Thread: 97 Jeep Wrangler |
Bronze Member Username: Mesodumm
Dewey,
Az
Usa
Post Number: 18 Registered: Apr-07
| Posted on Tuesday, May 01, 2007 - 11:50 am: |
This is my 97 Jeep Wrangler, its got 2 12" M3MOJO12 in 3.44 cu ft ported box tuned at 38hz with a mcd1500 1500 watt at 2 ohm running them. 3 pair 6.5 coaxial 15-msc, 1 pair 4x6 coaxial 15-mc4.6, ran by a mca5004, with a VR3 VRCD400-USB cheap deck but works great never a single problem with it!!
Gold Member Username: Denali_on_22s
Hit you in the chest m...
Post Number: 2254 Registered: Feb-06
| Posted on Tuesday, May 01, 2007 - 12:57 pm: |
looks nice man |
Gold Member Username: Trey4sports
Post Number: 1054 Registered: Sep-06
| Posted on Tuesday, May 01, 2007 - 03:01 pm: |
clean install bro, looks good all the way around, but are you sure you wouldnt rather have an 18" 06 RE XXX ?? |
Dewey,
Az
Usa
Post Number: 21 Registered: Apr-07
| Posted on Wednesday, May 02, 2007 - 01:21 pm: |
Hey Thanks!! Reese and Trey,, do you have pictures I like looking at other systems gives me ideas on what to do next!! I have been working on my wifes Jeep lately, she is mail carrier with 2006 Wrangler, she can't loose any room so I did 1 12" behind seat, 1/3 of air space is under seat and fiberglassed into side wall. I'll post a pic so you can see. While I do that put some of your up!!!!! Thanks again! Chad |
