Thread: Looking for a miniDV camcorder that can hook up to a DVDplayer/recorder |
New member Username: Lmmartin23
Post Number: 1 Registered: Mar-05
| Posted on Thursday, March 31, 2005 - 05:14 pm: |
Ok I'm looking to get a mini Dv camcorder but I want one that can be hooked up to a dvd player/recorder(writer) so I can transfer the video to a DVD. My computer doesn't have a DVD writer and I just bought it. So I thought I'd just buy a new DVD player that also writes DVD's, as I need a new DVD player also. Can someone tell me what camcorders will does this and what kind of cable I will need?? I would just ask the people at Best buy but most are no help and just try to get you to spend more money than needed around my area. Any help would be appreciated. Thanks |
Post Number: 2878 Registered: Dec-03
| Posted on Thursday, March 31, 2005 - 08:21 pm: |
You need a camcorder that has video outputs and a cable that can connect to a DVD recorder's video input. 1.Camcorder with video and audio output. Canon or JVC, take your pick. 2. Audio Video cable. 3. DVD recorder. This should already have an audio video input. It is not unlike the old vhs camera into a vhs recorder. Only the formats have changed but the basic prosess is the same.
Post Number: 2879 Registered: Dec-03
| Posted on Thursday, March 31, 2005 - 08:22 pm: |
You need a camcorder that has video outputs and a cable that can connect to a DVD recorder's video input. 1.Camcorder with video and audio output. Canon or JVC, take your pick. 2. Audio Video cable. 3. DVD recorder. This should already have an audio video input. It is not unlike the old vhs camera into a vhs recorder. Only the formats have changed but the basic process is the same.
Post Number: 2 Registered: Mar-05
| Posted on Friday, April 01, 2005 - 01:27 am: |
Thanks, so any model Canon or JVC will work?? Thanks so much |
Post Number: 2880 Registered: Dec-03
| Posted on Friday, April 01, 2005 - 09:46 am: |
Yes, just be wary of the output capability. |
Post Number: 3 Registered: Mar-05
| Posted on Friday, April 01, 2005 - 01:23 pm: |
I've heard the Cannon Elura 65 is a nice one.?? What do you think?? Thanks again |
Post Number: 2887 Registered: Dec-03
| Posted on Friday, April 01, 2005 - 03:09 pm: |
Excellent camera. |
Unregistered guest |
| Posted on Thursday, May 05, 2005 - 04:47 am: |
Has anyone had experience with Samsung SCD 453 mini DV? It seems to have great features for a very good price. My experience with other Samsung 35 mm cameras has bee positive. |
