Thread: Nikon D70 - PictureProject software |
New member Username: Kathy
Post Number: 1 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 12:23 pm: |
I recently pruchased the Nikon D70 and am trying to get the PictureProject software loaded on my Dell/XP/system. I am getting an error message from Install Shield referencing a SetupDLL file. NO ONE from Dell, Nikon, or Ritz/Wolf Camera has been able to come up with a solution. Anyone have any ideas? Is there other/better software that I should look at? |
Post Number: 2510 Registered: Dec-03
| Posted on Thursday, January 20, 2005 - 12:57 pm: |
is this the error? "WnPAPI32.dll" Do you have Nikon View as well? Make sure you remove it prior to installing Picture Project. A better software would be Adobe PhotoElements, Picture Project is useless. |
Post Number: 2511 Registered: Dec-03
| Posted on Thursday, January 20, 2005 - 01:06 pm: |
Come to think of it I would highly discourage you from installing Picture Project. Too many bugs and not very user friendly. Just use NikonView to view your pictures and use a different program to edit the pictures. Also use a card reader to transfer your photos, the USB on the D70 is very slow. |
Post Number: 2 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 02:07 pm: |
Thanks - I was heading in that direction. The error code is: 5004:0x80070005 The error description is: "SetupDLL\SetupDLL.cpp(1924) pAPP:PictureProjectPVENDOR:NikonPGUID:FF3999BE- 1A7B-4738-88AA97BF14094A4A$7.1.100.1248@Windows XP Service Pack 2(2600) IE 6.0.2900.2180" Any ideas? What is Nikon View? I probably do NOT have it if it did not come with my camera and accessories. I DO have Adobe Photo Delux. Is PhotoElements better/different?
Post Number: 2514 Registered: Dec-03
| Posted on Thursday, January 20, 2005 - 02:18 pm: |
If you purchased the D70 go here http://www.nikonusa.com/template.php?goingto=dtc_options&cat=1&grp=2&productNr=2 5214 and this http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_alp.php?p_prod _lvl1=19&p_prod_lvl2=56&p_cat_lvl1=22 get the latest firmware. You should also be able to download the free NikonView software NikonView is a software that helps you organize and download the pictures from your memory card to the computer. I haven't used the Adobe Photo Delux, but Photoelements is an excellent program to manipulate your pictures, plus it has the plug-ins if you decide to take pictures in RAW format. |
New member Username: Lindas
Post Number: 1 Registered: Mar-05
| Posted on Wednesday, March 02, 2005 - 11:51 am: |
Hi - I am having a problem with emailing a .MOV - can anyone lend assistance? thank you, Linda |
Post Number: 2834 Registered: Dec-03
| Posted on Tuesday, March 22, 2005 - 01:08 pm: |
Linda, Have solved this? The file is probably too big and there are limits on some e-mail accounts as far as the file size is concerned. |
| Posted on Thursday, April 07, 2005 - 07:59 pm: |
I had just bought a Nikon D70. I am concerned if I can use the software on both my PC and on my Laptop. I do a lot of Editing at home on my PC. But I also Travel to many places taking Photos. And I would like to edit Photos while I am away from home. |
Post Number: 2901 Registered: Dec-03
| Posted on Thursday, April 07, 2005 - 09:45 pm: |
yes you can. |
