Home > Message Board > Photography > Digital Cameras > Archive through May 28, 2005 > What's the best brand memory card to ...
Author Thread: What's the best brand memory card to use?
tonigurn
I have an HP Photoshoot camera, and my memory card fried and lost all my Christmas pics! Could it be the camera, or the memory card? It was a SanDisk SD card.
Are there other brand memory cards that are better than others?
Thanks so much!
Username: Project6
Post Number: 2242
SanDisk Ultra II or SanDisk Extreme.
tonigurn
Thanks so much for your reply!
So it's not the brand that's bad, but the kind of card? I know the one I have isn't an Ultra or Extreme.
Username: Project6
Post Number: 2249
You know you have a warranty on those memory cards. SanDisk is not a bad card, it is rated at how fast a device can write to the memory. If something went wrong, it is usually a device error.
Home > Message Board > Photography > Digital Cameras > Archive through May 28, 2005 > What's the best brand memory card to ... [ « Previous ] [ Next » ]
