Thread: No Playback or Connection |
Bahrgain Unregistered guest |
| Posted on Thursday, June 02, 2005 - 10:51 pm: |
Hey I recently just got a Panasoniv PV-DC152 minidv camcorder, and I can't seem to get it connected to the pc. I have the firewire cable coming from my firewire card hooking up directly to the camera. I know the cable and the card both work because I have hooked up a friends camera before. I just have no idea what to do now. Also, I can not playback videos on my camcorder. When I go to the 'VCR' mode and select 'Play' it makes a sound like its searching for something and then it just stops and does nothing. It is a blue screen this whole time. Can anyone please help me with this? Thanks |
New member Username: Johnny2ak
Post Number: 1 Registered: Jun-05
| Posted on Friday, June 10, 2005 - 09:49 pm: |
anyone???
Silver Member Username: Gromit
Post Number: 250 Registered: Mar-05
| Posted on Sunday, June 12, 2005 - 09:24 am: |
Johnny, I presume you are the same person as "Bahrgain" If your camcorder is failing to play back correctly, you can assume it is faulty in which case you might as well get a replacement before you start worrying about whether it can connect to your PC or not. From the hundreds of problems I have seen on this website, there is no particular emphasis on Panasonic, so don't feel that a brand-change is mandated at this point. Post again for further help as and when you require. Cheers. |
