Thread: Nikon Coolpix 3200 Problem |
New member Username: Chrisrun
Post Number: 1 Registered: Jun-05
| Posted on Monday, June 06, 2005 - 12:11 pm: |
Recently, my Nikon Coolpix 3200 has begun to take light and turn it purple, and its also overexposing to the light, so essentially, it's messed up and I can't use it right now. It shows this purple color on the LCD screen and when I transfer the pictures to my harddrive, so its definitely not just the LCD display. Does anyone know why its doing this and if there is some sort of setting that accidentally was changed? |
Post Number: 3092 Registered: Dec-03
| Posted on Tuesday, June 07, 2005 - 09:42 am: |
Check your manual on how to reset the camera to factory settings. |
| Posted on Sunday, June 19, 2005 - 04:43 am: |
well,i have the same problem on the lcd. but when i take pictures, the purple light is gone. however, i have problems on movies.but,here's what i do: when i want to take a movie, i use s-af (single focus) and i point the camera to a source of light. then,the purple stripes will be gone. |
Post Number: 3160 Registered: Dec-03
| Posted on Monday, June 20, 2005 - 07:36 am: |
If the camera is functioning properly, you shouldn't have to do any type of manipulation to make the "problem" go away. The term "problem" is the giveaway here. It means the camera needs to be serviced. |
Unregistered guest |
| Posted on Sunday, November 06, 2005 - 01:06 pm: |
I have the exact same problem, one day it was working and now PURPLE. I have not had a chance to get it serviced yet but if anyone has seen this problem and had it corrected can they let me know. |
| Posted on Saturday, November 19, 2005 - 03:28 am: |
I'm having a problem with my Coolpix 3200. Nothing happens when I connect it to my computer. Any ideas? Please help. |
Post Number: 4277 Registered: Dec-03
| Posted on Saturday, November 19, 2005 - 04:47 pm: |
kaeli, Did it work before? check your cable see if it is working properly. |
chantelle Unregistered guest |
| Posted on Saturday, February 11, 2006 - 06:00 pm: |
Hi i have bought a coolpix 3200 digital cam,(pre-owned) and i have noticed that it makes a clicking noise when its in the vidio mode. Im just wondering if this is normal for the cam? or do you think its been damaged. I hope someone can help thankyou. |
Post Number: 5555 Registered: Dec-03
| Posted on Saturday, February 11, 2006 - 06:43 pm: |
How loud is the clicking noise? And no, I don't see this as normal... |
| Posted on Saturday, February 25, 2006 - 03:52 am: |
Hello, I did a google search for "nikon coolpix 3200 help" and this page came up! Hopefully someone knows how to fix this problem: my nikon has always gone through batteries quickly (it's about two years old now), but recently i would put two new batteries in and almost immediately the screen will go white and it will read, "warning! battery exhausted!" Now, it barely turns on at all, even with totally new batteries. I only sometimes get that white screen. Is my camera just dead and gone, or what? Please help! Thanks. |
Post Number: 6329 Registered: Dec-03
| Posted on Saturday, February 25, 2006 - 04:08 am: |
When you write "totally new batteries", do you mean newly charged or brand new as in just bought from the store "new". If they are 2 years old, you have exhausted the batteries usable life. Unfortunately for Li-Ion batteries, you can only charge them so much and they will go flat after 2 years. You need to get fresh batteries and do not even try to use generic batteries. There is a reason why they are so cheap. |
| Posted on Saturday, February 25, 2006 - 12:57 pm: |
Thanks for your response, but I should've been more clear. My camera is 2 years old, not the batteries. I've never used rechargeable batteries (although I probably should to save money). The batteries I use for the camera are "just bought from the store new". I suppose I should only buy brand-name batteries, but even with Duracell or Energizer, my camera goes through them too quickly. I guess I'll buy some brand-name batteries and see if that works, though. Thank you. If you have any other suggestions, please let me know! |
Post Number: 6344 Registered: Dec-03
| Posted on Saturday, February 25, 2006 - 06:45 pm: |
Digital point and shoot cameras have always gone through batteries very quickly. The do not last too long on digital cmaeras because of the screen and the flash. It is never a good idea to use generic batteries on digital point and shoot cameras. I go through the same thing with my Coolpix cameras. |
| Posted on Sunday, February 26, 2006 - 11:22 pm: |
Thanks for your response. I bought new brand-name batteries and my camera works again. Guess it's as simple as that! |
Post Number: 6383 Registered: Dec-03
| Posted on Monday, February 27, 2006 - 04:12 am: |
Glad it worked out for you |
New member Username: Kiyutza
Post Number: 1 Registered: Apr-06
| Posted on Wednesday, April 26, 2006 - 01:49 pm: |
I have a problem with my nikon coolpix 3200 too. I took something like 10 pictures one after the other and then when i strated the camera the light of AF was green all the time and i can`t eneter the menu, i can't zoom, i can't do anything but a regular picture. i can't even chose what kind of photo.then....after i do one photo..i CAN enetr the menu, i can see the taken photos, but i can`t do another one. so i must turn it off and then on.. i can`t do anything... PLEASE help... what can i do?! |
Post Number: 7654 Registered: Dec-03
| Posted on Wednesday, April 26, 2006 - 11:38 pm: |
What memory card are you using. |
New member Username: Ideoplast
Post Number: 1 Registered: May-06
| Posted on Thursday, May 18, 2006 - 10:20 pm: |
Hello -- I have had a Coolpix 3200 for about a year and a half - during which point everything has worked fine. I tried to turn my camera on yesterday but only the green light next to the on/off switch flashed intermittently. The camera never powered up. I recharged the camera's batteries and tried again this evening -- same thing happened. I've looked around on Nikon's site and other places on the web and cannot find anything. Has anyone else ever experienced this issue? Thanks so much for your help! |
Post Number: 8038 Registered: Dec-03
| Posted on Thursday, May 18, 2006 - 11:10 pm: |
Ideoplast, How old is the battery? Is it about the same age as the camera? Chances are you need to replace the battery. Li-ion batteries will no longer hold a charge after about 2 years, specially if you use it a lot. It will be enough to light up a green LED but not enough to complete its cycle before running out of juice. Try that first. |
New member Username: Williaak
Post Number: 1 Registered: Aug-06
| Posted on Thursday, August 10, 2006 - 06:38 pm: |
Hi, I have a Coolpix 3200 and every time I try to do a transfer of pics to my laptop, I get the message "no CF card" in the camera etc. I bought one of those extended CF cards to shoot more pics and formatted it on the camera, but it still won't read. Any ideas? |
Post Number: 9492 Registered: Dec-03
| Posted on Thursday, August 10, 2006 - 07:14 pm: |
Amanda, The best thing to do is use a memory card reader. This will make your transfers a lot easier without having to use your camera as a go between. |
New member Username: Mell
| Posted on Wednesday, August 16, 2006 - 01:37 pm: |
I bought a used nikon coolpix 3200 and after every picture I take, it takes a long time until I am able to take another. The green light by AF blinks and sometimes the red light as well, and sometimes the screen even goes blanks for a second before I can take another picture. Is there anything I myself can do to try and fix this and make it quicker? Also, when its in video mode, it makes a clicking sound--barely audible when taking the video, but quite loud when playing it back. Thanks for any suggestions! |
Post Number: 9616 Registered: Dec-03
| Posted on Wednesday, August 16, 2006 - 07:51 pm: |
I think you may have purchased a bum camera. Return it if you can and know that buying a used digital point and shoot camera is never a good idea, even if it is by Nikon. That camera is really old by today's standards and really slow as well. Unfortunately, there is nothing you can do for it. The noise during video capture is something that needs to be repaired by Nikon and is not user serviceable. |
New member Username: Ashlie
| Posted on Friday, August 25, 2006 - 05:32 pm: |
I have a nikon coolpix 3200 camera, it fell on the ground and then only took pictures that looked like negatives, with a lot of purple in them. then i tried giving the camera a few good whacks like another camera help site suggested, and now it won't go into the taking picture mode at all. it displays a black screen and illuminates, but displays a 'lens error' message. is there anything i can do? |
Platinum Member Username: Project6
Post Number: 10455 Registered: Dec-03
| Posted on Friday, August 25, 2006 - 06:56 pm: |
You dropped a sensitive pies of equipment and then you gave it a "few good whacks". Did you really expect it to work after all that? Did you really think there is anything you can do? Let common sense take over at this point and really think about what you need to do. |
New member Username: Lovelyboy
Post Number: 1 Registered: Oct-06
| Posted on Tuesday, October 17, 2006 - 03:47 am: |
I own a beautiful Nikon 3200 coolpix. Couple of days back I used my camera normally and put it back in its bag. Today when I tried to use it again it wont start at all. I thought it could be a problem with the batteries totally discharged. It charged my batteries completely but my camera still did not start. I had an extra pair of batteries for which the same thing happened. Can anyone help me on this ? Have I lost my beloved camera ? |
New member Username: Midnightradio
Post Number: 1 Registered: Apr-07
| Posted on Friday, April 20, 2007 - 08:19 pm: |
Iam having a simaler problem with my nikon coolpix 3200 cameraas a previous poster. the batteries keep dying after only a few pictures have been taken (seriouly like 2 pics) when normaly batterries last for several pictures. these are brand new batteries straight from the package (i've tried more than one package/brand actually, i've also tried my re-chargeable batterries and the same thing happens. sometimes if i take the batteries out and put them right back in, it works for a few more pictures and then dies again. |
New member Username: Adina83
Post Number: 1 Registered: Sep-08
| Posted on Sunday, September 07, 2008 - 02:02 pm: |
I have my coolpix 3200 for 3 years now and have the same problem as Chris. It started to give me yellow and pink pictures, it would work again normal for a few times, get pink, work on and of and now I'm at the point it only gives pink pictures. Does anyone know if this is repaerable, if so, how much it would cost, and if its worth doing so. After all, the camera is 3 years old and I'm a heavy user, use it nearly every day for my work (Real estate). So far, I was happy with the camera, I find it very slow taking pictures but it was my first digital camera and i cannot really compare. Any suggestions? |
