Thread: Camcorder film to my pc is it possible? |
New member Username: Waveone
Post Number: 1 Registered: Jun-05
| Posted on Thursday, June 23, 2005 - 03:47 am: |
Hi i have a Canon UC8000 and a fairly new PC (windows XP), i was wondering if there was a way to connect the two so i can get all of my camcorder tapes on to my pc which i can then upload to my website later. I constantly see sites with video clips and would like ot to the same. The only leads i have are the scart ones that connect to the TV nothing else can you help? thanks in advance |
New member Username: Captain
Post Number: 9 Registered: Jul-06
| Posted on Monday, July 17, 2006 - 03:47 pm: |
yes |
Silver Member Username: Ftalife
Post Number: 228 Registered: Jul-06
| Posted on Saturday, August 05, 2006 - 02:24 am: |
Yes, you can even edit the videos however you would like with some software. You should have some usb or some type of cord that came with your cannon camera. |
New member Username: Cochin10
Post Number: 1 Registered: Jan-08
| Posted on Sunday, January 13, 2008 - 10:14 am: |
I have a samsung camcorder and a windows xp pc could anyone please tell me which wires I need to connect to the pc so I can edit it with Pinnacle I dont think i have a 1394 port but i have 5 usb ports thanks Jim |
