Home > Message Board > Photography > Camcorders > Archive through June 24, 2005 > JVC Mini DV
Author Thread: JVC Mini DV
Rocketguy18
I have a JVC Digital Video Camera Mini DV and it Isn't Firewire compatible. I also dont have a S-Video port on my new computer. My camera doesn't work with USB and I also hear USB has really bad video transfer...so what do I do?
Username: Mrgudman
Try using PCI or via USB analog video capture using audio-video cable.
Username: Project6
Post Number: 3032
What model is your JVC? At the very least you will have a JLIP output on the camcorder. You need to get a video capture card, this will work with the JLIP of the JVC.
Home > Message Board > Photography > Camcorders > Archive through June 24, 2005 > JVC Mini DV [ « Previous ] [ Next » ]
