Thread: JVC GR-D290 [Need Help Please] |
New member Username: Heawow
Post Number: 1 Registered: Jun-06
| Posted on Saturday, June 10, 2006 - 07:35 am: |
Hi, I just bought JVC GR-D290 a week ago. The problem is that i cannot transfer the video I captured with this handycam into my PC. But I can transfer the image that I captured into my PC using the USB cable provided. My PC recognised my handycan when I switch to MEMORY mode and it won't recognise it when I switch it to VIDEO mode. Please guide.. Thanks. |
New member Username: Barton71
Post Number: 5 Registered: Jun-06
| Posted on Tuesday, June 27, 2006 - 05:54 pm: |
You know that you need a firewire to transfer the video to the PC. USB wont do it. If you dont have one, you can pick one up on Amazon reasonably cheaply. |
New member Username: Da_silva
Post Number: 1 Registered: Sep-06
| Posted on Thursday, September 14, 2006 - 11:24 am: |
i have a JVC GR-D290 that i bought last week. i have a problem that i can not connect my cam to my pc (XP) using the usb cable (the pc not detecting the cam), the pc keep asking to install the drives or software which i already installed. can any help me with that problem, or could some one tell me which sites i can download the software for my mini dv? Please............ |
Platinum Member Username: Project6
Post Number: 10875 Registered: Dec-03
| Posted on Thursday, September 14, 2006 - 01:33 pm: |
Junevio, Use firewire to connect your camcorder to your PC. Your JVC should also have software that was included in the package. You need to install the software first before you connect anything. |
