Home > Message Board > Photography > Digital Cameras > Sony Cybershot P92
Closed Closed: New threads not accepted on this page
  Thread Last Poster Posts Pages Last Post
Archive through June 29, 2005Berny100 2005-06-29  07:40 ET
Author Thread: Sony Cybershot P92
sally smith
Thank you :-)
Relevant Product Info
sally smith
do you have any idea how much that would cost?
Username: Project6
Post Number: 3220
I have seen it cost as much as a replacement camera. Not really worth the trouble unless it is under warranty. They still charge you just for them to look at it.
Mitch-Man
Sally - I also would not recommend the “Fonz” approach to fixing the camera, but it works. I posted a question a while ago and got only sarcasm from Berny about a Jeffre fellow. As it turns out, I can fix my camera by just tapping the side – and it works fine. It may not help you, but for me it is cheaper than buying a new one (as Berny suggested long ago).
sally s
thanks
sally s
do you have any idea whats causing this problem
sander
a problem with the lens causes an error
Username: Laney02
I have a sony DSC-P73, and it has worked fine. However, I am getting a C13:01 error, which i know is a format error. I would just reformat and move on, but there are photos on the card that i would like to keep. Is there anyway to recover those?? Please help!!
kimberley
how to reformat the memory stick? my camera is a sony cyber-shot 5 megapixel. 3x optical zoom. it is showing 'format error' too. i'm wondering how to reformat the memory stick as you've suggested to a person above?
Corrine
I have a Sony Cybershot and sometimes when I turn it one I will get a "No Memory Stick" message even though there is a memory stick in it...other times it works fine...any ideas?
Username: Project6
Post Number: 3235
Elaine,
Try this http://www.datarescue.com/photorescue/
Kimberly,
Check the manual, it should tell you how to format the memory stick. It is usually under the main menu.
Corrine,
Check the contact points of the memory stick, sometimes it gets dirty and will not be detected by the camera.
Username: Chazzadd88
Hull, East Yorkshire
England
i have a sony cyber-shot camera (DSC-P32)-- everytime i upload pictures onto my computer, each picture uploads twice- a smaller version and the fullsize version... this is nothing to do with my computer because i know my friend altered something on my camera-- any ideas how to change the settings and put it right because it is using up too much memory space!!
--chazza
I have a sony cybershot camera. it works fine. recently we bought a new memory stick 128MB and used it. a couple of days back when i tried to turn it on, it came on and went off again. when i put the old 16MB card instead it worked fine. any idea whats going on with the new mem stick?
Jo123322
I lost my install disk and have recently built a new computer. I'd transfer the install files from the old comp, but I don't have the old comp available and I want to use my camera NOW. Is there site offering a free version of the software or method in which I can download the pictures from my camera to my PC without the software? Thank you VERY MUCH for the help.
Dee W
Haven't used my Sony DCS P92 for amonth or so, went to use today and screen is blank. Has batteries and power and does take pictures but you can only see them after the picture is taken - any quick fixes or links you can suggest. Thanks
Username: Project6
Post Number: 3277
go to your set up menu and look at the monitor options. Sometimes it is set for review only. Check your manual for more details.
martinp89
can a Cybershot DSC P93 be used as a webcam
madhva
i had a sony P73 digi cam and i hd lost the software cd and do i have any way to get in download through internet
I have a Sony Cybershot DSC P 93 camera. Yesterday, when i was taking pictures, it suddenly turned off. I tried reinserting the batteries. after 3-4 tries, Camera was on and it asked to set the date and time. Then after taking 2 snaps, it turned off as before. Now the power is not turining on. Any clues ? Is it the problem of battery wearing out ?
Username: Jad
To Anoynymous
Have you tried changing the batteries if not do so i have a cybershot that does that same thing.
try taking some pics after that see if it works.
once you have done that send me an email to jadthebad@gmail.com
Susannnnn
I have a Sony DSC - P92
How do I use it as a web cam??
I have bought a CPC refurbished Sony DSC P93 on 20 August 2005. And it is 25 August 2005 now. When I was trying to transfer the pictures from the camera to the computer the USB driver gave me some problem. So I removed the USB cable wire. And the lens extended out. And when i switched it off the lens didnt retract back. Now if I switch the camera on the lens retracts back and immediately the camera is switched off and the lens extends. this problem is really annoying to me now.
What might be the problem. Do I have to get a replacement for the camera ?
epicura
Another thing I have to add,
Yesterday while taking the pictures in the hot afternoon, it automatically switched off. This happened for a while when i was taking the pictures of the wall street bull... Evening it was working fine without any troubles. Today afternooon also it worked fine.. till i tried uploading the pictures to the computer.
Steve Wong
I have a 3.2Mp Cybershot-P8. It was working fine until 2 days ago. When I turn the camera on, the lens would extend out and the lens cover would open fine. But I see nothing (pure darkness) on the LCD screen. Thinking the LCD may be broken, I took a few pics and downloaded to my PC and the pics were pitch black. What could be wrong?
Username: Project6
Post Number: 3621
Could it be that your camera is broken?
Send it in for service.
If it does not work the way it was designed to do is usually a give away that the unit is broken.
Those Sony point-and-shoots are not made to last forever. 2 years and sometimes 6 months or shorter, something new, almost better and cheaper always comes along.
Sad with Cybershot
I bought my cybershot 8 months ago and recently have had two spots appear consistently in the same places on all my digital pictures. I have cleaned the lens but the spots remain. How do fix this problem? Is this due to moisture that dried on the inside of the lens or dust? Thanks!
Username: Project6
Post Number: 3658
Could be both. Could be dusty moisture that dried inside the lens. Send it in for service if it is still under warranty.
If someone knows the way to use my Cybershot Dsc-P93 as a webcam could send me an e-mail to this e-Address?
Thanks
Volker
My daughter has changed the recharchable batteries in my dsc p71 to normal ones, it worked for a couple of days, now the camera wont turn on anymore. Is it broken, can I do something about it? Thanks.
Volker
My daughter has changed the recharchable batteries in my dsc p71 to normal ones, it worked for a couple of days, now the camera wont turn on anymore, even with recharchable ones. Is it broken or can I do something about it? Thanks.
Volker
My daughter replaced the recharchable batteries in my dsc p71 with normal ones, it worked for a couple of days, now the camera wont turn on anymore, not even with recharchables. Do you have any idea what I can do?
Username: Project6
Post Number: 3855
Have you tried fresh batteries and is the camera designed to take in normal batteries?
umm i took pictures on my camera and it went to internal memory..is there anyway i can get it from internal memory to my momery card,so i can put the pictures on my computer?
My digital camera is a...
Kodak CX7330
Firmware Version 1.0000
Username: Project6
Post Number: 3966
This is Sony thread, you really should not be hijacking. Start your own.
Let me re-iterate
You can transfer the pictures from your camera by using the usb cable provided with your camera. There is als a thing that came with it. It is usually called an owner's manual. It really helps out if you actually use it
Annaesor
Hi, I have a Sony Cyber-shot 5 Mega Pixel DSC-P92 digital camera and up 'til about a week ago, it was working fine. At first I was using it and then after a while it started going crazy. It turns on by itself and makes a strange beeping noise for a while and then stays on until ready to shut back off, where it turns right back on again. Also, E:92:00 flashes on the screen and I can't take or delete pictures anymore. None of the buttons work. What's up with it? Do I need a new one or is there a way I can fix this? Thanks, any help is appreciated.
Username: Project6
Post Number: 4054
Check the contacts on your battery terminals and memory card. The contacts are probably dirty. You may need to clean it.
Username: Samio
I have a sony DSC F707 that works great .. however the LCD went blank on me ... the view finder still works fine and I can see the photos but I sure would like to get the LCD to work again ... when I turn it on I just see a white blank screen. Have anybody seen this issue before ... can anyone help guide me to the solution please. thanks.
Username: Project6
Post Number: 4057
Blank as in white or completely dark?
Username: Samio
Blank as in white. I hope this helps.
Have had the camera (Cyber-shot DSC-P72) for a few years and not had any problems with it until today. When I try to take pictures or movies the LCD screen is blank and blips different colored lines and I get no image what-so-ever. Even if I do take a picture, it comes out the same. Here's an example of a picture I took with it: http://img344.imageshack.us/img344/7953/dsc010341po.jpg. I've tried everything from changing batteries and memorie chips, to resetting the camera. Can anyone help? Thanks.
I have been using the camera (Cyber-shot DSC-P92) for three months and not had any problems with it until last week. When I try to take pictures or movies the LCD screen goes blank and shows different colored running lines or rather areas randomly and I get no image what-so-ever. Even if I do take a picture, it comes out the same. Can anyone help? Thanks. Everything else semms to be working.
I would like to remove the cover and see things for my self. Because I bought it in Hong KOng but live in Sri Lanka. Can anyone tell me how?
For all of you that have "Turn the power off and on again", here is what I found.
There is a motor assembly that is part of the lens assembly in the camera. Inside this motor assembly there are a few custom gears that are hard to find. When a gear gets damaged, the camera is able to detect the motor spinning and monitor that the lens is not moving. This causes that error message to display on the screen.
Depending on the extent of the damage of the gear and which gear broke (their are two typical ones, which are replaceable), some users may be able to get passed this occasionally. This can occur if only 1 tooth of the gear is broke. Eventually the teeth next to the broken tooth will break because of how the gears are connected to each other. This usually can be noticed by a grinding noise when you turn on the camera. If all you hear is a motor humming, then one of the gears is damaged as well.
Unfortunately, the fix depends on how the gears where damaged. If the gears were damaged because the camera was dropped on its lens, it could be possible that the lens itself is now crooked and even replacing the gears will not fix the problem (the lens will physically get stuck and redamage the replacement gears). If the gears broke over normal use (which is what happen to me), they can be replaced and all should work again.
Any questions, e-mail me at sony@fewin.com
Username: Sawlenas
Hello,
if anyone needs two specific gears for the Sony DSC-P92/72 i am selling those on ebay. i have fixed couple cameras, which had the same problem - these two gears.
so if you are looking for the gears, please go to ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D7557952981%26&sspagename= STRK%3AMESE%3AIT%26
or you can contact me if you want to buy them directly.
cia.saulius@gmail.com
Thank you
K. Reid
I have the SonyDSC P92 5 MP camera and it seems to have a 5 to 10 second shutter delay between shots. Is there any way that I can modify this so that I can shoot one quick shot after another?
Username: Project6
Post Number: 4183
try the sports mode if you have it. Use a faster shutter speed. Check the manual.
Louisa
My Sony DSC-P100 got a little wet. The power won't stay turned off. Is it repairable?
myko
hi i have a Sony DSC-P32. alrite i turn on my camera and the buttons are like all messed up. my delete button does not work, and the left n right buttons dont even move from picture to picture. any suggestions how to fix this?
Username: Project6
Post Number: 4264
Louisa,
Anything electronic that gets wet will inevitably suffer some sort of damage. Wait until it dries out before doing anything else. Give it a few days, and if it still malfunctioning, then send it in for repair. But it is not worth repairing.
Myko,
Even if a camera technician tells you how to fix it, do you have the technical know how to do so? Are you hoping for a series of buttons to push to make it work? If there is such a button, usually called a facory reset, you have to consult your manual. But if it is a chipset problem you have to send it in for repair.
I am in need of a replacement software disk for my Sony DSC P93. Sony wants to charge an arm and a leg for the software.
Can anyone help me out with suggestions?
Username: Project6
Post Number: 4320
I say pay the arm and the leg, unless you can borrow the software from somebody else.
Did you want Sony to get you one for free?
Etryus
Please help me! i bought a month ago a cybershot p200 and yesterday i bought a memory stick pro 1gb,first time i inserted the mem stick everything was ok,i took a pic to try, then i erased the pic and shut down the digital cam, later i switch it on and i get "format error c:13:c01", i had to try formating the mem card 3 times before it could work again.and now everytime i format the card i have this error and i have to try formating the card 2-3-4 times before it becomes functionnal again, what's wrong with it?please anyone can help?it's so annoying not to be able to enjoy a cam you paid alot of money for. Thanks everyone.
Username: Project6
Post Number: 4321
Return it and get a new one. A product should work the waay it was designed to do. If it doesn't return the defective product and get a new one. It should still be under warranty. Call Sony and see what they can do for you.
Okay, I have a problem. When I turn on my camera the screen shows only red and the image is blurred. I tired changing the settings, but that wasn't what was wrong with it. I don't know what to do.
ex.
[IMG]http://img.photobucket.com/albums/v318/AlliHearts/DSC02917.jpg[/IMG]
allihearts
I'm in such a state I forgot about the model Song Cybershot DSC-P92
Username: Project6
Post Number: 4340
The camera is broken. Replace it.
There are no magic sequence of buttons that can fix it.
Even if there is a technical fix from a well meaning Sony technician on this board will you have the skill to fix it yourself? How are you going to get the parts?
Hi Berny,
This may be a problem you've seen before. Before I throw the camera out, would appreciate your advice. This is a DSC-F717 bought in Nov 2002. It worked fine for 2 years, now I get the "C:13:01 Memory stick Error". I changed different memory sticks and was told it may be a circuit problem. Is there any software upgrade that can fix this? Any help would be appreciated, as I bought this for over $800 and hate to just discard it.
Username: Project6
Post Number: 4373
go here
http://www.pechorin.com/m/2003/07/12/SONY_C1301_ERROR-202719-24.html
Yeah...i have a problem with my sony dsc-p92 when i choose the "take picture" mode there is a major clicking sound inside the camera and the lenses sometimes open and sometimes dont.I am aware that my camera is broken(DUH!!! im not dumb!)
so i sent it in but the warranty has expired and i think it has something to do with the gears inside the camera that make the lenses go up and down...Should i screw my camera open and try to fix the problem manually???
To help me a blueprint of the camera's inside would be great!..
Please help...Thanks Simon From turkey
Username: Project6
Post Number: 4385
Good luck trying to find a blue print.
Sony is not known to publish blueprints or send them out to every request. They like to keep their proprietary items to themselves.
You could try to fix it yourself since it is no longer under warranty. You have nothing to lose!
atul kulkarni
Hi
I have got a Sony Cybershot P 92, about 2 yrs old. When I put it on, it goes off automatically in a few seconds. how do I solve this problem?
Username: Project6
Post Number: 4446
