Thread: NV-DS65EN |
New member Username: Usbusb
Post Number: 2 Registered: Jul-06
| Posted on Tuesday, July 04, 2006 - 04:32 am: |
hi all. has anybody here owned Panasonic NV-DS65EN? I've been capturing the video to pc via usb cable provided n have used sotware such as windows movie maker, ulead etc.. the thing is the video captured wasnt in real time, ie it lags n jerky. So how do you NV-DS65EN owners do it then? thanks,,, |
Post Number: 8427 Registered: Dec-03
| Posted on Friday, July 07, 2006 - 07:36 am: |
Use the DV output and NOT USB. Connect it to a firewire/IEEE1394 input on your PC, get one if you don't have one. USB is not going to work well. |
Post Number: 3 Registered: Jul-06
| Posted on Friday, July 07, 2006 - 08:50 pm: |
thanks for the reply...can i use this cable? ie firewire to usb cable, will i still lose quality, will it still lags...thanks again
Post Number: 8480 Registered: Dec-03
| Posted on Friday, July 07, 2006 - 11:14 pm: |
That is not going to work. You can try it but you will have problems. |
Post Number: 4 Registered: Jul-06
| Posted on Friday, July 14, 2006 - 11:46 pm: |
thanks berny, just bought n installed PCI firewire card, then connected it to my camcorder...capturing works well....so to other users..GET A FIREWIRE CARD!!!!!!! |
New member Username: Harlan138
Post Number: 1 Registered: Nov-06
| Posted on Sunday, November 26, 2006 - 07:58 am: |
While capturing the video to PC it always stops at the blank tape. Anybody can help? |
