Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > Newbie with JVC Mini DV GR-DVM76U, ne...
Author Thread: Newbie with JVC Mini DV GR-DVM76U, need lots of help!
Username: Wildwind
Hi,
I got a JVC Mini DV camcorder in a trade, unfortunately I did not get instructions with it. I figured out how to use it to record and take pictures. But my question is how do I hook it into the TV so I can view it and then transfer it to DVD? I know it is probably a simple procedure, but I am not a technology wiz. :-) Please help. I will probably have more questions later.
Username: Project6
Post Number: 10555
First visit the JVC USA website. You candownload a manual from there.
Username: Wildwind
Berny,
Thank you very much! I knew that I should be able to get instructions from the internet. You just made my search easier. I will read through it and let you know if I have any further questions. Again, thank you!
Melinda
Username: Project6
Post Number: 10563
Look at the available outputs on the camcorder as well. You should see some audio and video outputs to connect to the TV.
Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > Newbie with JVC Mini DV GR-DVM76U, ne... [ « Previous ] [ Next » ]
