Thread: D200 |
Keith Anderson Unregistered guest |
| Posted on Sunday, January 01, 2006 - 08:43 pm: |
I currently use a D70 to shoot everything from nature to bands. I was wondering what the differences are between the D70 and D200 and if its worth the upgrade, Thanks Keith Anderson |
Post Number: 4650 Registered: Dec-03
| Posted on Monday, January 02, 2006 - 02:40 am: |
http://www.kenrockwell.com/nikon/d200.htm |
| Posted on Monday, January 02, 2006 - 01:18 pm: |
Thanks, after reading that I'm sticking with the D70. Yea I could use the 5 frames per second every once in a while. But the 3 frames works just fine. And personally, shooting live bands where they move alot, I enjoy the 1/500 flash sync, I dont know how the 1/250 is, so I'm happy with what I have. Maybe in a little while I'll upgrade if I have, you know, like $1700 just laying around , which isnt gonna happen...thanks, Keith Anderson |
