Home > Message Board > Photography > Camcorders > Archive through March 02, 2006 > ImageMixer for JVC GR-D70
Author Thread: ImageMixer for JVC GR-D70
I have a JVC GR-D70 and it came with a bunch of software on a cd, problem is, i lost the CD when i shifted houses. Can anybody send me the installer files for the jvc imagemixer? i would really appreciate it
Brennsol
BTW, i am using a usb cable to connect my jvc camcorder to my pc. it works well when i am using my machine with win2000 on it, but on winxp it doesnt seem to work. i have tried using a firewire cable on it, but unfortunately, without the video capture software (imagemixer) it just doesnt work.
I would appreciate if somebody could send me the installer files for the jvc imagemixer, or a link where i could download it. I have been searching the web for a long time, no luck for a free one :-(
Home > Message Board > Photography > Camcorders > Archive through March 02, 2006 > ImageMixer for JVC GR-D70 [ « Previous ] [ Next » ]
