Home > Message Board > Photography > Camcorders > Archive through December 25, 2005 > Please explain this "MiniDV is easier...
Author Thread: Please explain this "MiniDV is easier to edit than DVD" thing.
The one thing I have been pulling hair out about was wether to get a DVD or a MiniDV cam, and although it seems less popular from the quality camp, I am going DVD for a host of reasons. The one thing I can't seem to figure out, and might make me consider MiniDV again, is this constant comment I hear about Mini DV being easier to edit. I don't get it. How long does it take to get the data to your PC, as that can't be faster than from a DVD drive. So what makes it easier to work with really? Please be specific as to what you find easier, or harder, about either format.....Thanks.
Compumavengal
The issue is file format - it saves in a .vob that is not recognized by many video editing programs. If you want to shoot in DVD the advantage is that you can place it in a DVD player.
But if you want to do any editing you first have to find a program that will accept .vob files
or you will need to find a software converter.
mToo DVD Ripper converts VOB/Mpeg2 to .avi - http://imtoo.com
MPEG Viedo Wizard - http://www.womble.com
VideoReDo, converts without decompression/recompression http://www.videoredo.com
If you are not a teckie this is a major pain. Until camcorder producers work that out stick with MiniDV.
Home > Message Board > Photography > Camcorders > Archive through December 25, 2005 > Please explain this "MiniDV is easier... [ « Previous ] [ Next » ]
