Home > Message Board > Photography > Camcorders > Archive through October 21, 2007 > DVD Sony Camcoder to PC
Author Thread: DVD Sony Camcoder to PC
Username: Ilpap
Dear all,
I just bought a Sony DCR-DVD 105, I rec some dvd's (dvd-R) and what I want to do is to put them all together in a file (if possible) in my pc but at the same time to edit them (for example cut some scenes, put some titles etc). I tried to do this by using Microsoft Movie Maker but it cannot regongised the format of the files in the dvd-r (MPEG). What I tried was to rip the file, the Micr. Movie Maker regognised the file but the quality is extremely low! Can anyone help on these issues. How i can do all these but having the primary quality of the dvd?
Thank you a lot!!
Username: Project6
Post Number: 8884
You'd want to use a full featured video editing software like Adobe Premiere.
Username: Ilpap
Berny,
I installed the Adobe Premiere. I am trying to import any file from the dvd (mini) I have record with the sony but the S/W cannot find any file (probably cannot regognize the specific format??).
What I can do?? i need to gather 6 mini dvd's probably to one but having done some editings.
Username: Project6
Post Number: 8944
Have you finalized the DVD by using the camcorder?
Username: Project6
Post Number: 8945
Insert the DVD into the DVD-ROM drive of the computer.
On the computer desktop, click the Start button and then click My Computer.
NOTE: If available, you can double-click the My Computer icon on the desktop instead.
In the My Computer window, right-click the DVD Drive icon, then click Open.
Right-click the appropriate folder and then click Copy.
For still images, right-click the DCIM folder.
For movie files, right-click the VIDEO_TS folder.
Right-click on the desktop and then click Paste.
NOTE: The folder and all the contents in the folder will be copied to the desktop of the computer.
On the computer desktop, right-click the newly copied folder and then click Rename.
Type a new name for the folder.
Press the ENTER key on the keyboard.
Username: Ilpap
I have already Finalize the disc in the camcoder. I follow exactly what you wrote but as it I was expected that didin't change the situation. Adobe still cannot see anything.Do I have anything additional after these steps??
Thannk you very much for your replies and your time.
Username: Project6
Post Number: 8956
Sorry Ilias, that is all I can think of. I have worked on those files and I didn't have trouble with them.
One mor ething to check is to see if Adobe has the plug-ins for the Sony format. Got to the Adobe website for more information.
Username: Ilpap
ok.thank you
Username: Parantapudu
Hi All,
I have a sony camcorder DCR-DVD201. It records the media to a DVD-R/RW disc.
The product was shipped along with its USB driver and Imagemixer Version1.5 for Sony DVD software.
Unfortunately i lost the s/w CD and adding to it my harddisk also crashed.
Can someone please let me know where i can get this software from?
Any pointer's on this would be helpful.
Thanks
Anand Vardhan
Home > Message Board > Photography > Camcorders > Archive through October 21, 2007 > DVD Sony Camcoder to PC [ « Previous ] [ Next » ]
