Thread: Need help with a DSLR lens |
New member Username: Seeemeeego
New Orleans,
LA
Post Number: 7 Registered: Apr-06
| Posted on Wednesday, April 12, 2006 - 01:11 pm: |
OK, I'm back. I have purchased a Nikon D50 body that came with a Nikon 18-55mm AF-S DX Zoom Lens. Now I need to buy something for distance. As I said before, I am a journalism teacher buying a camera for school yearbook photography. I need the most bang for my buck, one lens that would handle the most telephoto type shots for the best price I can suss out. I don't want much, do I? What about this one - "Sigma's 70-300mm f/4-5.6 APO Super Macro lens is a compact apochromatic tele zoom lens incorporating two Special Low Dispersion glass elements in the front lens group, plus one Special Low Dispersion glass element in the rear lens group, to minimize chromatic aberration. This Tele-Macro Zoom lens is capable of focusing down to 1:2 (half life-size) reproduction ratio at 300mm focal length with superb optical quality. The advanced optical design of the 70-300mm APO Super Macro lens uses materials that are lead and arsenic free ecological glass. A detachable bayonet hood is included. The Sigma 70-300mm f/4-5.6 APO Super Macro is an extremely versatile lens that is ideal for close-up work, portraits, sports and nature photography, and all telephoto requirements. Will mount to ANY Nikon Manual Focus or AutoFocus Film or Digital SLR Camera." Thanks again guys for your help.
Post Number: 7416 Registered: Dec-03
| Posted on Wednesday, April 12, 2006 - 05:31 pm: |
Yes, that will work. It is also important to state a budget when you are trying to get recommendations for lens. |
New Orleans,
LA
Post Number: 8 Registered: Apr-06
| Posted on Wednesday, April 12, 2006 - 06:39 pm: |
Thanks Berny. I can't say that I really have budgeted an amount for a lens. I'm just looking for the lowest price lens that will cover the bases for me. I'm basically buying this for high school students to use, and I'm paying for it out of my own pocket so I'm just trying to get us by. I'm glad to know that is a lens that will work for me. I appreciate your help. |
Post Number: 7418 Registered: Dec-03
| Posted on Wednesday, April 12, 2006 - 08:46 pm: |
In that case...that would be the perfect lens |
Silver Member Username: Claudermilk
Post Number: 302 Registered: Sep-04
| Posted on Thursday, April 13, 2006 - 10:21 am: |
Any possibility of going used? Take a look over at KEH, they usually have a good selection of equipment & it would help save a few more bucks. |
