Home > Message Board > Photography > Camcorders > Archive through June 24, 2005 > SAMSUNG SCD103
Author Thread: SAMSUNG SCD103
CAMILO
Hello, somebody can help me?
I have a Samsung SCD103 DV but when I tranfer the video to my pc it is stored as .asf type, and I don´t know how can I save before as MPEG, AVI or DVD format to burn it as a DVD.
Another problem is the quality the video is saved. I don´t know if it is software´s Problem (I used the software provided with de camcorder) or is the USB cable, or what it is!!??
Help!!
Thanks
erbear
I am looking into buying a Samsung SCD103 DV and am having trouble getting "real" feedback on it's performance. It seems like a good buy for the money--anything I should know about it (good or bad)????
Username: Project6
Post Number: 2553
Try using a good video editing software that uses industry standards and not proprietary codes.
Try Ulead or Adobe Premier or Pinnacle.
Use a firewire to transfer video from camera to computer.
Better yet, go directly from camera to DVD recorder.
Bennay
I have a SCD103 & I have not found one single problem with the camera. It has worked perfect every time for me. I feel that it is sort of a friendship thing - You treat the camera right, it'll work for you.
Home > Message Board > Photography > Camcorders > Archive through June 24, 2005 > SAMSUNG SCD103 [ « Previous ] [ Next » ]
