Thread: Need help with firewire connect |
New member Username: Yukkerz
Post Number: 2 Registered: Feb-06
| Posted on Sunday, February 19, 2006 - 11:59 pm: |
I have a SC-D353 Samsung camcorder and the cam says "DV-IN" but pc doesnt see it, im using firewire cable to connect it, i just bought new card and wire and nothing. also i have sp2 and i went to try that trick but i don't have the old sp1 installed, pc came with sp2 any help please please please. post back on here or in email- yukker@comcast.net or im me at simplyf0rg0tten. PLEASE HELP |
Post Number: 6100 Registered: Dec-03
| Posted on Monday, February 20, 2006 - 09:18 am: |
If the cam says "DV-IN" that means signal is supposed to go in(to camera)...not out. You should use the "DV-OUT" to connect to the PC. |
Post Number: 3 Registered: Feb-06
| Posted on Monday, February 20, 2006 - 11:10 pm: |
well i mean it has the dv at the bottom right when its hooked up to the pc |
Post Number: 6173 Registered: Dec-03
| Posted on Tuesday, February 21, 2006 - 03:57 am: |
contact samsung tech support. |
