Home > Message Board > Photography > Camcorders > Archive through June 24, 2005 > Audio with firewire?
Author Thread: Audio with firewire?
Jerry C
Hi, I have a JVC Mini DV hooked up to my computer and am transferring video via firewire (which is fun to say:}. With a firewire hookup is sound transferred also or do I need to run a second wire for the recorded sound, because so far no sound found? Thanks.
Jerry C
Hi, I have a JVC Mini DV hooked up to my computer and am transferring video via firewire (which is fun to say:}. With a firewire hookup is sound transferred also or do I need to run a second wire for the recorded sound, because so far no sound found? Thanks. I'm posting this twice so I can be in this thread too.
Jerry C
Okay I finally found my answer in a previous posting thanks MR. Hopler. Firewire is all you need just change the setting in Premiere to record EEEE1984 for audio or whatever that number is. Thanks.
Username: Thaiphoang
I have the same problem, I captured and burned the video part using the dv cable but no audio, can you help
Home > Message Board > Photography > Camcorders > Archive through June 24, 2005 > Audio with firewire? [ « Previous ] [ Next » ]
