Thread: Help needed to capture miniDV tape (Panasonic camcorder) to VCD or DVD using USB cable |
New member Username: Yingtao
Brunei Darus...
Post Number: 1 Registered: Sep-05
| Posted on Monday, September 12, 2005 - 04:46 am: |
Hi, i'm trying to copy movies from my panasonic minidv to my pc then burn to a video cd using a usb cable. but i just found out that for a 120 mins tape, it will use up about 20GB!! how can i reduce it to fit into my pc and also a 800mb cd?? |
glennagreave Unregistered guest |
| Posted on Sunday, October 09, 2005 - 06:55 am: |
my advice is copy direct to a dvd recorder and then finalise to play on dvd players, much less hassle. |
AppleUser Unregistered guest |
| Posted on Wednesday, November 23, 2005 - 10:37 am: |
use firewire and some approprial video editing software ad you can set the compression rate so that you could fit the 120 mins on the CD but you would lose some quality. It is do-able tho. If you have a mac then it already has the appropriate software on it i.e. iMovie HD |
katelynn429 Unregistered guest |
| Posted on Saturday, December 24, 2005 - 11:55 pm: |
How do I get my video onto my PC? I have the software, like Movie Maker, but when I say capture nothing records. I don't know what I'm doing wrong. |
Post Number: 4570 Registered: Dec-03
| Posted on Sunday, December 25, 2005 - 12:15 am: |
How are you connected to the PC? Do you have an owner's manual? What camera? |
| Posted on Sunday, December 25, 2005 - 12:20 am: |
I have the Panasonic PV-GS31. I read the manual, it's useless. I've tried the video cables and the USB cable. I don't know what settings to put my camera on. |
