Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > Goddamn It!!! JVC-GR-D340E Help needed
Author Thread: Goddamn It!!! JVC-GR-D340E Help needed
Username: Bgrmckay
Post Number: 7
Help needed! I recently bought a JVC GR-D340E DV camera and need to transfer my recordings onto my PC. I bought a Firewire cable separately and have been trying to transfer my stuff across using Windows Media Maker on XP. Unfortunately, movie maker does not detect my camera. I have tried all the usual - turning it off and then on again etc... but it's still not working. Am I missing some software or anything else for that matter?
Following on from some of the threads I read earlier, I have looked on device manager for the IEEE1394 bus controller and I don't have it although there is a firewire connection in the back of my PC. What's going on?
Username: Project6
Post Number: 9312
If you have a firewire port on your PC and you cannot see it under your device manager, you have a faulty port.
Check the inside of your CPU and check if the firewire is even connected to the board.
Home > Message Board > Photography > Camcorders > Archive through December 29, 2006 > Goddamn It!!! JVC-GR-D340E Help needed [ « Previous ] [ Next » ]
