Thread: Please hellllllpppppp me with my panasonic nv-gs17 |
New member Username: Zerocool2acid
Post Number: 1 Registered: Oct-05
| Posted on Thursday, October 20, 2005 - 05:43 am: |
I need an answer! I hawe a panasonic nv-gs17 and i dont know how to transfer my video's on my PC. Where can I take the driver for my cam? PLS Help 10X
Unregistered guest |
| Posted on Sunday, December 11, 2005 - 01:27 pm: |
Hey! I have the same problem with my nvgs17, the software and cable where not included, please email me if you got any solutions on where to find the software/ legend_of_cavefish@hotmail |
I ain't no geek Unregistered guest |
| Posted on Friday, December 23, 2005 - 08:28 pm: |
I had the same problem and cured it. I can tell you what I did and hopefully it will help somebody else.I am no computer geek, I just don't know when to give up.This took me over an hour to work out. It worked for XP. First you need directx 9b or higher installed on your computer, you also need a 1394 firewire card which is designed for windows xp. Now we can begin---- Click Start On the menu click control panel Click performance and maintainance Click administrative tools Double click--Computer management On the left you should see Device manager Click Now on the right look for Network adapters mine has a green icon Double click It should open and display something like 1394 net adapter Double click You should now be at -- 1394 Net Adapter Properties General tab Should tell the maker of your card and if it is OCHI compliant Click --Driver tab This gives details on your drivers Click Update driver You can click No not this time--Next Click install software automatically--Next A torch should search tour computer for the best driver for your firewire card and install it Finish When you next connect your GS17 take a deep breath and hopefully like me you will now be able to operate the camera as you would like.You can use Windows Movie Maker or Nero. I personally use Nero. OK thats it ,all I can say is I hope it works for some of you and Merry Christmas and a Happy RECORDING New Year to all. P.S. If your 1394 card is not designed for windows then on the update wizard click Yes this time only, your computer should search the web for a driver GOOD LUCK!!!! Brian
