Home > Message Board > System Showcase > Best bang for your buck surround sound
Author Thread: Best bang for your buck surround sound
Username: Cutlassaapower
I have future plans in setting up surround sound and am looking for suggestions on the best bang for your buck.
My budget is around $300, but Im willing to go higher.
Username: Tunasalad
California
US
Post Number: 144
Hi,
The bragging area is for bragging about your setup, but anyway, for $300, your are probably looking at a Home Theater in a Box. They are anywhere from $100-700 and the usually come with a DVD player/amp, 5 speakers, and a subwoofer. HTIBs are good starter systems, but if you plan on upgrading, the parts are usually non-transferable. The other options are either buy a really nice HTIB that you won't need to upgrade, or to pick and choose. The two things that you need to decide on now are exactly how much you want to spend, as well as whether or not you will be upgrading any time soon. Keep asking and we'll help you.
Stefan
Username: Deadhorse
Post Number: 80
Bang! Can't go wrong.
http://www.amazon.com/Onkyo-HT-SR800-Component-Theater-System/dp/B000O8E8YW/ref= pd_bbs_sr_1/104-9935769-3492727?ie=UTF8&s=audio-video&qid=1178882686&sr=1-1
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > System Showcase > Best bang for your buck surround sound [ « Previous ] [ Next » ]
