Thread: Tdc-12 minicam , need software help please? |
New member Username: Debbie
Post Number: 1 Registered: Feb-06
| Posted on Sunday, February 26, 2006 - 01:55 pm: |
I have a 2nd hand MiniCam TDC-12 working but no software to get photos from the camera to my pc, any tips on finding the software? any other advice?? |
Post Number: 6365 Registered: Dec-03
| Posted on Sunday, February 26, 2006 - 05:12 pm: |
Purchase a decent video editing software. Check the capabilities of your computer. Find out if it is capable of video capture or a firewire input (IEEE1394). If it does not have any of these, you need to upgrade. Make sure that your operating systme is the latest version of XP, you'll have problems with others. Check your camera's capabilities and if it has outputs to interface with your PC. A DV output will be best.
New member Username: Digital_man16
Post Number: 2 Registered: Feb-06
| Posted on Tuesday, February 28, 2006 - 08:42 pm: |
Can anybody help me with my problem??? I got a DSC-S40 and i used it for a while then i got a message that read turn power off and then on agina! Any Body help me please??? Thanks in advance! |
