Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > JVC CCD sensor
Author Thread: JVC CCD sensor
Username: Jetset
My JVC GR-D23 camcorder is not showing any image on the LCD monitor. Screen is black but text is displayed. In fact it asks for Lens Cap to be removed, when this is so already. However image displays when tape is played back. Also nothing can be seen through the viewfinder either.
I took it to a repair shop, and as soon as he saw the camcorder, without me saying anything, he described my exact symptoms. He said that this was the 4th camera with the same problem in a week! He said it has a faulty CCD Sensor and the camcorder is vertually a write-off. He suggested that as I've just missed the guarantee, i should check whether perhaps a faulty batch was produced which were called back.
For me, this was a really an expensive purchase, so I'll go crazy if I have to throw it away. Has this fault happened to anyone else?
Username: Jaloed20
Ft Stewart, GA
Yes and I just missed the warranty as well. The same problem happen to a Minolta camera that I have and when I called the company they explained to me that there was a recall on the camera and that they will fix, and cover the shipping costs even though the camera is 3 years old
Username: Jetset
Jossilia, Do you mean JVC had a product recall, or Minolta?
Username: Jaloed20
Ft Stewart, GA
Minolta, but today at the JVC Customer service they told me that if it was the CCD Sensor they will fix it for free, you only have to send the camera.
Username: Jetset
Thanks for that. I will email them and hope that I will get the same response! Thanks
Username: Jetset
if any one is interested.......
http://www.jvc.co.uk/knowledge-list.php?id=4#0
Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > JVC CCD sensor [ « Previous ] [ Next » ]
