Home > Message Board > Photography > Digital Cameras > Sony Cybershot P92 > Archive through June 29, 2005
Author Thread: Archive through June 29, 2005
eliciaholly
We are thinking of getting this camera for family trips. I like a camera that has attention to clarity and the pictures are clear and sharp. Does anyone have any info on this camera they want to share? Good or bad? Any info is greatly appreciated!
Relevant Product Info
Username: Project6
Post Number: 397
not a bad camera. Easy to use and good picture quality, however, it will not be my first choice as a camera. It is a great consumer camera, though.
I didn't like the proprietary memory stick, though. Make sure to get lots of extra batteries as it uses it up a lot. The rechargeable ones do not fare any better.
Harriet
I have a sony cybershot camera, but recently it is saying "format error". i was wondering how to fix it?
Username: Project6
Post Number: 1185
you have to reformat the memory card.
Carlos Ricalde
Dear sir:
I have a physical problem with the SONY CYBERSHOT P-92, the viewfinder (1.5" color LCD) is probably broken, so I would like to contact some Sony dealer (e-mails). I live in Cusco-Perú-South America.
I also guess you are the one to tell me where and tell me about repairing cost.
Please I appreciate your answer.
Carlos
Username: Project6
Post Number: 1192
My apologies, Carlos. But I know of no Sony repair centers in Peru. The best place to check is to contact the place where you purchased the camera.
Brian J
I have a Cybershot P92. The lens is extending out but it makes a clicking noise. Then it shuts itself off. I live near Detroit, Michigan. Does anyone have a clue of what the problem is and how to get it fixed? Thank you for your time.
Username: Project6
Post Number: 1217
Sounds like the motor is on the fritz, and the camera senses a blockage on the front lens. Take it to your authorized Sony repair center. Check your warranty.
ted edward
I have a sony cyber-shot dsc-f707 camera. I reformatted the hard drive on my computer but lost the software to be able to download pics off my camera. Sony wants around $60 for a replacement disc and shipping. I am using windowes 98. I don't need to modify the pics, just transfer them. There has got to be a way to download something free to use, and have it today. Thanks for any help.
Username: Project6
Post Number: 1228
ted,
you can just take the memory stick out of the camera and transfer it directly to your computer. You really don't need the camera to transfer pictures to your pc.
I have a Sony DSC-P31m Cyber Shot. While in Scotland, the Camera got pretty wet. It won't turn on anymore, and it has dried for 7 days.
Suggestions?
Where in Los Angeles to get it fixed? (or just buy a new one) Thank you
Marshall (lives in 91411 area)
Username: Project6
Post Number: 1301
Get a new one, it will have better features and much better resolution at probably the same price you paid for the older one. The problem with digital cameras nowadays is that they become obsolete after 6 months.
cheers
I have a Sony Cyber shot 3.2 megapixels refurbished, and memory stick refurbished. The lens does not retract although it tries. I try to transfer my pictures to my computer and it says "Turn the power off and on again" I have done that but doesn't seem to help. I can still review my images. I don't see any way to transfer from the memory stick - how do i do that?
Username: Project6
Post Number: 1350
snowquail, get a memory card reader. You hook this up to your computer and insert your memoy stick and it will transfer your images from the memory stick to the PC.
I have sybershot dsc p71 camera. It has been functioning very good for 2 years (even though I dropped it twice) now it doesnt focus any more. Actually it does focus but all the pics turn out very blury (no sharp outlines) It can still take close objects with makro but that is about it.
Is it possible to get it repaired?
Thanks
Botond
I have a Sony DSC-P71 / Re-formatted my hard drive & now can't downoad photos ?? Previously I just plugged the camera into the port and it automatically downloaded photos to my desktop ?? Any suggestions ??
Username: Project6
Post Number: 1758
what port are you using?? Make sure that it is enabled, and you have all the drivers.
cyber shotP92 six month old giving memory stic error but when memory stic checked in another camera it is working
Username: Heinousleecha
My Cyber-shot DSC-P71 is approximately three years old. Suddenly, I am unable to take photos. When I press the button to take a photo, absolutely nothing happens. This happened after I was playing with menu options and attempting to add the date/time to the display.
Does anybody know if I inadvertently locked the camera and, if so, how to unlock it?
Thanks in advance --
Lori
Username: Project6
Post Number: 1844
do you still have the manual?
I have a two year old Sony DSC-P71 that we love. However, we let our sister-in-law borrow it and it came back with the lens cover and ring completely off the camera. I have tried to fix it and its too intricate for my large hands. The repair shop quotes us $200 for repair. Any other ideas?
Berny: I cannot find the manual. That's why I was hoping somebody else would know what to do.
we have a sony cyber shot 1.3, and when i turned it on yesterday even though it still showed the ciew screen, it said "Memory stick error" and was beeping and flashing. What's going on and how do i fix it?
Username: Project6
Post Number: 1945
Lori
Try the website, they may still have manuals that you can download in Adobe format.
Chelsea,
Try reformatting the memory stick.
chelsea
how does one go about reformatting the memory stick?
Username: Project6
Post Number: 1957
try this website.
The manuals should still be there.
http://ciscdb.sel.sony.com/perl/modelpage.pl?template=EN&mdl=DSCP30&session_id=b 4571e69588157337ba11be871909f25
cheaza
problem is I cant reformat the memory stick because of the C:13:01 error. I found this website here http://www.pechorin.com/m/2003/07/12/SONY_C1301_ERROR-202719-2.html
and it suggested that i needed to use the end of a pencil eraser to clean off the gold contacts and then start the computer up in set up and format it then. well it restarted fine but i didnt reformat it then. Any suggestions to get it working again?
Username: Project6
Post Number: 1975
use the camera to reformat the card.
I just bought a DSC-P73 camera and I am having problem transfering pictures to my computer. I am using Windows XP SP1. When I connect the camera to the USB port, I see in "My computer", "Sony Memory Stick". I am able to go in the folder and as soon as I see a picture, the window closes and it disconnects. I go back in "My computer" and I don't see the Memory stick anymore. Can somebody please help me!
Username: Kvprasad
how to use my sony dsc 972 as a webcam, the manual does not mention this. It is urgent, faster reply will be of great help.
My CyberShot P-92 is dropping pictures. When I take pictures it erases pictures that we're previously stored on the memory stick. This has happened with 3 different memeory sticks. Anyone have any similar experiences or luck in recovering lost pictures from a memory stick?
alexxxxxxxxxxxx
I just got a cyber dsc-p73 ... I have read all your comments on the camera (it was a gift or it wouldnt have been my first choice) besides the point... you guys are scaring me ?? can someone tell me if it is a good reliable camera that will keep up with me .. (eg) if i go away on vacation with a reg 35mm cam i usually take 12 rolls a film in the week .. is this a camera for me or should I get something better .. thanks
Username: Project6
Post Number: 2208
Have you actually compared a 35mm camera with this digital point and shoot?
You'll be fine. Just bring plenty of back up batteries.
Username: Sfreshour
Hi, Hope someone can help me out here. I did a lot of research on digital cameras and the SonyDSC P92 5 mp CyberShot got super reviews. However, I am not happy at all with the color quality of my snap shots, they are too orange. When I first got it a year ago it seemed like the pictures were really sharp and clear with true color but now, inside or out, the color is terrible. I took a picture of a chestnut horse, and he turned out the color of dark rust. I am the only person who has ever taken any pictures with it, but one time I asked someone to take pictures for me in Multi Burst and they were fidding around with the settings, however, never actually used it. Dont' know if that is when things changged or not. Why would my color be off so bad?
Username: Project6
Post Number: 2215
Check your white balance in the camera settings.
Username: Sfreshour
Thanks so much for your fast reply, I will try that. When I went into camera settings, my camera was set to Program. Would this have had any effect on my color? (I have changed it to auto)The white balance settings were set to auto.
Where would I set the WB when I am taking pictures indoors? I took pictures on Christmas Day inside and they were horrible also. I am also confused as to where to set the flash when I am taking pictures indoors. I just seem to remember my camera taking lots better pictures when I first got it than it does now. They are also coming out blurry when I take them indoors.
Username: Project6
Post Number: 2223
When in program mode you have to specify the white balance on your camera. the auto feature does not work well on some situations. The white balance should be set to corespond with the type of lighting that is illuminating your subject. you should have settings for flourescent, incandesecnt, flash, cloudy, sunny and in the shade lighting.
If you take pictures on full auto and not in program mode, it will take a lot of guesswork away. It is, however, beneficial for you to understand more about lighting situations and how your camera works undeer different circumstances.
Experiment, read the manual, have fun!
Oh and check to see if your camera has a reset button, to bring it back to factory default settings.
Username: Sfreshour
OK, found those differents settings and did some practice shots in the house and they turned out a lot better, I adjusted the WB to take some outside, (it is dreary and cloudy here today) but the color is more true. Thanks so much for your help! I am learning a lot about my camera today!Took it off Auto and put it back on Program. One more question, what flash setting usually works the best when taking pictures in doors?
Username: Project6
Post Number: 2224
i only know of one flash setting on digital point and shoot cameras...on or off. If it is on program mode you should have an indicator in the viewfinder that meters available light and it should tell you if you need a flash by displaying the lightning symbol. if you don't use the flash indoors and the indicator is flashing, the camera will adjust to a slower shutter speed and will cause blurring of pictures, unless the subject and camera are steady. Makes for a very dramatic and interesting effects, you should try it.
Username: Sfreshour
actually, in my manual, there is a section on Selecting Flash mode, and the different settings are Auto, Forced Flash, Slow Synchro and No Flash. Also a section for Adjusting the Flash Level cn select high, normal or low). I guess I just need to play around with these settings and see what works. Thanks so much for your help today, I got some nice pictures this afternoon!
Username: Project6
Post Number: 2232
I see what you mean by flash settings.
Auto-means exactly that, the camera meters the available light and sets the amount of flash to illuminate the subject.
Forced Flash - used when there are deep shadows on the subject that you want to fill in. Very useful when you are outside and the sun is behind your subject, use it to light the shadows on the front of your subject.
Slow Synchro - used when you want to capture the ambient light behind the subject, e.g., night time on the streets and you want to show the neon lighting behind your subject.
The flash level takes experience. A high setting will give you the maximum burst of the flash and highlights your subject very brightly. Normal will give you even exposures and almost flat picture. Low will give more depth and emotion as it doesn't completely light up the shadows.
I think its time for you to get a Digital SLR:-)
Hi there,
I need help because i have a strange problem with my SONY Cyber-Shot P31
I have change the Auto Focus off and suddendly nothing happens anymore. I can´t turn the Camera on in the Photo or Camera Mode but just in the MemoryMode to watch my Pictures. I don´t know what i have done and hope you know the solution. Thanks
Björn
Username: Sfreshour
You explained the flash settings a lot more clearly than the manual, now I understand the Forced Flash, sometimes just need it worded a little differently.
What is a Digital SLR?
Username: Project6
Post Number: 2240
Sharon
check out this site.
Very informative and should lead on the right track.
http://www.kenrockwell.com/tech/2dig.htm
Username: Project6
Post Number: 2241
Björn,
Go to the Sony website and they should have an answer for you.
Check also your manual, and check "how to reset" the camera to factory specifications.
I just bought a Sony Cybershot P92 and I am in doubt of what kind of memory card to buy for it? Can anyone help me?
Username: Project6
Post Number: 2289
Sony memory stick.
67354
I've got a Cyber-shot P93 I know sony that by using memory stick pro I can get higher frame rates when recording. Sony just released high speed memory stick pro, I know its compatible but is there any advantage to this new memmory?
Username: Project6
Post Number: 2321
faster write speeds.
Hello.A friend gave me a Sony P-92, with 256 memory stick, usb cable, everything, but the manual. Is there some link, some place can I get the manual for free, in english, spanish or portuguese? Thanks a lot. Sandra
Username: Project6
Post Number: 2403
go to the sony website
I have a Sony Cybershot DSC-93 but I have misplaced the CD with all the software to download the pictures. Does anybody have any idead where I can download this from? I've tried contacting Sony but it looks as if they would like to charge me the earth for one CD.
I just purchased a new DSC P93 and I am having a very difficult time getting a true color. I have tried all of the white balance settings and still have a problem. The subject is one of my wife's paintings, so true color is mandatory. On atuo mode, the colors are too warm, greens become muddy. In any of the other modes that correct the green, the whites take on a bluish cast. Is this correctable? I had better results with Fuji color print film and an Epson scanner.
Username: Project6
Post Number: 2442
Wes, you have to take into consideration the monitor you are using. Make sure that it is properly calibrated to coincide with the prints or results that you want.
If you can, try to calibrate the white balance on your Sony by using a white or gray card. You should be able to know if this is possible by reading your manual.
Also a good photo editing software is a must, i.e. Photoshop.
You just can't do too much with a point and shoot camera.
Wes
That is the conclusion that I had reached. The Cybershot was relatively cheap after buying a Vaio desktop with all the media bells and whistles. After some practice there, I think I will end up buying a Nikon D70 to go with my N70 and its lenses. Yeah, I know the focal length changes when used on the D70...
Username: Pleasehelp
Woodbury, Mn
Usa
I HAVE A SONY MEMORY CARD THAT RECENTLY WHEN I PUT INTO THE SANDISK SAID: NEEDS TO BE FORMATTED. WOULD YOU LIKR TO FORMAT OR NOT. I AM SO SCRAED THAT I HAVE LOST ALL MY WEDDING PICS. I KEEP NOT FORMATTING COS I AM SCARED OF LOSING PICS. IS THERE ANYHOW POSSIBLE TO RETRIEVE THESE PICS AT ALL?????????
Top of pagePrevious messageNext messageBottom of page
