Home > Message Board > Photography > Camcorders > Archive through November 24, 2004 > I may become a videographer.
Author Thread: I may become a videographer.
brianrehmann
I might be recording weddings in my home town. My Uncle did it for 10 years or longer with an old RCA s-vhs. I have no compatition but I still want people to be happy with it..I plan on making the recording to a DVD. In your opinion what camera should I buy??
THANKS!
Drhiberd
I would recommend the Canon GL2 or Sony VX2100. You can get them both for around $2000. They are excellent, and will get you the results you are looking for.
BrianRehmann
Not the canon XL?
Thank you!
Drhiberd
The XL1S is an excellent camera, but I don't think you need to spend that much. If you check Cnet.com, the GL2 got a much better review than the XL1S. In all the research I have done, I think the reason people are so big on the XL1S is because it has interchangeable lenses. I cannot imagine that would be something you would need for weddings. Both the Sony VX2100 and the Canon GL2 can take zoom microphones and external mics, as well as wide-angle lenses. The rating on picture quality is better on these two cameras, plus they have an LCD screen and the XL1S does not. I'm sure the XL1S is a wonderful camera, but I think you would be wasting money when you could get one of the other two for around $2000. Hope this helps
ginger chris
If youre going to do it properly you need to be able to hear people. the speeches and vows.
this means proper mics/ radio mics. which have XLR connectors. hence need a pro camera that can accept them
canon xl1s
panasonic ag dvx100
or pro version of the sony vx2100 -> pd170
jones
Canon has an adapter for the GL2 for XLR connections. You can also get one for the Sony.
Home > Message Board > Photography > Camcorders > Archive through November 24, 2004 > I may become a videographer. [ « Previous ] [ Next » ]
