Home > Message Board > Photography > Camcorders > Archive through December 25, 2005 > HI-8MM to PC
Author Thread: HI-8MM to PC
Username: Vandiyan
Post Number: 8
I am looking to buy a Sony HI-8MM camcorder and was wondering how I would transfer the video from the camcorder to my PC so that I may burn it to a DVD. Would something like this item be all that I need? http://www.newegg.com/Product/Product.asp?Item=N82E16814144503
Thanks for all of your help.
Username: Vandiyan
Post Number: 9
I did not see an edit button so I am sorry for the double post. Since my previous post I have looked around a little more and have some more questions. I am now looking at 2 different camcorders. Here are the ones I am looking at.
Digital 8MM
http://www.bestbuy.com/site/olspage.jsp?skuId=6956537&type=product&productCatego ryId=cat04015&id=1099382961094
HI 8MM
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=ELEC&pid=0 0356007000&subcat=Camcorders
I am guessing that the Digital 8MM will let me connect directly to my PC with the included USB 2.0 cable. I can then just burn the video to a DVD right? Would I need any special software to do this other then my DVD burning software that I already have? If I can in fact connect the Digital 8MM to my PC I would think that this would be the best choice and cheaper in the long run. Do the Digital 8MM use regular 8MM tapes? Thanks again for the help. Also how much quicker would using the firewire be? I am guessing a lot. My PC does have firewire but I have yet to use it for anything.
Home > Message Board > Photography > Camcorders > Archive through December 25, 2005 > HI-8MM to PC [ « Previous ] [ Next » ]
