Home > Message Board > Photography > Digital Cameras > Sony Cybershot Memory stick issue
Author Thread: Sony Cybershot Memory stick issue
I have the Sony 5.0 megapixel cybershot. Everytime I have a memory stick (I have three of them) in there, it only lets me take one picture and then says, NO MEMORY SPACE, which isn't true! And it does this with all three sticks and I know they're empty. Any ideas about what's going on? Can it be fixed? It was fine for the longest time and then this just suddenly started happening.
Username: Project6
Post Number: 3193
Are you sure it is using the memory of the stick or is it the camera's internal memory?
Hmm... I'm not sure I even knew my camera HAD an internal memory thing? How do I check that? As far as I know, it's the sticks. And they used to work fine. Then suddenly -- poof -- they stopped. Thanks so much for answering!
Yakup
I had have the same problem. On the display of my Sony DSC-P52 was the message "NO MEMORY SPACE". After formatting the memory stick the message was gone.
The DSC-P52 has an option to format, I don't know if your camera has it too.
Thanks! That did the trick. Really, really appreciate it!
Hi
Well Sir i have a question for u ... i have Sony Cyber-Shot Camera (2.0 mega pixels)... last month i had this problem with its memory stick ... it displays a message "Memory Stick Error" ... i am all confused what to do ... so can u please help me out or suggest something ... waiting for your reply
Thank U!!!!
in memory stick pro 512MB photos automatically gets deleted
i m using sony dsc s60
photos gets deleted when i switch off the camera
not all photos gets deleted, only few
I also have Sony Cyber-Shot Camera (2.0 mega pixels). After removing all of the photo's off of the memory stick via my computer I get a error that says " No Memory Space" and "no file" I guess that I must have deleted a important file off of the memory card?.
Username: Project6
Post Number: 4303
Try reformatting the card by using the camera.
prahadan
Hi there, I have just got a Sony DSC-T1, with 1GB PRO DUO HIGH SPEED memory card. I format the card with the camera, then try to record video on 640FINE setting (which should give about 13 minutes of video). After 6 minutes, the camera announces that the buffer is full, and after that if I try to take pictures or do anything, I just get a flashing file error or file formatting error. Can anyone help with this issue? DO you think updating the firmware might help?
Thanks, Dan
Username: Easyluckyfree
Post Number: 9
if you can plug in your memory stick in your computer without using your camera, either through a port on the computer itself or through a driver, you should be able to open up the memory stick folder and see everything saved on it. that happened with a memory stick i was dealing with. i took a picture and it said it was full. i plugged it in and in the folder there were a bunch of leftover crap on it. that's probably the problem with your memory stick.
Username: Dreamomara
I have 2 sony memory sticks with around 50 pics each and on my camara i can see them but when i put the memory sticks in to the scan disk thingy thing nothing comes up at all. I do have a third stick and it works just fine.....i need major help i have some of my wedding pics on it and i want them...
Username: Lith1um
Sydney, NSW
Australia
i have a Sony Cyber-Shot U DSC-U30, & i have a problem with this camera. i've been using it for some time now and it's been perfect but then all of a sudden when i take pictures or record, the image is pitch black. the screen is pitch black, i cannot see anything. i have tried taking a picture but the result comes out the same, it is pitch black, what should i do to fix this problem?
Username: Lakemama
Many, La
Usa
i need help unlocking a memory stick! one of my kids must have locked it by accident and i have no manual. how do i unprotect it?
Username: Project6
Post Number: 8409
Look for a protection tab on the stick itself.
Username: Lakemama
Many, La
Usa
ok, berny the protection tab only protects, i don't see how it'll un-protect.
Username: Lakemama
Many, La
Usa
Post Number: 7
no sorry i didn't read your response correctly, my husband was harassing me for other stuff. sorry again. didn't mean to be rude. i did find that tab u talked about and thanks for the help.
Username: Project6
Post Number: 8412
it happens.
Username: Roger3125
WEll Thank God I have found a group that talks about my Cyber-Shot and better understands it.
I know this sounds dumb BUT how do you clear a memroy stick of all the pics on it. I used to have a program that would automaticallyh saved the pics to my harddrive and then give me the option to delete all pics from the card.
New PC with same camera and don't recall what program it was nor how to delete the pics from a memory stick.
Can someone help...and thank you all for being here
Username: Lakemama
Many, La
Usa
Post Number: 8
hey roger, while the memory stick is in your camera, you can choose the settings tab and format the stick and that will erase all the stuff on the memory card. or if you have the memory stick hooked up to your pc and your pc reads the pic on like drive "e" or "f", you can use the windows explorer function and click on that particuar drive where the memory stick is and format it there or erase the stuff there too.don't feel stupid, i ask all sorts of questions, that's why we have to hang out together her............diana
Username: Mrapp
my cybershot DSC-P92 does not recognize the memory card. everytime I turn it on the camera says no memorystick. I bought a knew memory stick and it still doesn't work.
Username: Bookwormbry
another memory stick problem...
i have a sony cybershot p93A, about a year and a half old. it was working great, but just recently i've had problems with it and my sandisk 1 GB memory stick pro. i take pictures, can see them in preview mode on the camera, then go to upload it with my card reader or the USB cable (i've tried both ways) and nothing. the photos are magically gone. i can get them back with photorescue, sometimes. but anyone know why my pictures aren't being captured right? i checked for firmware updates on sony's website, but couldn't find any.
Username: Project6
Post Number: 8777
Format it using the camera.
already done - i format it every time i empty all the pictures off.
Username: Project6
Post Number: 8798
Try a different memory card to isolate the problem.
Username: Kjoywalk
I have a sony cyber-shot 5.1. My computer will not read what is on the momory stick. The stick was recently formated and only has 15-20 pictures on it. It will read what is on the internal memory. I may have gotten sand inside the camera. Any suggestions?
Username: Tajs_mom
Honolulu, HI
I keep getting a "memory stick error" c:13:01 how do I fix it? When I tried to format it, it came back with the same error. I recently downloaded the pictures then deleted the files from the memory stick with my computer. Anyone know how I can get past this one?
Username: Tstyoung
Los Angeles, CA
I have a silly question to ask. If I deleted a picture on my camera. Is there a way to go back and retrieve it?
Username: Project6
Post Number: 8870
Yes, but not by any conventional means.
Username: Crzee_4_bk
Brooklyn, New york
United states
on my sony dsc-p9 camera evrything works fine except the memory i tried taking pic but its still says no memory card..the card in there is a 128 mb card..i tried connecting the camera to the cpu but it doesnt read it..what do i do? take it to a specialist?
Username: Lilazngurl931
Can u delete pictures on a memory stick duo? because my owners guide said u can ... i think i wasn't sure so can u?
Username: Project6
Post Number: 9281
Yes you can. Format the memory stick using the camera.
Username: Roger3125
Orange County,, Orange
Just timing in to say thanks to Diana for answering my question.
Now onto question 2: I referred earlier to a program I used to have my late PC. I was neat...I'd pop the memory stick in and it would show thumb pics of all the pics on the strick and you could hit "All" or just some to save but what was really neat was it gave you the option to erase evrything after downloading.
It was a wonderful program and now can't for the life of me remember what it was. Anyone have an idea?
how do u format the memory stick on the camera? will it mess up the camera or do anything weird 2 the camera...??
Username: Project6
Post Number: 9559
You go to the menu and it will have an option to format the mempry card or read the instruction manual. It will not mess up the camera, it was designed to set up the memory card for use in the camera and delete all the pictures.
Username: Eureka
ERROR c:13:01
For those of u who encountered this error. I have a sony dscf505 2.1 MP camera. As I was attempting to enter a memory stick duo adapter in the camera I slightly felt a resistance that should have send a message to my brain to stop imediatly. But as adventures as I am I gave it an extra push. The next thing I read on the screen was a "memory stick error" with the code "c:13:01" . That did'nt work was my first reaction. So I put my regular stick in of 64 mb, yet to my surprise the error stayed. Did I reck the the thing I said to myself. I checked the Mstick on my laptop and it worked just fine. So it had to be the camera. So I started my investigation( remember adventures type) formatting was im[possible sinds I could'nt get acces to it, trying other Msticks gave the same error. Then I checked my slot on the camera. It's a bit tricky to see but there are about 10 pins that connect to the MemoryStick once u push it in and it locks in place. One of those pins was bent. I had a gut feeling that this could be the problem I was encountering. Sinds adjusting the pin with something small from inside the slot did'nt help I was forced to open up the camera. It's very tricky to unmount the tiny cables and flatcables but after a bit of fidling I got to the slot and I couldt see on the outside of the slot that one pin was indeed bent all the way out of the slot. Gently pushed it back into place as best as I could. Again very fidly parts to put back together. If ur not up to this fidly thing PLEASE DONT SART UNSCREWING UR CAMERA. Take it to a shop where people know what they are doing. So after have put it all back together and srewed al of its tiny screws back in. I tried my regular Memorystick of 64MB again. It looked as it was going to jam, but carefully I got it into place. Guess what....eureka the camera was working fine again.
But think twice before u want to open up your camera, because everything is so tiny an fidly to take apart let alone to put it all back together.
Eray
Username: Ronaldaroo
Have a DSC S600 and Memory Stick PRO Duo 512Mb and can download photos onto the computer.How can I upload photos from the computer to the memory stick.
Thanking you in antipation for your help.
Ronald John Saunders
Username: Project6
Post Number: 10165
The easiest way is to get a memory card reader. This will enable you to use your memory card as a storage device as well.
Username: Armywife97
I have a Sony memory stick duo 1GB and I have a card reader that I usually use in it, but lately the card reader won't read the memory stick. I can see the pictures just fine in the camera preview screen, but I can't get them onto my computer. Any suggestions?
Username: Project6
Post Number: 10267
Check the connection between your card reader and your PC. Also check the protection tab on your memory stick.
Username: Aznable
Hi, Ive read this entire thread and Ive got the A la Carte of problems here.. and by the way Thanks IN ADVANCE if you read this.. and A Million thanks if you got a clue how to help me out on this one..
I do get the Error 13:01c message, but the good news is that Ive ruled out my camera, with the help of another camer and mem stick.
The Problem: Ive got nearly 200 photos on a SONY Memory Stick PRO Duo 1GB using a Memory Stick Duo Adaptor (MSAC-M2)(stick made by MagicGate?)
Once I got home from classes my internal Memstick drive wouldnt read any more than the first 5 pics.. so I thought It was probably the Comp's Drive acting up. I then used two different USB / Mem Stick Adaptors to try to retreive all the pix off the stick.. with No luck. On a side note, before the third Adapter I was still able to read the pix on the camera, and couldnt transfer the pix into another folder.. but could take and retrieve test pix off a 2nd newly made folder (in the camera).. Then after trying the 3rd USB / Memstick Addapter .. the whole Stick Failed, 1301c error in the cam and now Nothing Reads it..
What are my Options?? Is this stick kaput? is there still any way to get anything to read this? or Should I be looking for my reciept?
Thank you
Username: Bill_mc
Rockledge, FL
I have a Sony TV, I bought a 1G Sonyscan disk pro memory stick. I have a friend who has a Sony Cyber Shot camera but it will not format the pro stick. I can read the stick and copy pictures to it but it won't work in my TV. Is there software available that will allow me to format the pro stick?
Username: Roger3125
To answer my own question about what is the best and esiest application to make Memory Albums with pics, movie clips and music of your choice hands down it is Windows Movie Maker. I've invested hours over a period of 6 months and many hundreds of dollars trying them all. Windows MM is best of all and if you look on your PC--> Programs more than likely it came on your PC as a freebie.
If you need help email me I'm almost a pro at it after using it for a few hours.
Username: Roger3125
I have a problem or rather a question about my CyberShot DSC-W5. I've been told by SONY that all Sony digitals work basicly the same so a solution for one model applies to others as well.
Can someone tell me how initialize the camera?
Thank you
Username: Nomi97
Hi,
I am a newbie to this forum, great to see a forum like this.
I have a sony dsc w100 and i bought a genuine sony 1gb pro duo. I can take photos with no drama, but when i put the stick in the genuine adaptor and plug it in my card reader and plug it in my laptop, it will recognise the removable drive but when i click to browse it will wont open saying "insert disk". But when connect my camera directly it will browse all pics with no issues.
I also took my stick to the photo processing shop and when i plug stick in the machine again it wont recognise.
I have formatted it prior to using it.
Please help
Regards
Nomi
Username: Mpgabor7
I just took a bunch of photos of my niece's play for my sister. I have a Sony DSC-H1 and use a Sony Memory Stick Pro Duo. I got home and over 3/4 of the photos show an error message: file error. I've tried downloading Sony's Memory Stick File Rescue from Sony and it only recovers the files that I was already able to upload to my computer. If I don't recover these, my sister will be SOOo upset! Can somebody help?
Username: Nano602
I was having the same problem with my 4GB memory stick pro duo, when i took more than 50 pictures with my camera (dsc-w90) i would get the blue screen with the file error message. I'm guessing you guys bought the memory stick on ebay right? I bought mines there and it turns out it's a fake one. If you also bought it there then you most likely have a fake memory stick because I found out that most of the memory sticks sold on ebay are fake, to help you figure out if you have a fake one or not check out this guide or google fake memory stick pro duo.
http://reviews.ebay.com/FAKE-Sony-Memory-Stick-Pro-Duo-MagicGate-Cards-Exposed_W 0QQugidZ10000000001236041
Username: Chappy675
I have a Lexar 128mb memory stick and my LIFE is on it. Suddenly when I try to view the photos using my scan disc stick reader OR my cybershot camera through a USB, the photos look fine in the thumbnail previews but when I click on a photo to open it they are scrambled. Some photos show the top of one photo and the bottom of another photo. Several photos only display the top 1/3 to 1/2 and the bottom part is just gray. As I said, they all look fine in the previews. I have tried opening with 3 different progams and it's the same. HELP!!
Username: Snkmom
I have a sony cyber shot dsc-p10. We just went to disney and i have over 300pics on a san disk 1.0gb memory stick. I went to look at my pics and got the c13:01 memory error. I had no problem taking any of the pictures while I was there. Please tell me there is a way to get my vacation pics back! I have tried other sticks in the camera and they work fine. I don't know what to do.
Thanks to anyone who can help!!!
Username: Mpgabor7
Regarding posts by: Chappy675 and Snkmom, I hope it's not the same thing that happened to me. In my case it turned out to be an issue with a memory stick bought off of eBay that ABSOLUTELY looked identical to my "real" Sony memory stick. Sony and recovery software was unable to retrieve any of my photos. I hope you all have better luck with yours.
Username: Margisteve
Hi I have a DSC-T30. I am using a 4GB memory stick I can't remember how to transfer photos from camera to stick help can't take any more pics.............
Username: Minnieb
I have a sony cybershot 7.2 megapixel digital camera. I recently purchased a 1gb high speed memory stick pro with adaptor from overstock.com. The camera worked wonderfully with the new memory stick. I went on vacation and took about 150 pics with no problem. On the last night of vacation in the middle of snapping away, the camera stopped working. It said access accross the screen and wouldn't allow me to take pics nor see the pics I had taken. I tried to turn the dial to different settings and it cont to say access. Upon returning home I put a different memory stick in and it allowed me to take pics and view pics on that memory stick. I have put the memory stick in printers to at least try to print the pics from my beautiful caribbean vacation but nothing comes up on the screen. I have put the memory stick in other cameras and it cont to say access across the screen. Any help is appreciated with this very frusterating experience.
Username: Chappy675
I can tell you from experience... your photos are lost. The files on the stick have become corrupt and you will have to format the stick (a function that you perform using the camera with the stick installed - follow set up instructions). When you do that you will be able to use your stick again, but your files on the stick now (ie: your photos) will be wiped clean.
Not sure what caused this. The same thing happened to me. Some say buying memory sticks on Ebay, Overstock.com and other sources where the legitimacy of the sticks may be questioned, is the cause. I bought mine from Circuit City so there goes that idea. A word to the wise... always format the stick before use. This might help prevent this from happening in the future.
Debbie
Username: Haroldo
I have a DSC P-9 and get the "No Memory Stick" message 90% of the time, occasionally the camera works. I've tried canned air to clean out the slot and when the card was working, I reformatted it, yet I still get the error. I reset the camera (pin hole next to battery) to no avail.
Any other clues, or is the camera a goner?
Username: Smajm
I have a Magicgate 256 MB card.
I have used this card for the past 2 years taking pictures downloading them to various computers and deleting them with no problems. Recently files that were previously on the card are no longer viewable, I get a No file message when I try to view them on my camera ...however the space is still being used up on the card...eg normally thre is room on the card for say 150 pics and although there is 'No file' I only have room for 20 pics.
Does anyone know how I might recover these "lost or hidden files"
Username: Aamir007
Fort Lauderdale, FL
Post Number: 10
I have a Cybershot DCS-W55 with a Memory card 2GB. I took many pictures in India last month bu can't retrieve them as they get lost in the memory card. When I looked at the memeory card using the camera on the PC it shows a lot of juck character folders and I can't open any of them. I don't want to lose the pictures and need help?
Username: Swt_mic94
hey uhm i have a memory stick buhh it's too small so i now it won't let me upload my photos .. any suggestions?
Username: Aamir007
Fort Lauderdale, FL
Post Number: 11
buy a bigger one! 2GB at least!
Username: Project6
Post Number: 14080
meshellnalie,
What do you mean it won't "upload my photos"? Do you mean it won't upload any photos to your computer? A bigger capacity memory stick may not solve your problem if you are having trouble moving your files from the memory stick to the computer.
Please be more specific so we can pinpoint the problem.
Do you reformat the card after you move the pictures from the memory stick? You need to do the formatting on the camera itself.
Aamir,
You may need to get a retrieval program. Type in "data recovery program" into a search engine and you should get a lot of hits. If you card is made by Sandisk or Lexar, try contacting them as they have free data recovery services.
Username: Karenl
United Kingdom
I was using a Sony (I thought! although having bought it on e-bay I see that may be a problem) 2gb memory stick proDuo in an adaptor in a Sony DSC H1. When reviewing the photos on the camera some of them went really small then I got Access across the screen then Error 13.01 and now I can't view them. I have tried another adaptor, the computer and a digital photoframe but no luck. Is there anything else I can try or are they lost? Would really appreciate some advice.
Thanks
Karen
Username: Telephone
hi there i wonder if anyone can help?
i recently purchased a sony dsc-w55 7.2mp
camera was working fine untill i inserted the memory stick pro duo 4gb, now when taking pictures and i look to preview them they will not come up on the full screen, all i get is a very small thumb nail pic, also when i down loaded some pics they were over exposed and some pics would not download. Any help and suggestions would be great thanks
Username: Telephone
hey karen i have the same problem when reviewing, and wonder if anyone can help
Username: Telephone
i guess im not going to get an answer on here then
Username: Karenl
United Kingdom
If you are still able to access any pictures I would recommend that you download them quickly as soon after mine started to do this it stopped working altogether.
Karen
Username: Monstertruckguy07
I recently bought a 4 GB sony mem stick pro. This was a horrible investment, I went to the Monster Jam this past weekend in Indianapolis and the pics that I took are now corrupted. I could not download them or anything. The sticks are pieces of crap, VERY DISAPPOINTED that I could not have my pics.
Hey Karen I was just reading your post about the errors on your cam. I had the same prob,but I forgot to mention that in my post. I totally lost all the pics and the videos that I had because of that error. I have looked all over the internet for a solution and was unable to find one, that is why I was so disappointed with the card, and not to mention I purchased mine from EBAY too. The only thing that I can tell you is to format the card, you will lose all your pics but it is working now. Hopefully that fixed the prob. Jeremy
Username: Project6
Post Number: 14586
Be careful when purchasing those Memory Sticks as there have been various counterfeit variants flooding the market so ensure that you are purchasing from a reputable dealer.
It is also not a good idea to buy cheap off-brand name memory sticks.
And I also advise a lot of people not to purchase memory cards that are beyond 1GB in size. Once a file gets corrupted, chances are the whole card will get corrupted and all your pictures will be gone. It is better to have multiple smaller capacity cards.
Username: Rosek
I have three different types of Sony memory sticks for my Sony DSC F505. All three were working until yesterday. Memory Stick, Memory Stick Duo and Memory Stick Pro Duo. The Duo and Pro are used with an adapter for my camera. All of the sticks work in the computer with no errors but yesterday started getting the Memory Stick Error C:13:01 when used with my camera. I was able to retreive photos with the computer and reformat but two of the sticks still do not work in the camera. I think if it was a connection problem none of them would work but the regular memory stick is working and the memory stick duo (64mb) works, but if I use the same adapter and put the 1gb duo in it will not work (and it did before). Does anyone have any suggestions?? Thanks.
Username: Shipra_priyadarshi
Gandhinagar, Gujrat
India
Hi,I bought a Sony cybershot T70 digital camera from US just one month back and now I am in India.When ever we insert the memory stick in the camera it shows "memory stick formating error".We formated it while going through Home - memory tool - formate.After this it shows the message to reinsert the stick. .Now when we reinserted the Stick it gives same message of formating error.What to do now?
Username: Project6
Post Number: 15310
Are you using a brand name memory stick or is it a generic brand?
Gandhinagar, Gujrat
India
Dear Berny,
We are using 2GB PRO DUO memory stick.
Username: Project6
Post Number: 15348
That is the type...I asked for brand name.
Gandhinagar, Gujrat
India
The Brand of our memory stick is SONY.
Username: Project6
Post Number: 15368
You have a bad memory card. It could also be a bad connection being affected by the humidity.
Gandhinagar, Gujrat
India
Do I need to change the memory card or is there any way to make this one working?
Username: Project6
Post Number: 15372
You need to change the memory card with a working card.
You could try to reformat the card through a PC.
Username: Anntnwv
Nashville, TN
I didn't know I could format a memory stick. Thanks for that information. What about the camera's internal memory. I had never heard of that. Can you explain it more. Can it be formatted? I really don't know about this. Mine is a Sony 6.0 MegaPixels Super Steady Shot DSC-H2 MPEGMovie VX. I can't remember when I bought it. I was having problems with the pictures being downloaded and half being gray. I hope this fixs that problem. I still don't know about the camera's internal memory. Can you help with this. Thanks in advance.
Ann
Username: Project6
Post Number: 15861
Go through the menus of your camera. Usually under "set-up". It would also help if you read the manual. This nifty little thing will usually tell you all bout the features of your camera and how it works. You should try it sometime.
Username: Banisters_mind
Adelaide Hills, Australia
I'm gonna kick off some fresh contributions to this thread.
I own the Sony Cybershot DSC-P92 and have had no problems what-so-ever since I was given it 4 years ago. However recently I am getting a message up on the camera saying "No Memory Stick". I have tried formatting the memory stick through my computer but this hasn't solved the problem. I have tried restting my camera without success and I have tried installing an updated driver/firmware but Vista doesn't seem to want to recognize the firmware and thus won't let me update my camera. Of course I have also tried to format the stick via the camera but because the camera is saying "No Memory Stick" I can't get it to respond.
I turn to you good folk here - to seek advice and help in solving this problem.
Any help would be muuch appreciated...
Username: Haroldo
[quote]I am getting a message up on the camera saying "No Memory Stick". I have tried formatting the memory stick through my computer but this hasn't solved the problem. I have tried restting my camera without success and I have tried installing an updated driver/firmware but Vista doesn't seem to want to recognize the firmware and thus won't let me update my camera. Of course I have also tried to format the stick via the camera but because the camera is saying "No Memory Stick" I can't get it to respond.[/quote]
I have the same issue (DSC P9).
I called Sony and did a ton of web searching.
They suggest brining it to a repair center (at your cost). Considering the cost of a new (and far superior) camera, it doesn't make sense to try and repair it.
Sorry to say, it's not worth the time and energy, just get a replacement (not a Sony!)
Username: The_zachariah
I am having the same problem Nauman introduced a while ago. I own a "1GB memory stick pro duo" and it has worked fine up until recently. I insert it into my computer through the "Memory stick duo adapter" by Sony and the icon appears in My Computer but I cannot open it. It just gives me the error "please insert disk into MemoryStick (G: )."
However, when I connect my camera with the transfer cable, everything works fine and I can access all my pictures. ALSO, I have used the same memory card AND adapter on a friends computer, which is EXACTLY the same as mine, and everything works fine. Please help me, I have scoured the internet looking for solutions and have not found one yet.
Username: Suresh2win
I have a sony cyber-shot 7.2. My laptop is not reading what is on the momory stick. The stick was recently formated and only has 15-20 pictures on it. Any suggestions?
Username: Gobshite
I have a sony cyber-shot DSC-T300, with a 2GB memory card - I need to format the card but there are loads of pictures on there that I have nowhere else, and my computer won't recognise the card (presumably because it needs formatting)... I know the answer will probably be no, but does ANYONE know of ANY way I can save the pictures??? Should I bother trying the photo machines in Boots to see if they will recognise the card or is it a lost cause???
Thankyou.
Username: Jezzie
Hi, I have a sony cyber-shot dsc-w210 and i use a sony memory stick pro duo 1GB.
Today when i was deleting a photo i must of stupidly pressed the wrong button that says delete all images in this folder! Is there anyway i can undo this? and would the images be saved anywhere else on my camra or memory stick? i cant find my manuel. please help.....
Username: Mbj8945
Mumbai, Maharashtra
India
I am using Sony DSC-S650 camera. It requires Pro Duo Memory Card. I have such 1 GB card. I used it for about 400/500 snaps w/o any difficulty. Suddenly it started giving message
" Memory Stick Locked"
Like SD card this card do not have locking/unlocking tab.
Please help me to overcome this difficulty.}
Username: Loops9
Hi.
Ive read the whole thread and i cant see anything that will answer my question.
I have a 4g memorystick in my sony cybershot camera. Ive only used it twice with about 100 pictures used. everytime i turn the camera on it keeps telling me to reinsert the memory stick which i have done lots of times and i dont know what i can do.
Please help.
Lou.
Username: Ariel12
I have a Sony Cybershot DSC-S950 and i keep getting an error message saying that I don't have a memory stick in the camera, but I do. I already tried to format the memory stick but it didn't work. Does anyone know what to do please?
Thank You
Username: Dukeyboycat
I have a sony cybershot DSC-P10 would like to buy a memory stick with a larger memory to take on holiday and cannot find one anywhere - was sent a pro duo stick but its too small for the camera - anyone with any ideas please?
Username: Helenartist
I bought my camera, a Sony Cybershot DSCCS950, and a 4gb Sandisk pro duo memory stick, 4 months ago. It stopped working a week ago. I was transferring images to the computer and the camera battery stopped working. Now the computer does not recognise when I connect the camera, and the camera screen says "reinsert the memory stick". When I do that it says "Menu" and when I press menu it then goes back to saying reinsert the memory stick. The battery is now recharged but the camera shows there are no shots remaining. I have tried reformatting the memory stick but that hasn't helped. It is clearly a common fault on these cameras. I could replace the memory stick. What else can I do now?
Username: Doglock
Camera sony cybershot W170
Memory stick is sony pro dou magicgate 8gb
did work in camera but since I used photo recovery software the camera will not recognise it. camera will not re formatting the card but the card will work in my computer card reader- any ideas would be appriciated
Username: Jaybee228
I just bought a 4GB Sony memory stick, I put it in the camera and it was working fine. I took it out and put it into the adapter into my laptop, and now whenever I put it in my in camear it reads (reinsert memory stick). I don't know what to do.
Username: Smcgoldrick09
I have a sony cybershot 7.2 mega pixels camera. out of no where my camera keeps telling me to reinsert the memory stick. i did and it keeps doing that....
Username: Kaylee316
United States
Heyyy I have the Sony Cybershot 12.1 mega-pixel digital camera.. the pictures are ahh-mazing!! but one problem... I DONT KNOW WHAT MEMORY STICK TO USE!! aaahh!! I was sooo excited to get it but my memory card wont fit :-( someone pleaseee help!!!! do you know where i can get it? (i live in California) do you know if its at a place like target or walmart or something??? also.. nothing too expensive... thank you sooo much!! <3 :-)
Username: Nano602
QUOTE: "Heyyy I have the Sony Cybershot 12.1 mega-pixel digital camera.. the pictures are ahh-mazing!! but one problem... I DONT KNOW WHAT MEMORY STICK TO USE!! aaahh!! I was sooo excited to get it but my memory card wont fit :-( someone pleaseee help!!!! do you know where i can get it? (i live in California) do you know if its at a place like target or walmart or something??? also.. nothing too expensive... thank you sooo much!! <3 :-)"
You dont mention what model it is but being Sony most if not all of the newer models use a "Memory Stick Pro Duo". Yes, you can find it at Walmart or Target. As far as price... well that depends on what size you want it there are 2GB, 4GB, and 8GB and even 16GB there are also 1GB out there but they're not too common anymore. The prices range from about $15 to $75.
Check Walmart here
http://www.walmart.com/search/search-ng.do?search_query=memory+stick+pro+duo&sea rch_constraint=0&tab_value=20_All&ic=48_0&ref=&search_sort=4&selected_items=+
you can also find it at many other stores like: Best Buy, Officemax, Staples, Radio Shack, Fry's Electronics, and other stores that have electronics.
Make sure you check your manual or at least write the model of the camera and take it with you to the store to make sure it uses that kind of memory, like I said Sony uses that kind of memory on their newer model cameras.
Username: Kaylee316
United States
Fernando!! Thank you soooooooooooooo much! You are an answer to my prayers!! haha I will go tomorrow! thanks again!
Username: Sd592
Hi, I have a Sony DSC-S950 10.1 megapixel camera with a 4gb Sandisk Memory Stick pro duo. When I tried to look at pictures on the camera it a blue screen came up and most of the recent pictures which said " File Error". I turned the camera off and back on and still same problem so I tried to take a picture and the camera froze and then shut off. When I turned it back on again the screen said "Reinsert the Memory Stick" Ive tried doing so several time to no avail. What should I do? Is there any way to recover the photos, I had about 300 pictures on it and I would really hate to lose them.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Photography > Digital Cameras > Sony Cybershot Memory stick issue [ « Previous ] [ Next » ]
