Home > Message Board > Photography > Digital Cameras > How do I "clear" Memory stick?
Author Thread: How do I "clear" Memory stick?
Username: Ewile
Sorry my question is so elementary, but how do I remove images from my DSC-H5 CyberShot memory stick duo after I have downloaded the images to my camera?
Relevant Product Info
Username: Project6
Post Number: 9292
Use the format function og the camera or you can use the PC to delete all the files.
Username: Mamasi
W. Barnstable, MA
United States
Hi Berny,
I have the same question, as a new digital camera user, and notice you've explained what to do, but not HOW to do it. Would you please elaborate?
Thanks!
M. Masi
Username: Project6
Post Number: 13124
Is this for the Sony?
Go to the set-up menu and look for "Format Memory" function. Consult your manual for details.
Username: Mel4576
Just about all digital cameras have a delete all funtion on the camera, check the manual. The way I delete my memory card is using the photo program on my pc that transfers the pictures over. The program I use actually has a checkbox that says 'delete photos on camera after download' right on the download screen or I use the delete all fuction while using the photo program. For more digital camera tips visit http://www.digital-camera-help.com/
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Photography > Digital Cameras > How do I "clear" Memory stick? [ « Previous ] [ Next » ]
