Home > Message Board > System Showcase > Bballas system
Author Thread: Bballas system
Username: Rosrock2000
AA Assassins, MI
Post Number: 387
2 12 assassins in tcabs with de i1100d.
This is how the thieves did to my car to brake in and steal ssd.
Username: Arande2
Extreme SQ FTW
Post Number: 2080
15kw + 100k-ohms = make it .01 ohm and get like a billion watts so you can power 100,000 LMS-5400s to Xmax at 40hz or 1 of them to Xmax at 1khz! That'd be crazy...1khz haha.
Alternatively you could create an isobaric subwoofer using 500k TC-5200s all lined up in push-pull to effectively create a motor force of 205,000,000 newtons²/watt total!!! It would also create an insanely low Qtc though...think of moving the decimal 30,000 places to the right...YEAAAH... the efficiency of the system would go way down as well...1 watt would only get you 37dB...of course with a motor force of 250 million newtons..
The power handling would go up to a few billion watts too...meaning a max motor force of 510,000,000,000,000,000 (five hundred ten quadrillion) newtons squared...............................................................that's a LOT of force you know.... If you were to spread that and NOT do isobaric then that would be a VERY high efficiency I'm guessing, in the higher hundreds maybe? I really don't know what I'm talking about I guess.
How does that have anything to do with your system? It doesn't!
AA Assassins, MI
Post Number: 394
i like sq to andre:-)
Username: Mercsable
Kalamazoo, MI
Post Number: 81
That looks almost like my set up, I have the exact same HU. My boxes are set up the same way, long narrow boxes with the subs facing up closer to the trunk opening. I had to do that because it was the only way 2 15s would fit in my trunk.
Username: Jkidder
Spring hill, Florida
Usa
Post Number: 506
where did u copy n' paste that from andre? ;)
A pic is worth
1000 posts!!
Post Number: 6087
Andre is a super genius packed into a child's body with the humor of a 40 year old man, on pain killers. He is what he is.
Andre, when are you movin' kid and how much have you saved for you're IB setup??
Username: Nvmyboom
Post Number: 308
ya, i had both of my ssd's stolen, theifs broke my window, no alarm on my car, stupid i know, just gettin ready to put one in too, no reason to now though,but
ur system looks great, nice
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > System Showcase > Bballas system [ « Previous ] [ Next » ]
