Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > Problem with canon camcorder. Help pl...
Author Thread: Problem with canon camcorder. Help please...
Username: Jen06
I have a canon mvx250i camcoder that is having problems with its zoom. Sometimes when I turn the camera on it will zoom in (to the closest zoom) on its own, and when I try and zoom out - it will slowly zoom out, but then after I let go of the zoom out switch,it automatically zooms back in on its own (to the closest zoom again). After a couple days it normally reverts back to normal functioning and the zoom works fine. This problem seems to happen after I recharge the battery (I don't know whether this is a coincidence or not). Anyway, this time the camera is not reverting back to its normal functioning and it seems to be stuck with this zoom problem. Please help.....thanks
Username: Gromit
Post Number: 603
This is probably a defect that requires the unit to be serviced. If you are lucky there might be just a bit of gunk in the switch that can be displaced with a puff from a compressed air canister. But the surface of the unit is probably sealed so I doubt that you could do it yourself.
Cheers.
Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > Problem with canon camcorder. Help pl... [ « Previous ] [ Next » ]
