Thread: Occasional olympus xd card trouble |
| Posted on Tuesday, August 30, 2005 - 08:55 pm: |
Hi, I've been having this problem lately. When I turn on my camera (olympus C-750 UZ) it would show "power off" or "format". Not all the time. I can sometimes make it work again by taking out the card and putting it back in. Sometimes while shooting the camera would hang while saving the picture. I don't suspect it's a corrupt XD card because it's new and would work fine before the occasional error and then work fine again. Sometimes when it asks to be formatted and when I do, the photos are still there on the card. Really need your help on this one. THanks |
Post Number: 3690 Registered: Dec-03
| Posted on Tuesday, August 30, 2005 - 09:14 pm: |
Try cleaning the contacts on the camera where you insert the memory card. Clean the contacts on your memory card as well. |
Unregistered guest |
| Posted on Wednesday, August 31, 2005 - 01:01 am: |
i cleaned the contacts of the card but how do you clean the contacts of the camera? |
New member Username: Caldera
Post Number: 2 Registered: Nov-05
| Posted on Wednesday, November 16, 2005 - 06:37 am: |
Caig DeOxit |
New member Username: Kaichandler
Post Number: 1 Registered: Nov-05
| Posted on Wednesday, November 16, 2005 - 05:32 pm: |
Did you manage to sort this? I have the same problem. thanks! |
| Posted on Wednesday, February 15, 2006 - 11:48 pm: |
I have this problem lately. When I turn on my camera (olympus Camedia X-200) it shows "power off" or "format". I am not able to see pictures or save them in PC. How can it will be solved? Should I formt? wht will happen to pictures? |
Post Number: 5838 Registered: Dec-03
| Posted on Wednesday, February 15, 2006 - 11:55 pm: |
Any file stored in the card will be erased once you format the card. |
