Thread: JVC GZ-MC100 vs. Sony DCR-PC350 Mini Dv |
Bronze Member Username: Chary
Dominicab Republic,
Santo Domingo
Post Number: 45 Registered: Sep-04
| Posted on Saturday, February 26, 2005 - 03:41 pm: |
i want to know of this two great camcorders, which is the best. What do you recommend me to buy. |
Dominicab Republic,
Santo Domingo
Post Number: 46 Registered: Sep-04
| Posted on Sunday, February 27, 2005 - 01:09 am: |
between those camcorders, what do you recommend, because i dont know about the difference on camcorders. I dont know nothing. i only want to know which is the best between that sony dcr-pc350 or the jvc gz-mc100. |
Post Number: 2800 Registered: Dec-03
| Posted on Sunday, February 27, 2005 - 11:34 am: |
They are both good. It comes down to the price and features you want or those that you will actually use. I try to stay away from Sony becuase they use a lot of proprietary peripherals. JVC tends to use what is out there and thus makes it more user friendly. JVC uses the compact flash and sony, of course, uses the sony memory stick. Unless you have an all sony product, you can't use the memory stick anywhere else. |
