Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > How do i transfer video from Analog c...
Author Thread: How do i transfer video from Analog cam to my PC
Username: Che41v
Dear!
I've a Panasonic Analog camrecorder, with a mini tape. I'd like to
transfer my video to PC, i have a IEEE 1394 cable.
So, which software can be used in this case.
Could you help me!
Thanks for cares and waiting for your reply
Username: Project6
Post Number: 9580
HMK,
Does your camcorder have a DV output?
If it does, you need to check if your PC has an IEEE1394 input. Having the cable means nothing until you have provisions that can use it.
If it does not, you will need a video capture card.
Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > How do i transfer video from Analog c... [ « Previous ] [ Next » ]
