Thread: Mitsuba DV5 Plus |
Unregistered guest |
| Posted on Friday, February 25, 2005 - 10:36 pm: |
I bought a new digital/camcorder camera, the Mitsuba DV5 Plus. The problem: I removed and replaced the flash card while the camera was on and it shut itself off. Now it is completly dead. Will not turn on. Tried new batteries - nothing... Did I short something out? Now it is worthless. Anybody have this same problem? Thanks |
| Posted on Thursday, March 03, 2005 - 01:53 pm: |
My 1st reaction is to ask you if you have the receipt because it should be under a 1 yr. mfg. warranty. I have one myself but I have had problems with the display saying MEMORY FULL just as I would take just one picture with nothing else on the card. I got a 512MB CF card and that solved that problem, if you would come across that. But the 1st thing I would check is where you put in the batteries, make sure the contacts are intact and the contacts where it slides into is correct also. Also, maybe one of the pins that the CF card goes into could possibly be bent, you may want to try a different card, but that shouldn't be the problem if you are just using the USB cable connected. Hope that helps some. |
grettahouse Unregistered guest |
| Posted on Friday, March 04, 2005 - 01:17 pm: |
Thanks for the info. The F.A.Q. in manual says it has shut down abnormally. No info on how to fix. I bought it on e-bay,negitive contact with seller. There is no warranty info with manual or on box. So I dont even know where to send it for warranty. Anybody know of a manufacters web site? |
Bronze Member Username: Freeringtones
Post Number: 43 Registered: Mar-05
| Posted on Wednesday, March 09, 2005 - 08:23 pm: |
Looking for a Mitsuba DV5? The Olympus C-770 is a much better product!
New member Username: Bgaineshunter
Post Number: 1 Registered: Jun-05
| Posted on Friday, June 03, 2005 - 06:16 am: |
I'm sure there are better products, and I'm sure they cost a lot more. The Mitsuba is my first camcorder, and I generally don't think that affordable, nonprofessional camcorders are very good yet. What I want to know is is anyone satisfied with the quality of the stills and day time videos that this camera takes? Are the pictures equally as good when using the zoom? What about the sound on videos? |
| Posted on Friday, June 03, 2005 - 11:09 am: |
The camera worked great. Stills and video, sound were all clear. The camera itself is cheaply made. I thought it would break every time I changed the batteries. Use caution and dont do what I did, remove flash card while camera is on. Now it sits brand new in its box because it never worked again after that. I was unable to find anyone to repair it. They told me to throw it in the trash, it was junk to begin with. |
| Posted on Sunday, July 03, 2005 - 03:47 pm: |
What a drag!!!! it gets WORSE!!! My neighbor came and asked me to see if I could fix his camera that went cold dead. I am the local techie. Anyway his was a ,get this, SONY brand DV5 PLUS. After many emails with sony and coaxing, turns out Sony does not make this product and refered me to a Mitsuba. It is the same EXACT camera with the same labels but instead of Mitsuba it said SONY. I can now contact my neighbor and let him know the bad news. I guess you tried the new flashcard like it said, right? |
| Posted on Sunday, July 03, 2005 - 03:57 pm: |
What a weiner! Do you sell Olympus? Thought So! We were talking about a problem of a specific camera type . |
| Posted on Saturday, July 09, 2005 - 01:35 am: |
Yupe, tried another new 512 flashcard. Didnt fix it. Now I have a new flashcard to throw in the box with it. |
| Posted on Tuesday, September 27, 2005 - 01:43 am: |
I have a dv5 and it works great!!!! |
| Posted on Wednesday, September 28, 2005 - 11:42 am: |
DONT REMOVE THE FLASHCARD!!! |
| Posted on Tuesday, October 04, 2005 - 05:11 am: |
does anyone know how i can get a users manual for the Mitsuba dv5 plus? bought this cam from ebay but it didnt come with a manual like it was supposed to. i've looked all over the internet but can't seem to find one, i can't even figure out who the manufacturer is to try to contact them.i know i could just use it w/o the manual but i dont know what half the options in the menu stand for. also, i can't figure out how to delete a single pic..for those of you who own one, can you delete only one single pic or do you have to delete all of them at once or none at all? any help would be greatly appreciated. thanks! |
| Posted on Wednesday, October 05, 2005 - 01:27 pm: |
Yes u can delete 1 at a time or all at once. Give me your e-mail address and i will send you copies from my manual. |
| Posted on Saturday, October 29, 2005 - 02:47 pm: |
does anyone know how i can get a users manual for the Mitsuba dv5 plus? i boutht this cam with sony mark, ut is not sony. I want a manual an if the cam have other type of battery (with more time). And the type fo card i can buy. I have a surprice about this cam i think is a one use cam, until it became worse without repair. Please my mail is: estherlaz@yahoo.es thanks |
| Posted on Sunday, November 06, 2005 - 11:14 pm: |
Hi.. As Alicia and Estherlaz my father bought a Mitsuba DV5 Cam but it came without itīs user guide.. i have a terrible problem because i canīt make it works as it should be. The resolution isnīt as i hope, videos and pics donīt look clear (everything looks between green and brown :S ) and i canīt stablish colors. It would be great if someone can send me the guide copies.. Pls i need some help!! iīm going to have my vacations to Netherland and i need this camera working. Thanks so much for ur help. |
| Posted on Thursday, November 24, 2005 - 08:13 pm: |
I have a Mitsuba DV5 Plus. When i go to record something or take a picture... it only uses the bottom lense... how do i get it to use the top one? |
davided Unregistered guest |
| Posted on Saturday, November 26, 2005 - 11:43 pm: |
i have the mituba Dv5 plus and it is on working and i dont know what to do .so can someone please help me. |
| Posted on Saturday, November 26, 2005 - 11:58 pm: |
Did anyone find know where i an send in my mituba to get it fixes. |
| Posted on Saturday, November 26, 2005 - 11:59 pm: |
Does anyone know where i can send in my mituba dv5 to get it fixes. |
reverendanthony Unregistered guest |
| Posted on Thursday, December 01, 2005 - 12:26 pm: |
Does anyone know how I can get software for the MITSUBA DV5 camera. Mine did not come with the CD that it heeds and I can not find the manufactor on the net to get a down load. Help is appreaciated. |
New member Username: Jorgemz
Post Number: 1 Registered: Dec-05
| Posted on Thursday, December 08, 2005 - 01:51 am: |
yo tambien tuve el mismo problema, sin sabe saque la memoria compac flash, y de un momento a otro murio, y no se como hacerlo funcionar de nuevo, no tengo el manual verdadero. si alguien lo tiene enviemelo a mi email. jrglmz@gmail.com |
Post Number: 2 Registered: Dec-05
| Posted on Thursday, December 08, 2005 - 01:58 am: |
el problema es que cuando se saca la memoria flash, cuando esta encendida, genera un error, y se apaga automaticamente, si alguien sabe como hacerlo funcionar nuevamente, o como resetear el equipo para ponerlo en cero, envieme la informacion a mi email. jrglmz@gmail.com (nota: el equipo no tiene pila para resetear, y la memoria que usa es duo-26, si alguien sabe resetear el sistema del equipo, envieme la informacio please). segun se, estas camaras, tienen problemas con las memorias flash y algunas no pueden formatearlas. |
fired up Unregistered guest |
| Posted on Saturday, December 24, 2005 - 04:33 am: |
Boy... I wish I had came across this site befor I bought my SAC-O-CRAP DV5 (Dosnt-Verk-after 5minuts!!) What kind of camera has three of the same menu control bars,? and do nothing of what their said to do. To all those looking for manuals, buying large memory cards, and plain waisting your time looking for help and answers,,STOP! there are none! I'm probaly going to hang myself after talking about it. I've missed out on my son's school events, my daughter 1st birthday, and my 5th wedding anervercery. And that was a good night if you know what I mean!!.. Down With the DV5,, DOWN WITH Mitsuba!!! PEICE OF $#!T |
| Posted on Sunday, December 25, 2005 - 06:00 pm: |
Can someone please send me a copy of the insturction manual or tell me where I can get a copy off the net? I'm trying to figure out how to work this thing, and though most of it seems simple enough, I would like to be able to do more with the camera. My email address is: shelbylovesali@yahoo.com or newhopeshelby@yahoo.com. Either addy would work fine. I would be so grateful if I could get this info. |
| Posted on Friday, December 30, 2005 - 05:10 am: |
I have a Mitsuba Camcorder and Iam trying to figure it out. Can someone please email me copy of manual or tell where I can optain a copy. |
| Posted on Monday, January 02, 2006 - 05:37 pm: |
Can anyone tell me where i can find a free download of pixela image mixer? |
| Posted on Friday, January 06, 2006 - 10:21 am: |
I am having the same problem I took the flash card out of my mitsuba DV5 camera, put it back in, and now my camera is dead. If some one finds the solution please let me know what the solution is. THANK YOU |
Post Number: 3 Registered: Dec-05
| Posted on Sunday, January 08, 2006 - 02:05 pm: |
bueno, he encontrado algunas paginas que tienen algo de informacion, en primer lugar la camara tiene un procesador sunplus SPCA536A-PB111, este pequeņo procesador es utilizado en muchas camaras fotograficas, he bajado algunos pdf que muestran el diagrama de funcionamiento, http://mxhaard.free.fr/spca50x/Doc/Sunplus/spca533a/SPCA-533A.pdf ademas, tiene una memoria "NAND Flash Interface", que no estoy seguro si es el que tiene el sistema operativo de la camara, o es el que procesa el LCD, lo mas es lo primero, este pdf de esta memoria, esta en la siguiente pagina http://search.semicon.toshiba.co.jp/cs.html?charset=iso-8859-1&url=http%3A//www. semicon.toshiba.co.jp/eng/prd/memory/doc/pdf/nand_applicationguide_e.pdf&qt=TC58 DVM72A1FT00&col=eng+presse+tde&n=1&la=en, el fabricante es TOSHIBA y el modelo es TC58DVM72A1FT00. ahora tiene una memoria adicional, que es de almacenamiento de fotos y video de de tipo DDR de fabricante VDATA, esta memoria es comun, pero no he encontrado pdf que indique como funciona, pero el modelo es VDATA 20442 VDS7616A4A-6. por ultimo un circuito integrado que es un divisor y adaptador de voltaje , y es temporizador de encendido, es el que controla que la camara se apague automaticamente si se encuentra inactivo. este CI es de modelo TPS61100, el cual encontre una pagina que habla de su funcionamiento, http://www.epn-online.com/page/15197/power-solution-for-one-or-two-cell-battery- applications-battery-status-indicator.html?sid=6267f240056a9982e5cd5fc78b18d898# otra cosa, he encontrado una pagina de un especialista electronico diseņador de camaras digitales, el mismo construye camara y los hace funcionar en linux, este especialista fabrica sus camaras usando el procesador Sunplus de la serie SPCA53xxx, Si alguien puede contactarlo para que pueda arreglar la camara seria lo mejor, y publicar la solucion. la pagina de esta persona es http://mxhaard.free.fr y esta subpagina se tiene algunos archivos de su Sunplus SPCA53XXX http://mxhaard.free.fr/spca50x/Doc/Sunplus/ |
dexter66 Unregistered guest |
| Posted on Tuesday, January 24, 2006 - 11:14 am: |
I made the same mistake as the others!! I bought my DV5 on Ebay too. No manual. I would love a copy of the manual. I don't know anything about this camera. I am going to Israel in 2 weeks and would like to be able to at least take photos. Thanks. dexter66@netzero.com |
| Posted on Tuesday, January 24, 2006 - 11:20 pm: |
I have Mitsuba DV5 plus which is gifted by my friend but its now not working & i misplaced the main power cord the same. I don't know the service centre addresses for the same. So please guide me for the same. Regards, Megha |
queenjody76 Unregistered guest |
| Posted on Thursday, February 02, 2006 - 01:54 am: |
Anyone Please Let me know if you were able to get your fixed.... Mine died and I exxchanged it and then the second one died too. HElp! queenjody76@hotmail.com |
Post Number: 5126 Registered: Dec-03
| Posted on Thursday, February 02, 2006 - 02:09 am: |
First one died...then the second. What does that tell you? Get a different one! |
Miranda Rene Unregistered guest |
| Posted on Friday, February 03, 2006 - 01:05 pm: |
Thanks for all your input! We just bought a Mitsuba DV5, and it looks really cool, but were planing on sending it back due to all the negative feed back, and having no tech. support, if anything happens to it, pluse it has no flash:-( Appreciate it! |
New member Username: Misstique
Post Number: 1 Registered: Feb-06
| Posted on Tuesday, February 07, 2006 - 11:51 am: |
Hi everybody! I was referred to this site by someone at Ebay. He thought someone here may be able to help me. I have a Mitsuba DV5, which for all intents and purposes is brand new. I purchased it for my mom, who then passed away. The problem is, I intend on selling this camera via Ebay, and when I went through the box to make sure everything was as it should be, I found that the users manual is no where to be found. The person who referred me here said someone may be able to help me, even if it was by e-mailing me a copy, which I could then print out or something, or ultimately direct me to where I can get an original copy. Please, can anyone out there help a girl out? Thanks in advance!! My e-mail is kathy.hi@comcast.net |
Post Number: 6002 Registered: Dec-03
| Posted on Saturday, February 18, 2006 - 05:47 pm: |
Try the links given above. |
| Posted on Sunday, February 19, 2006 - 02:13 pm: |
I AM LOOKING FOR A MANUAL FOR A MITSUBA DV55 CAMARA CAN ANYONE OUT THERE GUID ME TO WHERE I CAN FIND THIS MANUAL AND SOFT WHERE. |
Post Number: 6074 Registered: Dec-03
| Posted on Sunday, February 19, 2006 - 07:53 pm: |
Why are you typing in allcaps??? |
| Posted on Wednesday, March 01, 2006 - 03:04 pm: |
DV5 Battery..Does anyone know of a replacement for the plastic battery box?..I mean a real battery that will last awhile.. |
New member Username: Kwacka2
Post Number: 1 Registered: May-06
| Posted on Wednesday, May 10, 2006 - 11:14 am: |
A friend has a "Sony" DV8 camera. It looks identical (including labels) to the Protex DV55F (described as a DV5 upgrade) that is manufactured in China by Queen Lines (XM) camera Co Ltd: http://www.fuzing.com/vli/000067e8a286/Digital_Camcorder_DV55F__20_colour_LCD_pa nel_with_360degree_rotation There is also an online contact at this site. Perhaps they might be able to supply manuals/advice? |
Silver Member Username: Geeker
Post Number: 115 Registered: Nov-04
| Posted on Monday, May 29, 2006 - 10:22 pm: |
My friend has tried to get me to ebay her DV5, i have refused based upon what i have found out so far. Hers is badged as Panasonic TEC05D (australia). The quality of this camera is abismal at best. Its video recording is 320x200, my sony cyber shot p100 has better video quality (it does 640x480! and its a digital still camera!!!). The camera does not use the top lens, nor the viewfinder. Which means it all runs off the cmos camera under the lens, which has no lens on itself. This leads to the worst picture quality you'll ever see. The included 16MB SD card will allow you to record about 30 seconds of video. A 1GB SD card (which will get you around 22minutes will cost your around $250, which could well have been spent on a better camera. I have the manual with it, but there is nothing special in the manual, all of it you can figure out for yourself. I doesn't even have references to the make or model of the camera. I reckon that some budget cheap assed comapny made these camera, stopped production half way through, and then badged them with well known brands to flog them off to poor individuals. I you have bought one, punch the person you bought it off. Please pass this onto anyone who might be thinking about a DV5. Post this on all eBay people trying to sell a DV5. Stop this monstrosoty now!
New member Username: Penjoka
Yaounde,
Centre
Cameroon
Post Number: 1 Registered: Jun-06
| Posted on Friday, June 02, 2006 - 06:34 am: |
Hello, nice meeting you guys here, I also have a Mitsuba Vision 103 that was sent to me by a friend from the USA to Cameroon Africa, bought from Ebay, he got the manual later and will send it to me. But the problem is not the manual, the flash is not working since the camera arrive Cameroon and he told me he used it with the flash when the camera came from Ebay. Please if anybody knows how one can get the flash working, do not hesitate to contact me at: penjoka@yahoo.com I do not visit this website often, today I had this opportunity to see this website because I was doing some research on how to get the flash fixed. So please do contact me direct with my email address. I won't know how to get to this website after closing it. I do not know if there is any card like flash card separate from Memory Card, I have 512 memory card that can permit me take 930 pictures and some video. My problem is the flash, I can't take pictures in the dark... Please help me. |
Yaounde,
Centre
Cameroon
Post Number: 2 Registered: Jun-06
| Posted on Friday, June 02, 2006 - 06:42 am: |
New member Username: Bartender69oo69
| Posted on Saturday, June 17, 2006 - 01:00 am: |
After reading all of your feedback reguarding this P&$ce of $h!t camera... after 5 minutes, and a simple insertion and removal of the memory card, its over, no support, many generic and brand names for the same camera... so the short of it is, if you bought one....YOU GOT SCREWED.. If you want one.... Im selling mine along with other useless items... If your considering buying one of these... do this.. goto google and search " MITSUBA support ", try as many other search engines as u wish....and not only will you have wasted money, but now countless amounts of time. Its nothing more than a broken look pretty, waiting to be thrown away |
New member Username: Gato
| Posted on Friday, June 23, 2006 - 12:50 am: |
yes tihis cam is a chit i buyed and never works y wnat to know if somebody of you can help me or give a instrions manual because i dontss have any plz and dont buy any product from mitsuba |
New member Username: Jkoo
Post Number: 1 Registered: Jul-06
| Posted on Wednesday, July 05, 2006 - 09:38 pm: |
I just bought a Mitsuba MV300M Digital Camcorder/Camera and I was wondering if the same problems exist for this camcorder. It says retail value is $499 - load of s*** |
Post Number: 8411 Registered: Dec-03
| Posted on Thursday, July 06, 2006 - 09:42 am: |
Give it some time and you will wonder no more! |
New member Username: Traci
Post Number: 1 Registered: Sep-06
| Posted on Saturday, September 30, 2006 - 11:02 am: |
I received the Mitsuba MV300M as a B-day gift and it has worked fine for the last 6 months and still does with the exception of a problem that started a few days ago. I turn the camera on and everything in the display window looks like a picture negitive, but when I take the memory card out and view the contents on my computer everything looks fine. With the display window looking as it does it is very hard to see what I'm recording. Any suggestions other then it a piece of Crap, this I know alreay. Just would like to figure out what is wrong and find out if anyone else has had the same issue. |
New member Username: Tekmage
New York
Post Number: 1 Registered: Dec-06
| Posted on Monday, January 01, 2007 - 11:03 am: |
http://www.konaki.com/home.html Received a Mitsuba DV500 fo X-mas. Pictures and video are acceptable however, this thing doesnt compare to my 'old' 3.1 megapixel Fuji finepix. As many of you have found out, there is a warranty card included, but no address or phone #. Included is a 3.7v Li-Ion battery, and a box that is supposed to hold two double AA batterys...kicker is two AA batteries = 3v so you guessed it...useless. The CD only has the driver and NO aditional software. The manufacturer (or buyout co?} is KONAKI and according to their site this camera is a model DV7. So my Mitsuba LV500 is actually a KONAKI DV7. Hope this helps some of you. If anyone can find any additional info or usefull tips on operating this camera kindly mail me - aescallier@hvc.rr.com http://www.konaki.com/home.html |
New member Username: Jill1119
Post Number: 1 Registered: May-07
| Posted on Wednesday, May 23, 2007 - 03:44 pm: |
I have a Mitsuba MV300M. The toggle switch/button that moves the "cursor" to different pictures and menu items now only goes side to side, not up and down. Therefore I can not delete any of my pictures, as the "cursor" won't go down. After reading all these posts, I don't have much confidence I'm going to get this fixed. But if anyone can help, please post your response for me. Thanks. |
New York
Post Number: 2 Registered: Dec-06
| Posted on Wednesday, May 23, 2007 - 06:44 pm: |
Remove the SD card, place it in your PC or printers SD slot, and delete your photos that way. Or if your using the internal memory have you tried the master reset? |
Post Number: 2 Registered: May-07
| Posted on Thursday, May 24, 2007 - 09:50 am: |
Thanks Adam! I never thought of that, I'll give it a try. Now if I can FIND my PC's SD slot...(I'm not much of a techie...) |
New York
Post Number: 3 Registered: Dec-06
| Posted on Thursday, May 24, 2007 - 06:14 pm: |
If you have a media(SD) card reader on you PC its usually found on the front panel, above or below the CD drive. You may not have one. If not, check your printer. Most of the newer HP printers for example have card readers built in. And if all else fails run over to radio shack/Circuit City/or a Best Buy and pick one up. While there look for a better camera... |
New member Username: Okenglish
Post Number: 1 Registered: Apr-08
| Posted on Saturday, April 26, 2008 - 05:58 pm: |
Do anyone know where I can find the plastic battery box "Powerbox" for my Mitshuba DV-304? The box just melted. My husband bought this camcorder for my birthday and now it is no good to me. We found it a pawnshop which the tag on it said "CANON". For the money I thought that I was getting a good deal as well as a very good camcorder. Boy was I wrong. Took it back to the pawnshop and show them what had happen and I was told to call Canon. Called Canon told them what had happen and they told me that they did not make this camcorder. Searching the internet I discovered the real name of the camcorder and that is "MITSUBA". Someone had stuck the labe Canon on the camcorder. Now I have a camcorder that is totally 100% useless, however }unless I find a "Powerbox". |
New York
Post Number: 4 Registered: Dec-06
| Posted on Tuesday, April 29, 2008 - 09:53 pm: |
TJ Contact Mitsuba support directly. Here is the link: http://www.mitsubausa.com/contact.htm |
