Home > Message Board > Photography > Webcams > Camcorder as Webcam?
Author Thread: Camcorder as Webcam?
Flash
How do you use a camcorder as a webcam? I have a Canon ZR-10 MiniDV camcorder and a Sony VIAO laptop (two years old).
You can use DVdriver software from http://www.trackercam.com
i have viao laptop and trying to use my sony dvd camcorder as a webcam. how can i achieve it?
Username: Murd
i have a Panasonic mini DV... NV-DS28 and am trying to se if i can run it as a we cam. It is connected to my pc via a firewire and for all intents and purposes works for anything but a web cam. would the above link work for all that aswell?? any help would be cool
Username: Project6
Post Number: 1081
yes
Username: Guleryuzo
I cant use my panasonic nv-gs15 as a webcam driver. When I install webcam driver windows xp home edition doesnt recognize it. is it useful to install xp professional. I tried everything please help.
hi everyone. I have a panasonic nv-gs15 and I didnt manage to install its webcam driver. it seems there is no problem during the installation but windows xp home edition doesnt accept it. I am obsessed on that. I ll be glad to your replys.
Hi I also have a panasonic nv-gs15, but running Windows 2000. The webcam driver is suppose to work on win XP service pack 1, does anyone know where to find a webcam driver for windows 2000 workstation. PLEASE!!!!!!:-(
Username: Guleryuzo
hi frustrated you are looking for a webcam driver for windows 2000 but nv-gs webcam doesn't work win. 2000. it only works with win xp. I think you cant find any driver for win 2000
I use xp and I have service pack 1 but I couldt even work it I dont know what to do
soky
Panasonic PV-GS12 Windows 2000 Pro
I have been looking EVERYWHERE... the advice in the second reply worked for me with a firewire connection and through Yahoo IM.
Just thought I would offer my comment in return for the great advice... thanks all.
http://DavidFrancis.us
lost my driver for panasonic nv-ds28. could anyone help me out to get a copy of the same?
Xplosion
I've got the same problem... need a driver 4 panasonic NV-DS28 and this topic was the only usefull thing I found. PLS anyone ! :-)
Username: Sapiputih
Hi,
I have a Sharp VL-SD20U MiniDV digital camcorder
(the model is about 3-4 years old) that I would like to use as a webcam on my computer. The camcorder has both a firewire (IEEE-1394) and an S-video connector. I read somewhere that using the S-video connection should work, but it seems that I would first need to install the camcorder on the PC. The problem is that the video (editing) software that came with the camcorder is for Windows 98, and my OS is Windows XP Pro. Sharp's website is no help in getting a driver that will work with Windows XP. And I haven't been able to find a driver anywhere else either.
Anyone have any thoughts on how to get this camcorder to work as a webcam in Windows XP?
Thanks
Amit
i have problems with installing the webcam driver for nv-gs-15 as it is compatible only with Windows xp, and I use Win-98. Is it possible to get the driver software for the same, compatible to Win-98? As I can see, many other users are also complaining of the driver software, even with Win xp! What's the way out?
Username: Drmalli29
hi every body recently i brought a panasonic gs-15 it has no function as a web cam it will be used to drag pics from memory card.the production people must rectify this. otherwise we the consumers have to file a suit on those people who cheated us priorly telling that this gs 15 can be used as a web cam.if u find any drivers which can rectify the above problem plese send me mail
Thanking you
Regards
Dr.Mallikarjun.
Username: Panawebcaman
Hiya, you need to uninstall the usb and wecam driver software. All you need is to set your camera to webcam under the usb device. Connect it to u'r PC and windows will pic it up. You need to run Windows XP SP1 though.
I bought a Panasonic NV Gs 15. I have tried desperately to download my recordings in the form of Video form the camera. The s/w provided with the DVC, allows us to only produce still photos while playing back the tape. I have also tried to connect the DVC as a web cam but it simply wont work.
What surprises me is that the model with the above features is being advertised and sold around the globe. But there seems to be very less support to resolve user problems.
If any one can HELP me with instructions to download Video and use the NV GS15 as a Web Cam please mail me at ruggs1@rediffmail.com.
Any help is appreciated.
anonryrtyryreyteryerj
A simple method is to get a TV card with S-Video input. I found the whole process of recording from miniDv and also using it as a webcam quite simple. It is my recommendation to get a V-gear TV card or similar.
Username: Ruggs
I have a Panasonic NV GS 15 DVC. I have tried to use the "Colour Night View" feature while recording in bad light. I noticed that the camera takes longer to focus on the object. While shootong still pictures it works well, but if we shoot a moving object like a "playing baby" or any similar thisn, the result obtained is blurd. Please let me know, if this feature works this way or am I using this in-correctly.
Hi HARRY.B,
last week i boght a same Sharp VL-SD20U MiniDV digital camcorder, i install miniDV300 IEEE1394 card on my old PIII 800 with its drivers and software but it can recognize the camcorder (windows Me), like y said Sharp's website is no help in getting a driver.
can you tell me how if it works with win98 then i w'll install it.
Thanks
Username: Benoyfr
Hi I have bought a camcorder Panasonic PV GS12. I needed to use it as a web CAM. The driver CD does not come with it. The driver CD comes free with a model PV GS 15. Can anybody help me in getting the driver ?
thanks in advance
hi everyone. I have a panasonic nv-gs12 and I didnt manage to install its webcam driver. it seems there is no problem during the installation but windows xp home edition doesnt accept it. I am obsessed on that. I ll be glad to your replys.
hi everyone. I have a panasonic pv-gs12 and I didnt manage to install its webcam driver. it seems there is no problem during the installation but windows xp home edition doesnt accept it. I am obsessed on that. I ll be glad to your replys.
HI I am Michal. I am from Slovakia. I have a panasonic nv-gs40 and I need software for USB driver (with webcamera). Where I find this software? Thaks Michal
Need Helppppp
hi a am trying to use a DV Camcorder with
Yahoo IM the camcorder is running through FireWire i know that windows works with it because i use it with MSN Messenger Yahoo Is not detecting the cam I Need HELP
ChadE
I have a Panasonic PV-GS200.. i install all the drivers... but when trying to use as a webcam.. i get about 3 secs of vid.. then i get blue screen of death.. and are forced to restart.. anyone know how i can fix??
rockman93@comcast.net
I own a panasonic pv-gs-12 digital vidieo camcorder. where do I go to down load some free software so I can load it to my computer. Jerome Bakshas
Hi, i bought a panasonic pv-gs12 and i think i have the same problem that everybody else, i can't find the webcam driver for this camcorder.
If somebody could send me the driver or tell me where i can download it i will be glad.
here I am with a pv_gs12 camcorder
I was given no driver with it and am in need of getting my filmage onto my windows xp running computer.
Anyone knows where I could get the said driver for this heap of shite item, could you please email me at the given address.
in waiting
jonowyn theaffection@gmail.com
liverpool United Kingdom
i got a sonydcr pc55 camcorder, how can i use it as a web cam
Hi
Its amazing to see that nobody has a solution for the problem of transporting Video from Panasonic NV-GS15 to a PC.
The CD that comes with the camera is useless for this purpose and is only geared for still pictures and webcam. If anyone has a solution please email me.
I've got a Panasonic NV-GS 11 camcorder. Everything is fine with except for the webcam function. The camera is set on "webcam", the USB cable is connected, and the USB Driver and Webcam Driver are both installed. I have gone onto Windows Messenger to use it but I only get a black screen. Do I need to use the Firewire connection? No Firewire cable was supplied with the camera. Please help
I had same problem with Panasonic NV-GS400. But! I just solved it!!!!!
On the Panasonics Driver-CD i found another driver and it worked!!!!!! Here is where I found it D:\USBDriver\Video\Drivers\Xp\WindowsXP-KB842787-x86-enu
There is 2 drivers, and the first one doesent work, but the second - did worked well.
Okay I'm totally new to this and I have a Sony Digital camera that I want to use as a webcam. I downloaded the DVdriver but how is this supposed to work? I am compentent but not well versed technically. :-)
Brian Hernandez
I am using a Canon GL1... want to use it as a webcam... but my difficulty is finding a good driver or app to allow the computer to see it as a webcam. I only have Firewire..no USB... All the drivers I've found so far are for XP only.. I am on a Mac, so I need a driver or app that's compatible with OS X. Thanks.
Username: Doctoriman
I have a Sony HandyCam CCD-TRV308 can I use it as a webcam? I would like to know if I can instead of bying a web cam.
I have a CCD-TRV308 Sony camcorder can I use it as a webcam...
Hi
I have Panasonic GS11. I downloaded all the software except the DV Studio 3.1E-SE.when i try to install this software it runs for a while then an error code comes up (error 0x80040303) and the installation is terminated. Please advice how can I rectify this problema and also please advice what otehr doftware I need to install to run all teh features og GS11.
camuser
I use my camcorder as a webcam with DVdriver
http://www.trackercam.com/TCamWeb/dvdriver.htm
They don't say there are any limitations .. it should work with any camcorder ....
dear sir, i have a panasonic nvgs11 camcoder ( digital video camera) Everything is fine with except for the webcam function. The camera is set on "webcam", the USB cable is connected, and the USB Driver and Webcam Driver are both installed.But when I start my web camera in windows messenger or yahoo messenger to use it, I only get a black screen. can u help me to solve my problem. i shall be grateful to u if u could solve my problem as early as possible )my e mail id is: dilip_anandk@yahoo.co.in).shall be awaiting for ur reply. thank u.
Where can I find drivers Panasonic NV-GS40 ?? Help me ,please...:-)
Jimmy88
I have just bought the panasonic NV-GS17 which has Webcam abilty and I have Windows Xp Pro Sp2.
I have the exact same problem as the person 2 posts above "dear sir, i have a panasonic nvgs11 camcoder...." EXCEPT i do not have ANY USB Driver or WEBCAM driver except the windows ones. I dont have them because it did not come with them.
PLEASE RESPOND! I WANT A WEBCAM! :D
Hi Guys,
I am trying to do some research with my NV-GS15 about moving VDOs to PC. Later i'll let you know about it in detail, here a link migh help you some: http://www.pcauthority.com.au/review.aspx?CIaRID=2247&CatID=36
I have a JVC camcorder and want to use it as a webcam. But I am not being able to with my PC. It gives me the following message: WELCOME TO THE FOUND NEW HARDWARE WIZARD. What should I do?
Please see attachment.
Username: Gigi2005
I have a Panasonic NV-GS17 camera and i don't know how to copy in my pc what i have registred with this
Anyone whao want to help me with answers my mail address is : xevious1001@gmail.com
i am trying to install sony dvdcamcorder to sony vaio laptop to work as web cam aint getting anywhere help please
hello sorry to bother you but my webcam is not working and i need it to but its because ive lost the cd to install it it was workig be for though until some one restarted the computer is there any way you can help me!! thanks write back .. mia x
Username: Project6
Post Number: 3859
mia,
what kind of webcam is it and what is your operating systme. Do you have any idea why the webcam failed?
Did you have to re-install the operating system(OS)?
I have used Trackercam usb driver and it works fine it works as web cam ,can be use to download minidv to hard disc(I have NV-GC17),but I wwant to know any other usb drivers are available on net which can be used,does the above softeare works for win98?
Hi, guys please tell me where i can find a diver for my Panasonic NV-GS 17 cam.it didn't come with the camera .
Thanx.
For those trying to use the Panasonic GS15 as a webcam, you have to tell the camera to act as a webcam (rather than for video editing). Press the MENU button, select CAMERA, USB FUNCTION and set it to WEB CAMERA. This worked for me, and I also had to use the USB cable rather than the DV cable.
Soky
"For those trying to use the Panasonic GS15 as a webcam, ..."
Actually, the GS15 comes with the drivers and software needed to make the model work. From page 47 of the technical manual; "PV-GS9/PV-GS12/PV-GS14 : Optional Software"
(Image removed from post but inserted on my webpage at http://www.davidfrancis.us )
Page 50 kind of spells it out, the camera does in fact work with MS Messenger without any additional drivers. As for Yahoo? eh no.
Since I posted here more than a year ago, I have to say that I am pleased with the camera but very disappointed with Panasonics support. I doubt I will buy another one.
This seems to be a very popular topic because I'm still getting traffic at my site from here... I wonder if Panasonic would bother to address this issue?
i have a panasonic gs17 i got told i can use it as a webcam but i have not got the software
kiril
Hi
I have a JVC D270, XP sp2, and I never had any problem in exporting video or recognizing the camera in windows.
I tried using it as webcam and, with MS Messenger, it works partially: I get video, but I can't use the cam mic. Until some days ago it showed an option in Messenger 7 wizard (I also tried 7.5), but after messing with alternative DV drivers, it disappearead.
I tried Orangeware's WebcamDV & DVDriver, but with no success.
Also, why does Messenger send outside a zoomed and cropped image?
Can someone help me?
Thanks
I have a Sony DCR DVD201e Hand ca (DVD Model)with USB streaming Please suggest how can I use it as a web cam.
m sears
I have a sony trv36 Hi8 camcorder, which i have used as a webcam. Hooking it up to the computer via the a/v calbes to a video capture device.
I am thinking of upgrading to a sony dvd dcrdvd403, would that work as a webcam???
i have a Sony handycam and it used to work as a webcam. now it looks like its solarized. The camcorder works fine recording and looking through when its hooked up to the computer but as soon as i turn on the cam through yahoo it does that. Can someone please help im goin nutts. ive tryed everything i could think of. thanks a bunch.. xoxo candi
Hello there.
Can someone tell me how to turn the web camera future on Panasonic NV-GS15?
Regards
Hello
I've got a Sony handycam (DCR-DVD201E) but no software/driver for using it with a Macintosh iMac G4 (MacOS X). Where to buy it ? Can anybody help with information?
hi i have a sony handycam (DCR-DVD203E) I cant use as a webcam, Can anybody help with information?
I need a Driver for my NV-GS17 miniDV.Send it in my mail.hubutm20@yahoo.com
I need a Driver for my panasonic miniDV NV-GS17. Send it in my e-mail:majid.s80@hotmail.com thanks.
Hi
I hv sony DCRA-C121 its one year, can i use that camcoder as webcom. and pc is having 2000 server edition
Thanks in advance
Hi! I need a Driver for my panasonic miniDV NV-GS17. It didn't come with the camera .Please send it in my e-mail: pnp@freemail.hu thanks.
Monique
A bit of info, for those who have a hi8 camcorder.
i have a sony trv38 hi8 camcorder. I connect it to a dazzle 85 external capture card with av...and use it as a webcam on both yahoo, and msn.
Ryan Delaney
Hey i have a Panasonic NV-GS17 and i need a driver for it. could u email it to me at delaneyryaneric@hotmail.com or send me a link where i could find one. thanks
Divemike
Has anyone had any experience or luck in using the Panasonic PV-GS150 as a webcam using yahoo. I am considering the purchase of this camera but want to make sure I can use it as a webcam. Any input would be greatly appreciated. Thank you.
Has anyone solved the panasonic nv-gs 17 problem with the black screen. We have the driver and all but it's still not working. Send email to nothinglikelife1@hotmail.com Thanks.
gear7
hello every1.. i need dv driver for my sharp vl-z500.please help me.
email me at x_gear7@yahoo.com
Username: Bombox
Hey i have a Panasonic NV-GS17 and i need a driver for it :-( could you email it to me at czarny_tandem@poczta.fm
:-( thanks
Username: Sammuhsoarus
i have no i dea how to hook up my samsung mini DV camcorder as a webcam caould you please take me threw the proceses? i have been tring to do this for 2 hours my e-mail is living_dead_girl456@hotmail.com
PANASONIC WEBCAM DRIVER!!!!! At last!!!!
Hi everyone, for your Panasonic GS15 to use as webcam download this driver. It works!!!!!!!!!!
http://www.panasonic.be/servlet/PB/menu/1042455_l6/index.html
Click on webcameradriver.....
ur camera.....Set USB FUNCTION to WEB CAMERA.
Unplug cam from PC!! Install driver..you need XP PRO SP1.
Restart PC and plug in USB cable. Will detect cam as webcam and done. Use Movie maker to check ur video screen.
Hello i need a driver for sharp camera vl z500,i want browse camera with computer, please help me,if anyone has a driver send me on e-mail thank you .The e-mail is dlugaric@net.hr
Hi i am having a Panasonic NV GS15 Handycam. I have lost my driver CD. Can anyone help me out to install my camera or can provide any type of help regarding software availability to me.
Username: Project6
Post Number: 5079
Try contacting panasonic.
red_dart
Hey, i have a JVC HDD video camera and im trying to hook it up as a webcam, but for some reason my computer is not reconizing it and i cant figure out what to do. can someone give me an idea what to do or a step i can take? thanks
Username: Project6
Post Number: 5198
JVC tech support.
Will Canon ZR200 do webcam(yahoo IM)? I seem to be missing something simple. It sees it I think, but says it is the wrong image size and won't let me change it anywhere that I can see(Not in superwebcam settings). :/
Thanks for any insight.
I have a sony 201E handycam, ive had the software and the laptop stolen that had the software installed on it. Can anyone point me to where i might find some free pixela software to download so that my new laptop recognises the camera?
Cheers
Username: Project6
Post Number: 5566
Contact Sony
I have a Halina DV3000 with a usb cable and both windows and apple computers. How can i set it up as a webcam? i would apperciate help emailed to Mpinhasi@gmail.com thanks!
porkorbeans
You can download drivers from this
http://www.panasonic.com/consumerdownloads
Username: Project6
Post Number: 6737
Drivers for what?
Username: Shmeeadiggle
i have a panasonic PV L353D, and i was wondinging if there was anyway to use it as a web cam. my friend tell me no way, but i rele wanna know if i can. if any1 can help ill be very greatful:-)
Username: Project6
Post Number: 7156
first connect it to your pc. If it gets recognized, you are in business.
Username: Wcliffperkins
Hooks, Tx
Usa
I need a driver for my Halina DV3000L camera
Any help wpould be appreciated
Hooks, Tx
Usa
Any help would be appreciated
graffixxs@gmail.com
Username: Tip
Hi
I have a Panasonic NV GS-47.
The camera works fine on a Dell Lat 610 running on Windows XP
The Camera however does not seem to agree with Windows 2000 (SP4)
1. While attempting to install in Tape Recording or Tape playback mode. Windows 2000 finds the new hardware as DVC. Not able to detect drivers and the device as to either skipped or disabled.
It is listed in Device Manager ->Other Devices->DVC
The drivers for this device are not installed. (Code 28)
2. The Camera works fine on PC Connection mode. The device is installed as Matshita DVC USB device and everything works fine.
3. The CD which came along as the MotionDV STUDIO 5.3E LE for DV, Video Stream Driver and USB device.
4. The Operating Instructions manual has the USb High speed and USB logo. So the issue "should" not be with USB 2.0 or related issues.
5. I am not looking at solutions which involve Fireware. The challenge is to get the camera to work in USB mode. It works fine on Windows XP.
Any suggestions??
Username: Tip
I used a software from Microsoft: "USB Device Viewer"
This is what I found
---===>Device Information<===---
English product name: "DVC"
ConnectionStatus:
Current Config Value: 0x00 -> Device Bus Speed: Full
Device Address: 0x03
Open Pipes: 0
*!*ERROR: No open pipes!
Username: Tip
I downloaded the drivers for "USB Driver (for Web Camera)" from http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&lan gId=-1&page=CamcorderDownloads
These drivers are for PV-GS36 and PV-GS39
I installed them for my NV GS47.
The DVC issue does not appear to anymore in the device manager.
However MotionDV STUDIO 5.3E LE for DV tells me that the Camera should be connected using USB 2.0.
I then installed a USB 2.0 card on my machine.
MotionDV STUDIO 5.3E LE for DV stills wants camera to be installed on USB 2.0
On the camera LCD "PC does not support USB 2.0"
I then installed Ulead MediaStudio Pro 8.0->Video Capture 8.0
Video Capture 8.0 detects my camera fine.
However Camera still says "PC does not support USB 2.0"
I have installed an Acer USB 2.0 PCI card (Displayed in Device Manager as ALI PCI to USB Open Host Controller)
Username: Vegeta
I recently bought a GS17 and want to use it as a webcam.
I connect the cam via a firewire cable.
After connecting the cam to my pc I startup MSN Messenger. When I go to the Audio and Vidio settings wizard, I can't select the GS17 as a microphone in step 2. But I can select the GS17 in step 3 as a cam.
Does somebody have a solution how I also can use the microphone of the GS17 in MSN Messenger?
My setup:
* MS Windows XP Home SP2
* MSN Messenger 7.5
* Panasonic GS17
* firewire
Already thanks for the time and trouble.
Greetings.
Username: Project6
Post Number: 9507
You will need to attach a separate microphone to the PC. The microphone will not be recognized by the program at all. Firewire will not accept raw unprocessed microphone input, just audio from a media source.
Username: Vegeta
So via firewire it isn't possible to use the mic.
Is it possible if I make the connection via USB?
Or is that also not possible?
Username: Project6
Post Number: 9510
No it is not.
I have used a camcorder as a webcam only by using firewire and a separate microphone attached to the PC's mic input. I hated it. Now I just use a regular webcam from logitech with a built in mic. A lot less hassle.
I have not used a USB connection with any camcorder, so I cannot comment on that.
Username: Project6
Post Number: 9511
Sorry Vegeta,
I hate that I cannot edit the posts.
More information, that I forgot to tell you. The only way for the microphone to work on the camcorder if being used as a webcam is to turn on the recording function of the camcorder. Otherwise it will not work, because the mic only turns on when the camcorder is shooting footage. I believe that you will get the same results with USB. You still need to get a separate microphone to connect to the PCs mic input.
Username: Ksprasad
can any please provide me the NVGS15 Drivers.or
the source where can i get
Plaese mail prasad_kol@yahoo.com
Username: Kmahone48
I have a Panasonic Pv-GS50 and need the Software to run it onto my computer. I believe that it is called DV-Studio 3.1E-SE. If anyone has information on where to get this software please e-mail me at korymahoney48@yahoo.com. Thanks
Username: Project6
Post Number: 10225
Have you contacted Panasonic?
Username: John_9rn
Can I use my MiniDV HandyCam DCR-HC22E PAL as a
WebCam with Yahoo.John
Username: Rubiagirl
Hi. I from Romania and I bought two years ago Panasonic cam- model PV-GS12. They told me it will work with my computer and I don't need the driver for video record. But no chance. I tried everywhere, I asked everybody but nobody can help me. Please. Is anybody who has the driver for this model?
my address is lavi19802003@yahoo.com
Thank you very much
Username: Megamanzo
Hello,
I recently purchased a Sony DV505 Camcorder. I want to use it as a Webcam, but noticed it does not have Firewire. Instead it has USB 2.0. I thought this was a "high end" Camcorder and I'm surprised it does not have Firewire. I want to use it as a Webcam and can't find any softwarre that works with USB. Everthing seems to require Firewire. Has anybody successfully converted a Camcorder to a Webcam using USB as opposed to Firewire?
Username: Mathewjones
Hi All,
I have Sony DCR-SR100 Camcoder , How should i use it as Webcam ? Please Advise !
Username: Project6
Post Number: 12847
Does it have a USB connection?
Username: Folusoji
Houston, Texas
I have Sony DCR-SR42 bought with the intention of using it also as a webcam. I found out that I could not use it. I have tried some third software driver, but the best I could get is blank screen. I use xp media center edition. Please I need help from any one who has solved this problem.
Username: Syfer1981
Hi I have a Sony handycam model no DCR - DVD201E
I was wondering if I can use it as web cam? If so please can someone point me in the right direction thanks :-)
Username: Project6
Post Number: 14600
Sony tech support.
Username: Tradestead123
Post Number: 10
Hi all , please help me i have sony laptop and trying to use my canon dvd camcorder as a webcam.Can any one tell me step by step how to achieve it! Thank you a lot!
Username: Ironman44
WE NEED TO USE OUR CANON VIXIA HF100 HD CAMCORDER AS WEBCAM WE ARE RUNNING WINDOWS VISTA BUSINESS ON A DELL PRECISION M6300 WORKSTATION DOES ANYONE KNOW WHAT SOFTWARE CAN MAKE THIS HAPPEN IM READY 2 BEAT MY HEAD AGGAINST A BRICK WALL WITH THIS THING ANY HELP WOULD B APPRECIATED THANKS BRYAN.
Username: Eatisa
Post Number: 13
i have never really tried it, i have sony cybershot 10MPX cam, can i use it as a web cam?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Photography > Webcams > Camcorder as Webcam? [ « Previous ] [ Next » ]
