Thread: Acoustic treatment on a budget - my ideas |
New member Username: Nkotb
Marietta,
GA
Post Number: 6 Registered: Jul-04
| Posted on Monday, August 23, 2004 - 05:20 pm: |
OK, here's my setup - dedicated 14'w x 15'l x 8'h room located in corner of basement. Walls are sheetrock over soundboard, attached with anti-resonant clips, w/ sound-reducing insulation batts b/w the studs. The floor is carpeted w/ pad over the slab w/ 4 recliners in a row in the back 3rd of the room. I am considering the following for your opinions: Making absorptive door & wall curtains, and screen masking on front wall that continue into the corners, and along the side walls a couple of feet. What would you say if I made these curtains out of gathered Velux nylon poly-foam blankets? (http://www.mynautique.com/B00005OTJD-Vellux-Blanket-Amethyst-King.html) As for diffusers & absorbers - I like the concept of RPG's BAD Panels (http://www.rpginc.com/products/badpanel/) For Bass traps - I've seen these two options 1.http://www.rpginc.com/products/procorner/index.htm 2. http://www.auralex.com/bass_traps_lenrd/bass_traps_lenrd.asp What's would be my bang for the buck combo? Thanks! |
J. Vigne Unregistered guest |
| Posted on Sunday, August 29, 2004 - 07:04 pm: |
Corners and floor and ceiling intersections are where you get the most build up of bass energy. Treat those areas first with just enough material to get the response you want without sucking-out too much. There is little need to do the front wall all the way across in most applications. You can use a mirror and a flashlight to find the first reflection spots on your side walls, this is what you want to dampen more than anything. Wrapping the matrerial a few feet out into the room will accomplish very little unless your speakers sit directly against the back wall. The first reflection is usually several (4-5) feet out in front of the speakers. Absorptive material should be hung a few inches away from the wall with absorptive foam placed behind it. The more surface area the soundwaves pass through (and the more often you can make them pass through the material) the better for absorption. Placing material directly against a wall leaves no roon for reflection. By allowing a lowered bounce you get double the work for the same money. A corrugated foam is best for this application. Something that looks like the corrugated mattress toppers is the idea, the deeper the corrugation the better. These materials are often available from a foam rubber supply company at reasonable prices. Treat the rear corners and the area just behind your listening position and then decide on the diffusers. Often they are not needed unless the speakers overpower the space. With an 8' ceiling I would think about treating the ceiling with strips of absorptive material to cut the bounce from that area. As you start to tune the room a crude but effective tool to use is a stack of cardboard boxes stuffed loosely with newspaper. Stack these and place them in various locations until you are satisfied with the sound. |
New member Username: Bettyt456
Calgary,
Alberta
Post Number: 4 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 02:06 pm: |
I have mastering studio and I bought a full room acoustic treatment package at "Primacoustics". do a search for them in google. It cost about 600 CAN and it did a hell of a job. Improved my room alot. I also put a kit in my home theatre room. Amazing! |
New member Username: Mart1gen
Post Number: 1 Registered: Apr-05
| Posted on Sunday, April 10, 2005 - 06:59 pm: |
I've had similar problems, I'll try your suggestion Brent.
| Posted on Friday, April 15, 2005 - 10:43 am: |
I would try bass traps from Audiotec USA http://www.audiotecUSA.com. They did a fantastic job for me. |
Silver Member Username: Joe_c
Oakwood,
Ga
Post Number: 280 Registered: Mar-05
| Posted on Friday, May 13, 2005 - 10:18 pm: |
I covered my walls in black burlap floor to cieling. Looks great and does a good job on catching the sound. Only cost me 150 bucks too. Heres the picshttp://forum.ecoustics.com/bbs/messages/3/130158.html |
Scott Mayo Unregistered guest |
| Posted on Monday, May 23, 2005 - 11:19 pm: |
Where did you get the black burlap? |
Oakwood,
Ga
Post Number: 314 Registered: Mar-05
| Posted on Saturday, May 28, 2005 - 11:39 am: |
from hancock fabrics online. |
Bronze Member Username: Lowfront
Post Number: 43 Registered: Jun-05
| Posted on Saturday, June 18, 2005 - 11:00 am: |
Alright...Anyone else Suggest the burlap??...I was gonna try it out as a starter for my room... How do I know how much yards to get...?? my room measurements are here.... Walls are 7feet 6 inches high the back of the closet is 2 feet back anyone that takes the time it will be greatly appretiated...
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 4119 Registered: May-04
| Posted on Saturday, June 18, 2005 - 01:24 pm: |
Take your dimensions to the fabric shop; they will assist you. I would not suggest burlap, but that is simply a matter of personal taste and what you want the final appearance to be. What you want is a fabric which will allow a certain amount of signal to pass through to a padding underneath. I would suggest you look at the linens at the fabric shop and ask if they carry grill cloth. If the weave of the material is not open enough to let light pass through, like a grill cloth, you will reflect as many frequencies as you let pass. If you choose a heavier fabric or a tighter weave, hang it in loose folds and not stretched tightly across the wall. The folds will act as a diffusion material and break up the reflections. Be aware that damping low frequencies (beneath about 200Hz) is very difficult without large quantities of material. For these frequencies, other tactics are employed. |
Oakwood,
Ga
Post Number: 441 Registered: Mar-05
| Posted on Saturday, June 18, 2005 - 05:02 pm: |
only reason I did burlap is the price, and it doesn't look that bad either. I stretched it tight over the wall but left 1/4" of gap behind. It works good for my setup and I noticed a big difference because this same setup was in my livingroom before I moved it down here. Also Burlap is thicker than most other fabrics so that is another reason I thought it would work good. I guess I am just hurt by Jan's harsh words about my thrifty home theater. |
Oakwood,
Ga
Post Number: 442 Registered: Mar-05
| Posted on Saturday, June 18, 2005 - 05:03 pm: |
also I have pics of it here:http://forum.ecoustics.com/bbs/messages/3/130158.html |
Dallas,
TX
Post Number: 4126 Registered: May-04
| Posted on Saturday, June 18, 2005 - 05:23 pm: |
j.c. - Any harshness in my words was merely a reflection of the blantant disregard for the worldwide burlap shortage which has occurred over the last twenty years. There are children who will have to go without underwe@r and pillows to sleep on because of your greed for burlap. I hope you're happy! Unbelievably you cannot post the word underwe@r on this forum. |
Oakwood,
Ga
Post Number: 446 Registered: Mar-05
| Posted on Sunday, June 19, 2005 - 10:28 am: |
lol! pantie$ either |
New member Username: Donski
Surrey,
B.C.
Post Number: 1 Registered: Jul-05
| Posted on Tuesday, July 12, 2005 - 10:58 am: |
Hello all; this is my first posting. How does a person know if they have room acoustic problems? I replaced my wall to wall with laminate, it sounded bright so I placed a floor mat in front of each speaker on the floor. What else do I look (or listen) for. Bless the experts. |
Oakwood,
Ga
Post Number: 595 Registered: Mar-05
| Posted on Wednesday, July 13, 2005 - 06:48 am: |
Your on the right track. Try and move those rugs around and see how it sounds when placed differently. Also if you can hang acoustical treatments on the walls such as tapestries or even acoustic panels (if the wife doesn't mind) to dampen the sound. The main I dea as you probably have already realized is to prevent the sound from bouncing all over the place. Use your ears, they will serve you well. |
New member Username: Maze
Post Number: 2 Registered: Aug-05
| Posted on Wednesday, August 10, 2005 - 03:56 am: |
ok i'm a newb in isolation old time drummer. thinkin of havin 2 layers 2" each of isolating rockwool with sheetblock and guypsum boards. what i was thinkin is should i put one layer on my existing wall and the other one on the gypsum wall parallel to it leaving space there? or would it be much better if i have one on gypsum then space then the second layer then another space then my existing wall? |
New member Username: Croco
Post Number: 1 Registered: Aug-05
| Posted on Friday, August 26, 2005 - 09:08 pm: |
i have connected my computer to the amplifier and i just want to find if the sound is not going to damage the sound card for my computer. Anyone with idea. |
Silver Member Username: Cheapskate
Post Number: 512 Registered: Mar-04
| Posted on Sunday, November 13, 2005 - 09:44 pm: |
i just went to a local department store and picked a couple of $8 foam egg crate matress liners up for my asymmetrical side walls. i'm thinking of picking another one or two for my front wall too for a LEDE setup. acoustical tiles are crazy. it cost me $50 just for 5 small 3" and 4" wedges to line my sub cabinet. |
New member Username: Ehwwong
Post Number: 1 Registered: Nov-05
| Posted on Sunday, November 20, 2005 - 12:13 pm: |
hi, i am using gcd acoustic foams and they are priced quite reasonably.. for 42sq feet, i only paid USD149.. www.gcdacoustic.com check them out if you are on budget.. like me..  |
New member Username: Jasev
Post Number: 1 Registered: Apr-06
| Posted on Monday, April 24, 2006 - 10:55 am: |
Here's another acoustic treatment supplier in the uk also with very reasonable prices, www.acoustic-foam.co.uk they are part of a large foam company called comfortex in oldham uk |
Bronze Member Username: Willieman
PR
Post Number: 52 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 03:47 pm: |
New member Username: Comfortex
Post Number: 1 Registered: Oct-06
| Posted on Tuesday, October 03, 2006 - 09:31 am: |
we now have test data avaliable online for comfortex acoustic foam tiles and bass traps http://www.acoustic-foam.co.uk/testresults.pdf Specialists in acoustic treatment for studios and live rooms and home cinemas. |
Post Number: 2 Registered: Oct-06
| Posted on Tuesday, October 03, 2006 - 09:35 am: |
to see the current range of acoustic treatment please visit www.acoustic-foam.co.uk or to see what we have on offer direct to the public see our ebay shop we will deliver to europe but please ask for a quote on postage first http://stores.ebay.co.uk/Comfortex-Foam_Acoustic-Foam |
New member Username: Harrycunninghamgooglemailcom
Post Number: 1 Registered: Nov-07
| Posted on Sunday, November 18, 2007 - 11:23 am: |
Hi all, I'm new to sound proofing, I would like to sound proof my basement room to allow my son and his mates to carry out band practice. I have never done anything like this before but I'm willing to have a go at most things. I would appreciate any help or suggestions you might have. |
New member Username: Lock1347
Newburgh,
Indiana
US
Post Number: 1 Registered: Jan-08
| Posted on Monday, January 14, 2008 - 01:13 pm: |
I'm new to this site and I am have trouble following the way to posting my own post in the proper place. I just wanted to warn everyone about ordering from XDIMAX, I ordered a video stabilizer on Jan. 2, 2008, and have not received it as yet, Jan.14, 2008. Nor did I get a valid tracking number from them. What I did find out is that this company is in Israel, and the order comes by Israeli Postal Service. After I had all ready ordered, I then found this out, also that I must wait up to three weeks for delivery and that is at a cost of 8.95 for the shipping. Also they don't make clear until it's to late that they take your Credit Card but payment is through Pay Pal, and your are charged before you can verify that you will even receive the product, another drawback. That there would be noway of tracking this order between Israel and the US, which could be up to three weeks. Evidently the Israeli post travels by boat, and they done tell you this until after the order has been finalized. So I would highly recommend that this site be avoided. |
New member Username: Warrenz
Post Number: 1 Registered: Feb-08
| Posted on Friday, February 01, 2008 - 10:04 pm: |
Take your dimensions to the fabric shop; http://www.vcao.net |
