Thread: Problems with Pixela software :/ |
New member Username: Smekla
Post Number: 1 Registered: Nov-04
| Posted on Tuesday, November 09, 2004 - 04:13 pm: |
Hello, when i want to capture all the movie from my Sony cam to my p.c. it records maximum 10-15 minutes of video and writes that it's not enough free space in my hard disc, but there are ~23 GB of free space in my hdd. what's the problem? (when capturing, i used 'normal' quality) |
Relevant Product Info
Unregistered guest |
| Posted on Friday, December 31, 2004 - 04:42 pm: |
Hi, I have a similar problem to you but I have 150 GB free space. Someone out there must have the answer ! |
| Posted on Sunday, April 03, 2005 - 11:28 pm: |
Hi, same problem here. Updating the USB driver (from Sony website) did not help. I hope someone has an answer out there. |
New member Username: Reedrosa
Post Number: 1 Registered: Apr-05
| Posted on Saturday, April 09, 2005 - 11:13 pm: |
Same problem here. Anyone find the solution yet? |
Narasimha Murthy Unregistered guest |
| Posted on Tuesday, May 10, 2005 - 02:16 pm: |
Hi, I too have the same problem, but the work around i can suggest (which worked for me) is to capture the video upto 12 mins (about 300 MB), which will save the video to a file and continue from that point again. Little painful, but works!! Actually, the error message is misleading, and i think the cause of the problem is the file size that this video capture software can handle (having in memory).
| Posted on Monday, May 16, 2005 - 03:32 am: |
how to download Pixela Imagemixer Ver. 1.6 driver for sony
| Posted on Saturday, May 28, 2005 - 01:58 pm: |
hi there can anyone help, using imagemixer 1.7 with jvc mini dv all the drivers load and i am able to control the camcorder etc from my computer, converts image data and sound data but then comes a notice saying easyvcd has caused an error and will now close. the program then closes and i go back to my desktop |
New member Username: Javiersantosr
Post Number: 1 Registered: Jun-05
| Posted on Friday, June 03, 2005 - 06:41 pm: |
Hello, when i want to capture all the movie from my Sony cam to my p.c. it records maximum 10-15 minutes of video (about 300 MB) and writes that it's not enough free space in my hard disc, but there are ~60 GB of free space in my hdd. what's the problem? (when capturing, i used 'normal' quality) |
| Posted on Monday, June 20, 2005 - 02:52 pm: |
I found this solution on a forum that I am not registered but it seems the credit should go to Mike Daly. However, it didn't work for me but it seems it fixed the problem for everybody else. I am still hoping it will work after I reboot my PC. In muy case I could capture the whole tape (1 hour with Pinacle but I ended up with a 13 GB file which I ca't fit on a DVD. So I am trying to get the whole movie saved as mpg1 using Imagemixer I would appreciate if anybody can give me any input. My PC run under XP with 80GB free space. Re: Sony Handycam capturing images to computer [posted on: Jun 8, 2005 4:49 AM by mike daly Reply I saw the problem you and others were having with image mixer. I found the solution for this problem. I had to search high and low as well as translate the page from a different language. Well anyways I hope this helps everyone. -click START -click RUN -type in REGEDIT -click on HKEY_Local_Machine -click on software -click on pixela -click on Image Mixer for Sony -click on input -click on USB Control 01 -click on USB AVI Limit -Type in a (0) in place of the (1) -click OK XP users your problems solved
New member Username: Mrocho46
Toronto,
ON.
| Posted on Thursday, June 23, 2005 - 09:18 am: |
I have never had a software problem like I've had since installing the Pixela software for my Sony DVD Camera. I've managed to burn one DVD and now all I get is this message saying Explorer has encountered a problem and will shut down. I've tried everything I can think of including totally removing the software and re-installing it, to no avail. Has anyone else had this problem? I'm running Windows XP. |
| Posted on Saturday, June 25, 2005 - 02:10 am: |
I too am receiving explorer error messages everytime that I try to do anything in Pixela. Running XP. Any ideas? |
| Posted on Thursday, June 30, 2005 - 09:59 pm: |
well my sister installed pixela this morning and when i went on my computer no videos work in window media player has anyone had or heard of this? |
| Posted on Sunday, July 03, 2005 - 01:40 pm: |
I am new to this.My Pixela is telling me CDR does not exist! |
Toronto,
ON.
Post Number: 2 Registered: Jun-05
| Posted on Sunday, July 03, 2005 - 04:55 pm: |
Well I managed to solve one problem with Pixela. At least now I can finally burn a DVD, but it takes forever and you have to keep saving. I did try to use MyDVD to burn a saved DVD from Pixela, but although I was able to make the DVD, I had no audio. But at least I was finally able to make a DVD from 3 mini-disks. If you try to add music to it, it takes forever to prepare to burn, I'm talking hours. |
| Posted on Tuesday, July 05, 2005 - 02:52 pm: |
I have installed Sony Imaging Software rev 1.6, which came with DSC S40 Sony Camera. As soon as I have done it, I have lost access to all COM Ports. Apart of this, when I try to check Control Panel, System, Hardware, Device Manager, all I see is an empty page... I can not access my modem, therefore Internet. ... Any ideas? Quite a big surprise from a known manufacturer... I am using Dell Notebook with Windows 2000 Professional. Any ideas? |
| Posted on Wednesday, July 06, 2005 - 05:45 pm: |
I have installed this software which came with my JVC camcorder but will not detect it for what ever reason. I have tried to re-install it on numerous occations but still no joy. All the software is working OK but will not pick up my camcorder (gr-dx67ek) |
ben rethual Unregistered guest |
| Posted on Friday, July 08, 2005 - 02:53 am: |
Try copying the file "XP" from Pixela and saving it in a different location on yr pc, eg MyDocs etc. Reboot and then connect the camcorder and it should be ok. If not Install "xp" from where you saved it if asked. Any help on why direct burn is only for 20 mins and how to overcome this?
| Posted on Thursday, July 28, 2005 - 02:33 pm: |
hi! one question: "-click on input" --> i dont have this order! does anybody know why? i´m from germany an my english istn the best, so please answer in simple phrases. thanks. bye, jana
| Posted on Thursday, July 28, 2005 - 02:38 pm: |
sorry, i mean "sentence" and not "phrase" .. i ever confuse this two words... jana |
Andrew83 Unregistered guest |
| Posted on Saturday, August 13, 2005 - 06:20 am: |
Hi, I've got ImageMixer DVD2 (upgraded from software provide with Fuji FinePix). Whenever I try writing to DVD/creating disc image, it gets all the way through the 'editing contents' phase, but when 'creating disc image' it gets varying amounts through this task and then the progress window just dissapears. It is then as though you never clicked the write button......with the exception that there is a new empty blank folder called DVD image in the location specified for saving the disc image! Can anyone help?!? Many thanks! |
| Posted on Saturday, August 13, 2005 - 08:54 am: |
Update! Have made some progress....if I select my "video/TV format" to be NTSC as opposed to PAL, the process completes successfully 100% of the time! However, each time when attempting to use PAL it fails each time. Does that help anyone in suggesting a possible solution to my problems (I want to use PAL)? Thank you very much, Andrew |
| Posted on Wednesday, September 21, 2005 - 03:23 pm: |
Hi, I'm trying to create a still picture from a movie file using Image Mixer 1.0 that came with my Sony F717. I clicked on "export within album as new picture" and navigated to the frame I wanted to save, but when I view the picture that was created, it is a different frame than the one I want. I can drag the slider to the frame I want, but if I just play the movie it only plays the first 10 seconds, and the still picture I want to create is about 50 seconds into the movie. Can someone help? Thanks |
unregistered Unregistered guest |
| Posted on Sunday, October 02, 2005 - 06:15 am: |
Hi, when i try to use the Imagmaker it says's CDR not found why is this .. Altough i have tried it on various CD writers . is there anybody for help ? who has encountred the same problem ? pls mail me mohdmoulana@yahoo.com Thanks |
| Posted on Wednesday, October 26, 2005 - 03:17 pm: |
I'd be really grateful for any help. When I try to make a VCD using ImageMixer VCD2I get the message #=[ IM06007 ] Failed to write CDR. -10. I can't find what the message means. Anybody come across this problem?
| Posted on Monday, November 07, 2005 - 10:43 am: |
Please help to locate ImageMixer 1.5 installation file. I do own TRV355E Handycam 8, but has lost the driver CD. Now that I own a PC, I want to connect the two for Video Editing and I need this driver very urgently. I have a update download from Sony Asia. I will appreciate if someone can add a link to my e-mail address for downloading. Thanx Barax |
| Posted on Friday, November 18, 2005 - 05:38 pm: |
evening all I have a Sonydigital handycam which came with a pixela image mixer I`ve been trying for bleedin hours to get the ver.1.0 to work it keeps coming up as cam corder not found. HELP PLEASE. |
| Posted on Wednesday, December 28, 2005 - 03:49 am: |
Pixela supports only 15 mins of recording from USB, this has been stated in the FAQs section of imagemixer.com site. You have the option of joining the 15 mins pieces of video together in the movie editing section. Question: I am not getting the sound when i play it on the imagemixer software. Any remedies ? And how good is the Mini DV usage ? Does it enhance the quality ? I am planning to buy a IEEE 1394 cable Also the size of movie is 25 MB for 1 min of video. Please do let me know your answers @ alprashanth@yahoo.com
| Posted on Thursday, December 29, 2005 - 01:51 pm: |
Just got Sony DCR HC21 camcorder with Imagemaker software. I successfully transferred some video to computer with USB connection, captured and saved short clip (about 30 sec's) then tried to email it. File of that short video clip was SO HUGE (165 Mg)that server refused it. How in the world can I make a short clip that can be email'd? |
Mike Orange G. Unregistered guest |
| Posted on Friday, December 30, 2005 - 08:33 am: |
Help me please! I have a Soncy DCRHC30. Using Windows XP, I have tried PicturePackage ver. 1.0 and 1.5, able to install either version, camcorder hardware is found but when I attempt to write to CD-R, I receive error message that there is not a recordable CD-R in the CD writer. Also, ver 1.5 seems to cause XP OS instability. Any ideas? |
| Posted on Friday, December 30, 2005 - 08:35 am: |
Help me please! I have a Sony DCRHC30. Using Windows XP, I have tried PicturePackage ver. 1.0 and 1.5, able to install either version, camcorder hardware is found but when I attempt to write to CD-R, I receive error message that there is not a recordable CD-R in the CD writer. Also, ver 1.5 seems to cause XP OS instability. Any ideas? |
| Posted on Thursday, January 12, 2006 - 04:08 pm: |
I AM GOING TO COMPLAIN TO SONY..ALL THE PROBLEMS WE ARE ALL HAVING IS COMPLETE BS! NOT THAT COMPLAINING WILL DO ANY GOOD |
Ameer A.H. Unregistered guest |
| Posted on Tuesday, January 24, 2006 - 05:07 pm: |
When I try to add my sony handycam as a new hardware, the original disk "delivered with my camera from local agent" is accepted and everything is OK with MICROSOFT MELLINIUM. But the roblem is that the setup is not completed in WINDOWS XP.I tried several times but I faced the same problem. I've contacted my local agent and he told me to contact you. Many thanks and best regards. YOURS AMEER A.H. |
| Posted on Tuesday, January 24, 2006 - 05:23 pm: |
When I try to add my sony handycam as a new hardware from the CD delivered from local agent with my camera, everything is OK with WINDOWS MELLINIUM but the problem is that the setup is never completed in WINDOWS XP and some sort of error occurs . I tried several times with sevral editions of XP but the same problem . What should I do and I think the problem is in the CD. |
| Posted on Friday, February 10, 2006 - 02:32 pm: |
Hi, I have lost the driver CD which came with my sony DCR TRV 355e. Can any one help me buying a spare one or a link from where i can download the programme. please please help |
| Posted on Wednesday, February 15, 2006 - 07:41 pm: |
I have Pixela Image Maker 1.7 which came with my JVC camcorder. When I try to burn a CD it will not allow me to vary the burn speed from the max x40. The burn speed box only contains this one speed Can anyone help with a solution. If I burn at this speed nothing comes out. |
| Posted on Wednesday, February 22, 2006 - 05:31 am: |
I am looking for ImageMixer Ver.1.5 for Sony DVD Handycam software to download onto my computer, using Windows XP. Can somebody help me? Leon from South Africa, Pretoria |
| Posted on Saturday, February 25, 2006 - 07:03 am: |
I noticed a lot of people got problems with burning. My old cd-burner worked fine but died and now with my new one it is not working anymore, it says CDR not found. I've tried the update but this is also not working. Can someone please help? Many thanks in advance |
New member Username: Digital_man16
Post Number: 1 Registered: Feb-06
| Posted on Monday, February 27, 2006 - 08:15 pm: |
Hey i just got my DSC-S40 and it says "turn power off and on again", everytime i do that it says the same thing! Does anybody have any suggestions? I really need help on this! Thank you if you helped! |
moragamur Unregistered guest |
| Posted on Friday, March 03, 2006 - 01:15 am: |
Hi, I have Sony TRV140. I want to create DVD from Sony Tape. Insatlled the Pixela software and driver. Connected the TRV140 using USB cable. My computer XP recognized it. I have to make a small file 1 by 1 one. But I did not get sound at all. What is the problem? Do I have to do any setting? |
antoniooo Unregistered guest |
| Posted on Saturday, March 04, 2006 - 11:40 am: |
hi. I also have that camera (sony dv ....mpla mpla) and i want to ask if anyone knows how can i hear and copy the sound. I use imagemixer 1.5. I have no problem with the image. I can see and make a copy of that but i can't even hear the sound. be on the tapis to get the sound from a different connection? |
| Posted on Saturday, March 04, 2006 - 11:43 am: |
aaaa my email address: coconaros@yahoo.com thanks |
New member Username: Romieroach
Post Number: 1 Registered: Mar-06
| Posted on Wednesday, March 08, 2006 - 01:30 pm: |
Hi I bought the dcr-dvd201 software but I do not have the disk. Imagemixer sofrware that is ver 1.5. Is there anyone that can give me links to this. or obtain a copy from somebody? I will pay for it. Thanks. email me at champion_lover_forever@yahoo.com |
New member Username: Bibincjoy
PATHANAMTHITTA,
KERALA
INDIA
Post Number: 2 Registered: Mar-06
| Posted on Wednesday, March 15, 2006 - 12:28 am: |
help me i bought a sony dcr hc42e recently. but unfortunately i missed the cd so was the picture package. please help me . can anyone post me the picture package ver 1.5 by attachment to my mail joelsibybin@yahoo.com. please help me . i would be thankful to you.
Post Number: 7002 Registered: Dec-03
| Posted on Wednesday, March 15, 2006 - 12:32 am: |
Why not buy the software yourself? You can do better than pixela. |
| Posted on Wednesday, March 15, 2006 - 09:35 am: |
What Software @ Berny? |
Post Number: 7020 Registered: Dec-03
| Posted on Wednesday, March 15, 2006 - 05:29 pm: |
Ulead, Adobe, Video Director, Pinnacle...all better than pixela. |
New member Username: Jkaustubh
Pune,
Maharastra
India
| Posted on Monday, March 20, 2006 - 02:47 pm: |
Post Number: 3 Registered: Mar-06
| Posted on Tuesday, March 21, 2006 - 09:55 am: |
is there a difference between dcr-dvd201 and dcr-dvd201E. My cam dcr-dvd201 does not detect on my pc. error comes up saying there were problems with the usb driver. ddxa1010 |
New member Username: Khemraj01
| Posted on Friday, March 24, 2006 - 11:02 pm: |
hi, can anyone pls suggest me how to download software from internet for my Sony DCR HC21 camcorder, I lost my installer CD. pls I am stuck without it.. pls reply me in khemraj01@gmail.com |
Post Number: 7206 Registered: Dec-03
| Posted on Saturday, March 25, 2006 - 08:50 am: |
Go to Sony tech support. Buy the software. Or you can buy a different photo editing software like Photoelements. The best thing you can do is actually buy software. |
| Posted on Saturday, March 25, 2006 - 05:11 pm: |
thanx Berny... |
New member Username: Quincyzr
Post Number: 1 Registered: Apr-06
| Posted on Saturday, April 15, 2006 - 02:37 pm: |
You all are doing better than me. I cannot seem to add music. It says drag over music file but program won't accept files. Please help! |
Post Number: 7453 Registered: Dec-03
| Posted on Saturday, April 15, 2006 - 05:26 pm: |
Make sure that the music is in the right format. |
New member Username: Owensie
Post Number: 2 Registered: May-06
| Posted on Wednesday, May 10, 2006 - 09:55 am: |
Hi, I have pixela installed on my friend's PC, downloaded the movies, then copied them to DVD and tried to play them on my Apple but they wouldn't play. I tried using CD/DVD. Do I need to install some file converting software?? Any ideas ?? |
New member Username: Maribago
Post Number: 1 Registered: May-06
| Posted on Saturday, May 20, 2006 - 12:53 am: |
The "not enough free space" message probably refers to space on a specific partition on the hard disc. Not space on the DVD disc and not space on the disc where you've originally stored the MPEG video. Be sure your temp directory disc (typically C:\ by default) has 150% of the size of your video files. Worked for me. |
New member Username: Cmh1780
Post Number: 1 Registered: Jun-06
| Posted on Wednesday, June 07, 2006 - 11:04 am: |
Help, I have tried to download video from my DCR PC5E camcorder to my PC using the ULead software and it tells me that no capture driver is installed? I am running out of hair to pull out, please advise |
New member Username: Nitinjak
| Posted on Tuesday, June 13, 2006 - 04:41 am: |
Hello, when i want to capture all the movie from my Sony cam to my p.c. it records maximum 10-15 minutes of video and writes that it's not enough free space in my hard disc, but there are ~23 GB of free space in my hdd. what's the problem? (when capturing, i used 'normal' quality)..pls reply to nitin@iitcoman.com |
Post Number: 2 Registered: Jun-06
| Posted on Tuesday, June 13, 2006 - 05:04 am: |
When I try to download DV from my Sony DCR PC5E to win xp via a firewire Ulead tells me no capture device detected??? I have spent 2 weeks via Dell support and Sony support to no avail----Pleeeeeese help me |
New member Username: Tpurankar
| Posted on Sunday, June 18, 2006 - 12:54 am: |
I got same problem as "nitin jakaty ", I feel this is pixela sw bug and we need to upgrade it to latest version. I need to place lots of my Video caps to the CD/DVD. Pls help people if anybody knows about this. |
New member Username: Maxlancer
Post Number: 1 Registered: Aug-06
| Posted on Friday, August 11, 2006 - 10:07 pm: |
Hi, new here, I just got a Sony DCR-HC21 camera, Im trying to make videoCD, but as soon I put a blank CD-R on my CD Writer it tell me that my Drive is empty, what could I do? |
