Thread: Anyone Help me Transfering my tape to PC on My JVC |
New member Username: Darkstar555
Post Number: 1 Registered: Feb-06
| Posted on Thursday, February 02, 2006 - 01:11 pm: |
I have a Mini DV JVC GR-D260EK and I installed the disc they sent me and have all of my cables attached, but unlike my old cam it picks up the stills but when I try to use, say windows movie maker and other capture software its telling me it does not detect my cam, Can anyone help me please |
Post Number: 5133 Registered: Dec-03
| Posted on Thursday, February 02, 2006 - 04:19 pm: |
What cable are you using? |
New member Username: Cowboy_punk
Post Number: 2 Registered: Feb-06
| Posted on Thursday, February 02, 2006 - 06:27 pm: |
I am having the same problem, and I am not using the included Usb to Usb cable, but an aftermarket dv to usb cable. |
Post Number: 5143 Registered: Dec-03
| Posted on Thursday, February 02, 2006 - 06:36 pm: |
Won't work. Use a DV to firewire cable. |
Post Number: 3 Registered: Feb-06
| Posted on Thursday, February 02, 2006 - 07:04 pm: |
why won't it work? even if i download a driver for it? besides, I am on a laptop, so installing a firewire card isn't as "easy" for me as you claim for a desktop tower. |
Post Number: 4 Registered: Feb-06
| Posted on Thursday, February 02, 2006 - 07:06 pm: |
actually, i just did some research and can use my expansion slot, so it's even easier, but this means i have to spend more money on a different cable and the expansion card? there is absolutely no way the cable i am currently using will work?
Post Number: 5153 Registered: Dec-03
| Posted on Thursday, February 02, 2006 - 10:23 pm: |
Go ahead and try it. But you have to take a good look at all the problems being posted on this forum regarding USB. Prime example...you are having a problem right now...aren't you? But hey...maybe you know better. |
