Thread: Camcorders And PC's |
New member Username: Charliejz
Post Number: 1 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 08:47 am: |
im thinking of buying a new camcorder but i want one that i can edit using my PC what camera and what software do you recommend? |
Post Number: 2509 Registered: Dec-03
| Posted on Thursday, January 20, 2005 - 12:22 pm: |
What are the capabilities of your PC? I don't care what they say about the minimum requirements on the software, you need at least 1G of RAM. You also need a firewire input on your computer. Forget USB 2.0 For the camcorder, you need a DV output. You also need a DV to IEEE1394 cable to attach the DV output of the camera to the firewire input of the computer. For software, there's Ulead or Adobe Premier(the best), Roxio...you pick. |
Bronze Member Username: Fishcca
Post Number: 38 Registered: Nov-04
| Posted on Sunday, January 23, 2005 - 03:39 pm: |
my new XP PC has a P4 with 512 RAM... Berny, This will not do? |
Post Number: 2538 Registered: Dec-03
| Posted on Sunday, January 23, 2005 - 06:57 pm: |
It will work, it will just be very slow. That is why I recommend at least 1 gig RAM. |
Post Number: 39 Registered: Nov-04
| Posted on Sunday, January 23, 2005 - 08:32 pm: |
good. Then I will start burning and be patient... Thanks again for the 10th time.. |
