Thread: JVC DV Camcorder Problem! |
New member Username: Jamal420
Post Number: 1 Registered: Dec-05
| Posted on Sunday, December 25, 2005 - 09:27 pm: |
I Have GRD31 DV camcorder. It gives an error message "Lens Cap" causing screen to be black although the Cap is removed. If I record, the content is only a Black Screen. Help please! |
New member Username: Stans945
Post Number: 1 Registered: Jan-06
| Posted on Sunday, January 01, 2006 - 04:21 am: |
Gromit - I currently have a lot of family movies on cine film and I am in the process of determining the best method of conversion to digital format. Ideally I would like to have them put on DVD so I can view on the TV, however, they will be a jumbled mess to start with and I would like to then go on and edit, add music, etc. and present them much more professionally in my preferred order. The important question is can I capture directly from DVD on to a PC for editing without loss of quality. The alternative seems to be to convert cine to Mini DV format and download via a camcorder. At present I don't have a camcorder and before spilling out the cash I would appreciate your advice. |
| Posted on Saturday, January 14, 2006 - 06:16 pm: |
I, as well as many others, have experienced the same "Lens Cap" problem on many JVC digital camcorders. JVC has finally recongnized the problem as being a faulty CDD image sensor problem. They are now willing to fix the problem for FREE until 2007. Check out this webpage on thier site. This explains it all: http://www.jvc.com/support/notification/index.jsp?pageID=2 Hope that helps! -Andrew |
| Posted on Sunday, January 15, 2006 - 10:03 am: |
hi, i'm using imagemixer ver. 1.7 with jvc gr-d73u. all the drivers that are in the cd that comes along with the product are already installed. however, i'm unable to create a video cd from a tape in the camera. when the process reaches the part converts image data and sound data a notice saying "easyvcd has caused an error and will now close" appears. anyone pls help me on this. thanks. |
