Thread: Handycam to Laptop |
New member Username: Amit_180
Post Number: 1 Registered: Aug-06
| Posted on Thursday, August 17, 2006 - 02:17 am: |
Hi I have a SONY TRV 22E handycam. Need to know how to transfer the video to the laptop ? Also, is it possible to copy only say 10 mins of the video instead of complete download? Really appreciate a quck response ! thanks Amit |
Post Number: 9634 Registered: Dec-03
| Posted on Thursday, August 17, 2006 - 02:57 am: |
Depends on the outputs of your camcorder and the inputs of your laptop. And USB is not an acceptable way of transferring video and audio to the laptop. Preferred way is via firewire/IEEE1394. If you don't have it, you will need a video capture card. |
Post Number: 2 Registered: Aug-06
| Posted on Thursday, August 17, 2006 - 03:21 am: |
thanks ! does the same come with the standard package of the handycam or are these to be procured separately ! separatey, are the files too large ? |
Post Number: 9635 Registered: Dec-03
| Posted on Thursday, August 17, 2006 - 04:27 am: |
That handy cam has a firewire output so you have no problem there. Check your laptop if it has firewire input (IEEE1394) If it does, you are in luck! If not you have to get one. A firewire to USB adaptor is not going to work, so be forewarned. You are going to need a firewire cable and it is sold separately. You also need a video editing program to extract the movie from your handycam. And yes, the files will be quite large. |
