Home > Message Board > Photography > Camcorders > Archive through November 24, 2004 > Cable & Software for video transfers
Author Thread: Cable & Software for video transfers
Username: Selvan777
Hi all,
I'm new here and looking for advise.
I see a lot of questions answered in this forum like I need Firewire to transfer video.
I have a Sharp VL-Z5U which has a 4 pin DV terminal(IEEE1394), the manual mentions a DV cable.
My Adaptec DuoConnect for Notebooks has a 4 pin and a 6 pin Firewire port.
Questions:
1. do I use a "4 to 4" or "4 to 6" pin cable?
2. do I use a "DV to Firewire" cable?
3. do I use a "Firewire to Firewire" cable?
4. Windows Movie Maker or Ulead Media Studio?
Which software are you content with for video editing?
Thanks a bunch.
Selvan
Username: Hurricanejoe
I need some assistance. I just brought a new sony receiver and plan to hook this up to my TV. Heres what I have:
A 36" toshiba tv model cf36g50
a sony model str-de597 receiver
a audiosource eleven equlizer
a jvc dvd/vhs combo model xvc1u
a huges tivo sat. receiver recorder
1 jbl sub woofer
3 small kenwood speakers (rear left & right plus a front center)
2 skyline speakers (pretty big)
Please help me get this stuff straight.
Username: Selvan777
Hi Joe Echols,
Thanks for the reply but could you please place your questions in a thread of your own?
I think Home Theater Setup & Planning is a more appropriate forum to post in.
Go to the link below and click on "Start New Thread" above the latest thread.
http://forum.ecoustics.com/bbs/messages/3/8607.html
Username: Project6
Post Number: 1763
"1. do I use a "4 to 4" or "4 to 6" pin cable?
3. do I use a "Firewire to Firewire" cable? "
Selvan,
I use a 4 to 6 pin cable, and all are called by any of the names you mentioned.
I used Ulead software to edit videos.
cheers
Username: Selvan777
Berny,
Thanks for the reply.
Regarding cable quality, do you think the cable linked below will do the job?
http://www.compusa.com/products/product_info.asp?product_code=50529610&pfp=SEARC H
Username: Project6
Post Number: 1771
it should work. Have you checked the manual on compatible cables?
Username: Selvan777
Berny,
Thanks again for the reply.
At that price, I have not much to loose. The manual says it's a DV terminal an than in brackets (IEEE1394). I called them and they said either a 4-4 or 4-6 would work as long as it's a part# IEEE1394, it's hardly a part# but I got the message.
Thanks a bunch for the support.
My next step would be to pick the software that'll make VCD or SVCD movies, I was thinking TMPGE Plus V2.58, what do you think?
P.S. I got Ulead MediaStudio Pro 6
Username: Project6
Post Number: 1772
Sounds like you are on the right track, but I have not used TMPGE so I can't tell you if it is good or not.
Username: Selvan777
What would you recommend for ripping VCD's, would Ulead do the trick?
Home > Message Board > Photography > Camcorders > Archive through November 24, 2004 > Cable & Software for video transfers [ « Previous ] [ Next » ]
