Thread: Sony DCR-HC40E DVD burn |
New member Username: Madman10
Buckingham UK
Post Number: 1 Registered: Jan-05
| Posted on Monday, January 03, 2005 - 05:11 pm: |
I have noted everyone saying that the supplied Sony software is useless, so have used Roxio DVD builder to cature the video files. I have a problem however whenever I send the file to DVD, my PC or DVD player wont play the file in either MPEG or AVI format. I have used DVD- discs. I have set up a custom setting to burn, with PAL, no compression, 320x240. I dont know what else to try. Anyone got any ideas ??????? |
Post Number: 2310 Registered: Dec-03
| Posted on Monday, January 03, 2005 - 06:28 pm: |
You have to use media that the DVD player can recognise. Youhave different kinds, e.g., DVD-R, DVD+R, DVD-RW, DVD-RAM, etc. You also have to make sure that the disc is finalised. |
