Thread: Nikon D70 |
Steve Louseiu Unregistered guest |
| Posted on Tuesday, February 08, 2005 - 02:26 pm: |
Is there a mirror lock up on the nikon D70? |
| Posted on Wednesday, February 09, 2005 - 12:02 am: |
Please, Some one help me out?!?! |
Post Number: 2711 Registered: Dec-03
| Posted on Wednesday, February 09, 2005 - 07:36 am: |
No mirror lock-up. |
New member Username: Vlkers7171
Downers Grove,
Illinois
Usa
Post Number: 4 Registered: Feb-05
| Posted on Wednesday, February 09, 2005 - 05:00 pm: |
Berny, or Steve I've seen mirror lock-up on some cameras. What exactly is it for? |
Post Number: 2715 Registered: Dec-03
| Posted on Wednesday, February 09, 2005 - 05:45 pm: |
For taking extra long exposures and to keep the pictures from blurring when taking said extra long exposures. When the mirror on a SLR goes up and donw to expose the scene to the sensor or film, it causes a vibration and translate to the final picture.
Post Number: 2716 Registered: Dec-03
| Posted on Wednesday, February 09, 2005 - 05:49 pm: |
Keith, Here's a better explanation of mirro lock up and its advantages. http://www.photo.net/photo/nature/mlu PS- Are you in anyway related to anybody in the USAF Spec Ops?? |
Downers Grove,
Illinois
Usa
Post Number: 5 Registered: Feb-05
| Posted on Wednesday, February 09, 2005 - 06:44 pm: |
thanks...To my knowledge I am related to no one in the USAF Spec Ops. Ill ask my parents though, you never know. Thanks, Keith Vlk |
| Posted on Thursday, February 17, 2005 - 07:43 pm: |
The Nikon D70 does have MLU, what are you guys talking about. |
Post Number: 2753 Registered: Dec-03
| Posted on Thursday, February 17, 2005 - 08:22 pm: |
Yes, you can have the mirror lock up when cleaning the sensor. But in this case, Steve is probably refering to a mirror lock up or pre-release when taking extended long exposures. |
| Posted on Thursday, February 17, 2005 - 08:59 pm: |
Oh, yes no pre-release for the D70, maybe the next fireware update will take care of that. Sorry didnt mean to be harsh. |
| Posted on Thursday, February 17, 2005 - 09:01 pm: |
"firmware" |
bob utterback Unregistered guest |
| Posted on Wednesday, February 23, 2005 - 12:05 am: |
what is the buffer size on the d70? Thank you in advance to all who will answer |
Downers Grove,
Illinois
Usa
Post Number: 9 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 12:06 am: |
144 I believe...i'll wait for berny to verify this |
Downers Grove,
Illinois
Usa
Post Number: 10 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 12:09 am: |
ok....maybe its a 12..but you can write up to 144 continuous..i dont know...I just got mine |
Post Number: 2768 Registered: Dec-03
| Posted on Wednesday, February 23, 2005 - 07:53 am: |
At 3 fps it is about 12 images. On RAW mode it is only 4. But if you are using normal jpg it can go up to 144 if you are using a fast card. Keith, I see you are reading the manual! Lots of info, whew! |
Bronze Member Username: Vlkers7171
Downers Grove,
Illinois
Usa
Post Number: 11 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 02:22 pm: |
the manual is sooo long. But i figured since i spent the money i might as well take the time to understand all the features. |
Downers Grove,
Illinois
Usa
Post Number: 12 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 12:06 am: |
berny....is there a cable release for the D70. Someone told me there was only a remote release through the IR sensor |
Post Number: 2779 Registered: Dec-03
| Posted on Thursday, February 24, 2005 - 07:18 am: |
Nope, no cable release. You use a hand held remote ML-L3. You can get it for less than $20.
Downers Grove,
Illinois
Usa
Post Number: 13 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 02:07 pm: |
thanks....can you control the length of the shutter like a cable release can? |
Post Number: 2786 Registered: Dec-03
| Posted on Thursday, February 24, 2005 - 05:57 pm: |
Yes you can. You can even control it by clicking the remote to open the shutter and then clicking it again to close it. |
Downers Grove,
Illinois
Usa
Post Number: 14 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 06:30 pm: |
amazing....I want to get some cool night shots with like 2 minute exposures...So I need something like that...Thanks man |
Post Number: 2788 Registered: Dec-03
| Posted on Friday, February 25, 2005 - 07:21 am: |
I believe you can also use a programmable TV remote as your trigger. I have heard a few that tried it and apparently it works. There was a time when the ML-L3 remote was sooo hard to find. A lot of people were scrambling around for something else to use during the shortage. |
chrissu Unregistered guest |
| Posted on Tuesday, March 08, 2005 - 12:19 am: |
How do I get my ML-L3 remote to work with my D70? |
Post Number: 2813 Registered: Dec-03
| Posted on Thursday, March 10, 2005 - 07:45 am: |
page 107-110 of your D70 Manual. |
New member Username: Crit
Holland,
OH
Post Number: 2 Registered: Apr-05
| Posted on Tuesday, April 12, 2005 - 01:09 am: |
so Berny...what dont you know? haha |
