: Dec-07
| Posted on Friday, April 11, 2008 - 04:54 pm: |
You only have 769MB left ???? You simply don't have enough space for your PC to do anything anymore. I'm not sure why you insist and burning VCDs. That technology is so old. Do you self a favor and buy a new PC with more RAM and a bigger hard drive and DVD burner. |
Windhoek Namibia
Post Number: 3 Registered: Apr-08
| Posted on Tuesday, April 15, 2008 - 11:27 am: |
thanks LK for the kind words - I have upgraded to the latest version (which is still available on the Net.. old things are still active then)... my PC has both a CD & DVD burner-- thanks for the advise - buying a new camera also would mybe a good idee :o| but seeing that MANY ppl still have these Camcorder with the old software - doesn't it make you think that this is a good camera!! Thinking that I have to many files on my PC I have deleted some.. it helped a bit, but not for the 5 minutes on the end of the tape *sniff*. So now I am upgrading to Cylink DVD and copien it to my DVD player & then fixing it with PowerDVD. |
New member Username: Dbradley
Post Number: 1 Registered: May-08
| Posted on Thursday, May 15, 2008 - 11:38 am: |
I have a Sony Handycam DCR-HC46 I have the drivers installed them when I try to start the program it says Cannot find the Handycam (Tape). Check the i.LINK connection to the Handycam. I am not sure whats going on PLZ help me. You can contact me at donnabradley9@hotmail.com |
Silver Member Username: Ieee488
Post Number: 103 Registered: Dec-07
| Posted on Thursday, May 15, 2008 - 01:22 pm: |
Cannot start what program ? |
Post Number: 2 Registered: May-08
| Posted on Friday, May 16, 2008 - 02:59 am: |
I can start the Handycam Program but, when I have it all hooked up to the computer and bring up the program it says Cannot find the Handycam (Tape). Check the i.LINK connection to the Handycam. |
Post Number: 104 Registered: Dec-07
| Posted on Friday, May 16, 2008 - 09:15 am: |
Is your operating system compatible with that program ? |
