Thread: Which is the Best MiniDV |
Venkat#123 Unregistered guest |
| Posted on Sunday, July 10, 2005 - 12:54 am: |
Hi Guys, First of all thanks to all. This is a great forum. I am planning to buy a MiniDv in the range of ($450 to $550). Could someone suggest which is best to go? Please suggest some make and model numbers. Also one more question. I have been going through some threads related to NTSC and PAL. Can someone tell me which will have good quality : NTSC to PAL or PAL to NTSC? Thanks in advance Venkat |
| Posted on Monday, July 11, 2005 - 07:58 pm: |
Hi Guys, No Replies?
Silver Member Username: Gromit
Post Number: 408 Registered: Mar-05
| Posted on Monday, July 11, 2005 - 09:01 pm: |
Venkat, You can find consumer reviews of camcorders here: http://search.ecoustics.com/Consumer/Reviews/Camcorder/ Regarding PAL to NTSC or vice versa, I have only attempted NTSC to PAL, via a format-converting VCR from Aiwa. It worked better than I expected. Cheers. |
New member Username: Satish
Chennai,
Tn
India
Post Number: 1 Registered: Oct-05
| Posted on Saturday, October 08, 2005 - 03:23 pm: |
Iam planning to buy elura90 from u.s and i will be using in india,iam having multi system t.v. will i have any type of problem with that camcorder, for converting the capured image to vcd will there any problem or will the image will be disturbed. kindly tell immediately. Satishkumar |
