Thread: Alpine type r |
New member Username: Kory_m
Post Number: 2 Registered: Apr-07
| Posted on Tuesday, April 03, 2007 - 11:52 pm: |
i have two 12 inche alipne type r subs and a 600w alpine v12 amp is that enough to power both of the subs |
Gold Member Username: Blainew
Post Number: 2370 Registered: Nov-05
| Posted on Sunday, July 08, 2007 - 05:14 pm: |
no |
Silver Member Username: Kpa2727
Post Number: 310 Registered: May-07
| Posted on Sunday, July 08, 2007 - 05:19 pm: |
nope only 300 watss to each woofer that would give, i'm giving mine 600 rms to one and it's not enough. |
Bronze Member Username: Sqcheap
Grand rapids,
Michigan
Usa
Post Number: 26 Registered: Jul-07
| Posted on Monday, July 09, 2007 - 11:07 am: |
It will work, also depends on what enclosure you are using them in. No it might not max them out. |
Grand rapids,
Michigan
Usa
Post Number: 27 Registered: Jul-07
| Posted on Monday, July 09, 2007 - 11:11 am: |
Also depends on if that is 600w rms or not. The big old alpines put out pretty good, like the 1000. |
Post Number: 313 Registered: May-07
| Posted on Tuesday, July 10, 2007 - 02:36 am: |
ok but were talking on a safe level. yes 300 rms can make them move but not jump and kick like they should. and u come into the clipping/overdriving amp issues at really low rms. |
Grand rapids,
Michigan
Usa
Post Number: 31 Registered: Jul-07
| Posted on Tuesday, July 10, 2007 - 10:54 am: |
I agree. If you used a large ported or IB mounting then they would need less power for example. If you want max spl you will need a tighter enclosure and more power. If you are just listening to music 600rms should go pretty loud, 300rms will work but like Keith says the subs can give you more with the right power. My friend has I think a mrv1000 V12 alpine and it is not overrated, I have seen them go for 200+ on ebay. Its the darker silver color with the thick fins. It is rated at 600rms. |
Silver Member Username: Wojopro
Summerville,
SC
Post Number: 258 Registered: Nov-04
| Posted on Tuesday, July 24, 2007 - 09:06 pm: |
Woah! Depends on which type r's you have. The new ones are rated for 500 watts rms. The older ones are rated for 300 watts rms. Or something like that... Trying to find the exact specs |
Post Number: 4 Registered: Apr-07
| Posted on Tuesday, July 24, 2007 - 11:32 pm: |
well i have had the subs for a good 4 months now and they sound so fricken sweet and i have won a couple battles wit them so they should be pretty good |
Silver Member Username: Dubmc23
Rapid City,
SD
Post Number: 129 Registered: Sep-07
| Posted on Friday, November 30, 2007 - 11:28 pm: |
same here i have probably a little over 600 rms goin to each one and they sound amazing... |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 13450 Registered: Jul-05
| Posted on Tuesday, January 01, 2008 - 04:34 am: |
a couple battles??? I dont get it? |
Silver Member Username: Sqcheap
Grand rapids,
Michigan
Usa
Post Number: 101 Registered: Jul-07
| Posted on Tuesday, January 01, 2008 - 12:27 pm: |
V12s are pretty good amps IMO, though I'm switching to newer class D to reduce power draw. |
Post Number: 5 Registered: Apr-07
| Posted on Tuesday, January 01, 2008 - 04:00 pm: |
like when you go to a sub contest you beat other kids with subs and that is what a battle is |
Huntsville,
Alabama
U.S.
Post Number: 13454 Registered: Jul-05
| Posted on Tuesday, January 01, 2008 - 04:17 pm: |
how do u tell who wins??? is it by ear?? Is there a meter?? Port wars?? I just wanna no the rules |
Post Number: 6 Registered: Apr-07
| Posted on Wednesday, January 02, 2008 - 01:23 am: |
there is a meter that measures something, and they give you a cd that you have to play and then who ever measures the highest on the meter wins |
Post Number: 7 Registered: Apr-07
| Posted on Wednesday, January 02, 2008 - 01:28 am: |
Gold Member Username: Naledge503
Http://www.LowDownForu... Zac Davis 4 ...
Post Number: 2554 Registered: Jun-06
| Posted on Wednesday, January 02, 2008 - 03:40 pm: |
what was your score? |
Silver Member Username: Somedonniedude
Illinois
United States
Post Number: 676 Registered: May-07
| Posted on Wednesday, January 02, 2008 - 08:54 pm: |
Can I play this game? |
Illinois
United States
Post Number: 677 Registered: May-07
Sorry I meant battle. |
Silver Member Username: Vc23
Fi ,
2 12 Fi Bls
U.s.a
Post Number: 242 Registered: Mar-06
| Posted on Wednesday, January 02, 2008 - 10:56 pm: |
haha... i want to play as well... but can i just scream as loud as i can....i know thats like 125 db at least and that should do it...... |
Illinois
United States
Post Number: 680 Registered: May-07
| Posted on Thursday, January 03, 2008 - 12:53 am: |
Just dont hurt yourselves, its hard to burp a 45hz tone from your vocal chords with out burning your throat |
Huntsville,
Alabama
U.S.
Post Number: 13469 Registered: Jul-05
| Posted on Thursday, January 03, 2008 - 03:16 am: |
yea...^^^I burnt my 0.98425inch vc's (vocal chords) the other day |
Grand rapids,
Michigan
Usa
Post Number: 105 Registered: Jul-07
| Posted on Thursday, January 03, 2008 - 11:48 am: |
You need some soda or other carbonated beverage...potato chips, and you don't use your vocal cords...still might be hard to hit 45. |
